소개
We couldn’t squeeze every last ounce of chip ID into our iMac M1 24” teardown. So if you couldn’t get enough of that sweet silicon, here is a much more thorough look into the chips found on the logic board, interconnect board, and display board.
Back side of the logic board:
Apple APL1102/339S00817 64-bit M1 8-core SoC (system on a chip).
SK hynix H9HCNNNCRMMVGR-NEH 8 GB (2 x 4 GB) LPDDR4 SDRAM memory
Kioxia KICM225VE4779 128 GB NAND Flash
Murata 339S00763 Wi-Fi/Bluetooth module
Apple APL1096/343S00474 power management IC
Apple APL1097/343S00475 power management IC
Richtek RT4541GQV power management IC
Back side of the logic board, continued:
Texas Instruments INA210 bi-directional current sense amplifier
Texas Instruments INA214 bi-directional current sense amplifier
Texas Instruments TPS62137 DC-DC converter
Dialog Semiconductor (formerly Silego) SLG59M301V 4-amp load switch
Texas Instruments SN74AVC4T234 4-bit bus transceiver
Front side of the logic board:
Broadcom BCM57762 ethernet controller
Infineon (formerly Cypress Semiconductor) CYPDC1185B2-32LQXQ USB-C cable controller
Cirrus Logic CS42L83A audio codec
Analog Devices SSM3515B 31-watt class-D audio amplifier
Analog Devices (formerly Linear Technology) LTC3890-2 two-phase synchronous step-down converter
Texas Instruments TPS259827ON 15-amp eFuse with load current monitoring and transient fault management
Front side of logic board, continued:
Macronix MX25U6472F 64 MB serial NOR flash memory
Texas Instruments OPA333 single zero-drift CMOS operational amplifier
Temperature sensor (likely)
Nexperia (formerly NXP Semiconductor) 74AVC2T45 2-bit dual-supply voltage level translator/transceiver
Texas Instruments SN74AHC1G32 single 2-input OR gate
NXP Semiconductor SN210V NFC controller with secure element
Interconnect board:
ASMedia ASM3142 PCIe-to-USB 3.1 Gen 2 controller
Texas Instruments CD3218B12 USB-C port/power delivery controller
Intel JHL8040R Thunderbolt 4 retimer
ASMedia ASM1543 10 Gbps 4:2 mux switch with USB 3.1 type-C compatibility
Texas Instruments TMP464 five-channel temperature sensor
Interconnect board, continued:
Winbond W25Q80DVUXIE 8 MB serial NOR flash memory
Texas Instruments INA231BIYFD 16-bit current/voltage/power monitor
Texas Instruments TMUX1108 1-channel analog multiplexer (likely)
Texas Instruments TLV75533P 500 mA LDO regulator
Maxim Integrated DC-DC converter
Nexperia (formerly NXP Semiconductor) 74AUP1G09 single AND gate
Nexperia (formerly NXP Semiconductor) LSF0101 1-bit bidirectional multi-voltage level translator
Texas Instruments SN74AXC1T45 dual-supply bus transceiver
Texas Instruments SN74AUP1G17 Schmitt trigger (likely)
Left side of the display board:
Parade Technologies DP855A DisplayPort timing controller
Silicon Works SW50024 LCD level shifter
Winbond W25Q40EWUXIE 4 MB serial NOR flash memory
Texas Instruments TMP468 9-channel temperature sensor
Dialog Semiconductor (formerly Silego) SLG46826 mixed signal array
Analog Devices (formerly Linear Technology) LTC3115-1 2-amp synchronous buck converter
Texas Instruments TPS62140 2-amp step-down converter
Right side of the display board:
Texas Instruments BUF18830 18-channel gamma-voltage generator
Richtek RT6811HGQV display power management
Texas Instruments TPS259571 eFuse with over-voltage protection
Texas Instruments TPS26621 800 mA eFuse with I/O reverse polarity protection
Texas Instruments 2N7001T 1-bit dual-supply buffered voltage signal converter
Texas Instruments TLV76701 1-amp LDO Regulator
Texas Instruments SN74LVC1G04 single inverter
Left and right side of the display board, continued:
Texas Instruments OPA2810 dual rail-to-rail I/O operational amplifier
ON Semiconductor analog switch
Dialog Semiconductor load switch (likely)
Texas Instruments microcontroller (likely)
Texas Instruments regulator (likely)
Display drivers
A partial list of chips on the power supply board:
NXP Semiconductor TEA19161T digital power supply controller
NXP Semiconductor TEA19162T power factor correction controller
NXP Semiconductor TEA2095TE dual synchronous rectifier switching controller
댓글 한 개
76MiB of flash across the boards on this machine. Apple really does like large amounts of ROM, don’t they?
