주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iMac Intel 27" EMC 2390 Optical Drive Replacement
필요한 것
    1. iMac Intel 27" EMC 2390 Optical Drive Replacement, Glass Panel: 1 단계, 이미지 3개 중 1개 iMac Intel 27" EMC 2390 Optical Drive Replacement, Glass Panel: 1 단계, 이미지 3개 중 2개 iMac Intel 27" EMC 2390 Optical Drive Replacement, Glass Panel: 1 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Heavy-Duty Suction Cups (Pair)
      $16.95
      • Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
      • To attach the suction cups, first position the suction cup with the movable handle parallel to the face of the glass panel (as indicated in the second picture).
      • While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
      • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a damp soft, lint-free cloth. (Dampen with distilled water, and if needed, an equal ratio of distilled water and white vinegar for best results.)
      • Do not use the suction cups to carry the display glass because if one of them fails to stick, you could drop the screen and break it.
      • The original iMac box makes a good place to store the glass panel. Otherwise, a padded horizontal surface, like a towel on a desk, will do nicely.
      댓글 쓰기
    2. iMac Intel 27" EMC 2390 Optical Drive Replacement: 2 단계, 이미지 3개 중 1개 iMac Intel 27" EMC 2390 Optical Drive Replacement: 2 단계, 이미지 3개 중 2개 iMac Intel 27" EMC 2390 Optical Drive Replacement: 2 단계, 이미지 3개 중 3개
      • Gently lift the glass panel perpendicular to the face of the LCD, enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
      • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
      • Don't use the suction cups to carry the glass panel—if either one loses its grip, the panel could fall and break.
      • After setting the glass panel down safely, be sure to release the suction cups, as the suction force over time can crack the glass.
      • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
      댓글 쓰기
    1. iMac Intel 27" EMC 2390 Optical Drive Replacement, Display: 3 단계, 이미지 1개 중 1개
      • Remove the eight T10 Torx screws securing the LCD to the outer case.
      댓글 쓰기
    2. iMac Intel 27" EMC 2390 Optical Drive Replacement: 4 단계, 이미지 3개 중 1개 iMac Intel 27" EMC 2390 Optical Drive Replacement: 4 단계, 이미지 3개 중 2개 iMac Intel 27" EMC 2390 Optical Drive Replacement: 4 단계, 이미지 3개 중 3개
      • Carefully lay the iMac stand-side down on a flat surface.
      • Due to tight tolerances, you will have to use a thin hooked tool to lift the display out of the outer case. As seen in the third picture, we made one out of a bent paperclip.
      • Use a thin hooked tool to lift one side of the top edge of the display by its steel outer frame.
      • After lifting the top edge of the display on one side, hold it out of the outer case while you use a hooked tool to lift the other side.
      • Do not lift the top edge of the display out of the outer case too far, as several short ribbon cables still connect the two components.
      댓글 쓰기
    3. iMac Intel 27" EMC 2390 Optical Drive Replacement: 5 단계, 이미지 2개 중 1개 iMac Intel 27" EMC 2390 Optical Drive Replacement: 5 단계, 이미지 2개 중 2개
      • Using your fingers, carefully pull the vertical sync cable out of its socket on the LED driver board near the top left corner of your iMac.
      • Be sure to pull the connector parallel to the LED driver board, straight out of its socket.
      댓글 쓰기
    4. iMac Intel 27" EMC 2390 Optical Drive Replacement: 6 단계, 이미지 1개 중 1개
      • Squeeze the two display data cable connector arms together to unlock it from its socket on the logic board.
      • Pull the display data cable connector away from its socket on the logic board.
      댓글 쓰기
    5. iMac Intel 27" EMC 2390 Optical Drive Replacement: 7 단계, 이미지 1개 중 1개
      • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
      댓글 쓰기
    6. iMac Intel 27" EMC 2390 Optical Drive Replacement: 8 단계, 이미지 1개 중 1개
      • Lift the display for enough clearance to disconnect the LCD thermal sensor cable connector from its socket on the logic board.
      • If your fan is spinning full speed after completion, check this connection or the hard drive's thermal sensor cable.
      댓글 쓰기
    7. iMac Intel 27" EMC 2390 Optical Drive Replacement: 9 단계, 이미지 1개 중 1개
      • Carefully pull the display toward the top edge of your iMac and lift it out of the outer case.
