이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Removing smoke, shadow, dust behing the LCD panel of 20, 21.5, 24 and 27-inch non-unibody aluminium iMac.
필요한 것
Using the "Putty Knife" make a groove in the shield around the whole frame ;
Once done from the bottom center to the edges of the LCD panel unclip the frame (don't touch the top). Clips are located at :
Bottom left, center, right ;
Left bottom, top ;
Right bottom, top ;
Lift the frame 90° maximum ;
Using gloves and a suction cup gently lift the LCD sheet (no more than 90° failing to do so may bend the LCD and cause image displaying issues);
Meticulously clean the inside. Do not use any detergent at most a very lightly humidified microfiber / lint-free cloth ;
Do not use an air spray as those might leave marks. Best to get rid of dust is a simple hair dryer going from the top center to the edges ;
Reassembly is going back those steps making sure to get rid of your finger-prints ;
다른 21명이 해당 안내서를 완성하였습니다.
댓글 24개
I got the screen cleaned and all was well but when I returned everything back to the iMac the lower part of my screen didn't work...
If the backligt is ok but no image check connections :
— To the logic board ;
— Then underneath the protective cover on the top of step 2 image…
If the backlight is not ok check the connector and the cable at the lower right corner of step 2 image.
Beware that if you have bended the LCD you might have damaged it.
LLange -
It sounds like the LCD got bent then because the connections are fine so I just ordered a new LCD. But the guide was definitely helpful, I got the dust out!
Sorry about this I'm adding a warning on Step 5 to lift gently and no more than 90° hoping this might prevent others to have the same issue.
P.S. the LCD has an electronic board some times people have flickering issues after the display warmed-up. Thus changing that "inner-board" might solve their issue ⇒ after you receive your new LCD, try to sell the old display "inner-board" as well as the connectors…
LLange -
