주요 콘텐츠로 건너뛰기
iNNEXT N64 Classic Controller D-Pad Replacement
필요한 것
  1. iNNEXT N64 Classic Controller D-Pad Replacement, Bottom Case: 1 단계, 이미지 2개 중 1개 iNNEXT N64 Classic Controller D-Pad Replacement, Bottom Case: 1 단계, 이미지 2개 중 2개
    • Turn the controller face down.
    • Use a Phillips #00 screwdriver to remove the eight screws on the back of the controller.
  2. iNNEXT N64 Classic Controller D-Pad Replacement: 2 단계, 이미지 1개 중 1개
    • Insert an opening tool into the seam between the top and bottom case.
    • Work your way around edge of the controller to release the tabs connecting the top and bottom of the controller.
    • Remove the bottom case from the controller.
  3. iNNEXT N64 Classic Controller D-Pad Replacement, Shoulder Buttons: 3 단계, 이미지 2개 중 1개 iNNEXT N64 Classic Controller D-Pad Replacement, Shoulder Buttons: 3 단계, 이미지 2개 중 2개
    • To remove the shoulder buttons, lift the buttons labelled with "L" and "R" upwards and out of the controller. There should not be any resistance coming out.
    • To add the new buttons, put the top notch of the shoulder buttons into the hole right above the control circuit. There should not be any resistance going in. Once done, you can put the back of the controller back on
  4. iNNEXT N64 Classic Controller D-Pad Replacement, D-Pad: 4 단계, 이미지 2개 중 1개 iNNEXT N64 Classic Controller D-Pad Replacement, D-Pad: 4 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the six screws securing the joystick assembly to the top of the controller.
    • Gently lift the control panel and joystick assembly from the top cover of the controller.
  5. iNNEXT N64 Classic Controller D-Pad Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the silicone gasket from the D-pad.
  6. iNNEXT N64 Classic Controller D-Pad Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the old D-Pad by either pulling it out from the back of the front case or pushing it out from the front of the controller.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
작성자
2다른 기여자 명과 함께
Khaymare commock
회원 가입일: 10/24/24
265 평판
안내서 3개를 작성함
UMass Dartmouth, Team 3-4, Santin Fall 2024 UMass Dartmouth, Team 3-4, Santin Fall 2024 회원
UMASSD-SANTIN-F24S3G4
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 94
