소개
prerequisite for logic board, heat sink, and CPU
  1. Remove the four 7.5 mm T8 screws from behind the GPU on the logic board. These screws are set inside large, spring-loaded Phillips #2 screws. To prevent the larger screws from spinning when you loosen the T8 screws, hold them with a fingertip or Phillips #2 screwdriver. These screws are set inside large, spring-loaded Phillips #2 screws. To prevent the larger screws from spinning when you loosen the T8 screws, hold them with a fingertip or Phillips #2 screwdriver.
    • Remove the four 7.5 mm T8 screws from behind the GPU on the logic board.
    • These screws are set inside large, spring-loaded Phillips #2 screws. To prevent the larger screws from spinning when you loosen the T8 screws, hold them with a fingertip or Phillips #2 screwdriver.
  2. Remove the bracket from behind the GPU heat sink.
    • Remove the bracket from behind the GPU heat sink.
  3. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  4. Remove four black stickers from the back of the CPU heat sink.
    • Remove four black stickers from the back of the CPU heat sink.
  5. Remove four 12.3 mm T10 screws from the back of the CPU heat sink.
    • Remove four 12.3 mm T10 screws from the back of the CPU heat sink.
  6. Remove the spring plate from behind the CPU heat sink. Lift and remove the backing plate from behind the CPU heat sink. The backing plate has two posts that fit into alignment holes in the logic board. Lift and remove the backing plate from behind the CPU heat sink. The backing plate has two posts that fit into alignment holes in the logic board.
    • Remove the spring plate from behind the CPU heat sink.
    • Lift and remove the backing plate from behind the CPU heat sink. The backing plate has two posts that fit into alignment holes in the logic board.
  7. Lift the heat sink up from the logic board. The CPU will most likely stick to the heat sink, so be careful about where you put it down. The CPU will most likely stick to the heat sink, so be careful about where you put it down.
    • Lift the heat sink up from the logic board.
    • The CPU will most likely stick to the heat sink, so be careful about where you put it down.
결론
Andrew Optimus Goldheart
회원 가입일: 2009년 10월 17일
414,554 평판
안내서 411개 작성하였습니다
iFixit iFixit 회원
Community
101 회원들
안내서 8,662개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 120