      댓글 쓰기
    1. iMac Intel 27" EMC 2390 Optical Drive Replacement, Optical Drive: 10 단계, 이미지 1개 중 1개
      • Remove the four T10 Torx screws securing the optical drive to the outer case.
      댓글 쓰기
    2. iMac Intel 27" EMC 2390 Optical Drive Replacement: 11 단계, 이미지 1개 중 1개
      • Pull the optical drive thermal sensor connector straight away from its socket on the logic board.
      댓글 쓰기
    3. iMac Intel 27" EMC 2390 Optical Drive Replacement: 12 단계, 이미지 2개 중 1개 iMac Intel 27" EMC 2390 Optical Drive Replacement: 12 단계, 이미지 2개 중 2개
      • Insert a spudger between the optical drive connector and the optical drive.
      • Twist the spudger to slightly separate the optical drive connector from the optical drive, then use your fingers to pull the connector away from the drive.
      댓글 쓰기
    4. iMac Intel 27" EMC 2390 Optical Drive Replacement: 13 단계, 이미지 1개 중 1개
      • Lift the left edge of the optical drive slightly and pull it away from the right side of the outer case.
      • During reassembly, note that there are two holes in the optical drive face plate into which two stubby plastic posts must engage for proper positioning.
      댓글 쓰기
    1. iMac Intel 27" EMC 2390 Optical Drive Replacement, Optical Drive: 14 단계, 이미지 2개 중 1개 iMac Intel 27" EMC 2390 Optical Drive Replacement, Optical Drive: 14 단계, 이미지 2개 중 2개
      • Peel back the portion of aluminum tape highlighted in red, leaving the rest attached to the black plastic optical drive bracket.
      • It is not necessary to peel all of the EMI tape off the optical drive bracket.
      댓글 쓰기
    2. iMac Intel 27" EMC 2390 Optical Drive Replacement: 15 단계, 이미지 2개 중 1개 iMac Intel 27" EMC 2390 Optical Drive Replacement: 15 단계, 이미지 2개 중 2개
      • Remove the two T10 Torx screws from each side of the optical drive (four screws total).
      댓글 쓰기
    3. iMac Intel 27" EMC 2390 Optical Drive Replacement: 16 단계, 이미지 3개 중 1개 iMac Intel 27" EMC 2390 Optical Drive Replacement: 16 단계, 이미지 3개 중 2개 iMac Intel 27" EMC 2390 Optical Drive Replacement: 16 단계, 이미지 3개 중 3개
      • Use the tip of a spudger to press each of the optical drive bracket tabs out of their slots on the bottom of the optical drive.
      • Rotate the optical drive bracket slightly away from the optical drive.
      • Pull the optical drive bracket away from the open end of the optical drive, minding any tabs that may get caught.
      댓글 쓰기
    4. iMac Intel 27" EMC 2390 Optical Drive Replacement: 17 단계, 이미지 2개 중 1개 iMac Intel 27" EMC 2390 Optical Drive Replacement: 17 단계, 이미지 2개 중 2개
      • Use the tip of a spudger to peel back the piece of foam tape covering the optical drive thermal sensor.
      • Use the flat end of a spudger to carefully pry the thermal sensor up off the adhesive securing it to the optical drive.
      • If you have a disc or anything else stuck inside your optical drive, we have a guide to fix it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 24명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Brett Hartt
회원 가입일: 04/12/10
132,422 평판
안내서 144개를 작성함
iFixit iFixit 회원
Staff
122 회원들
안내서 86,241개를 작성함
4가이드 댓글
Great Guide!, Worked for me, I didn't need the hook tool, or suction cups.
Travis Reeves - 답글 공유
My optical drive is dead... do I have to replace it with an identical model? Ifixit doesn't seem to have the part for a mid 2010 iMac?
Don - 답글 공유
Thank you Brett!!
Roberto Blandino - 답글 공유
Great guide. I did this at same time as replacing my failed internal 1Tb Seagate hard drive (second disc factory fitted). All running great now.
I replaced my failed Sony AD-5680 superdrive with a compatible Hitach GA32N, only problem I had was that it was quite tricky to get the new drive in the caddy with the mounting srew holes lined up, needed a fair bit of pressure whilst lining up screws. Good gide - Thanks!
Simon Young - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 47
지난 30일: 95
전체 시간: 33,826
