주요 콘텐츠로 건너뛰기
iON SnapCam 1045 Wearable HD Video Camera Battery
필요한 것
  1. iON SnapCam 1045 Wearable HD Video Camera Battery, Battery: 1 단계, 이미지 1/1
    • Detach the magnetic clip from the bottom of the camera.
    • The magnetic clip gets in the way of disassembly because it constantly spins and therefore a distraction so it is imperative to detach.
  2. iON SnapCam 1045 Wearable HD Video Camera Battery: 2 단계, 이미지 1/1
    • Use a spudger to gently detach the memory card and USB slot cover.
  3. iON SnapCam 1045 Wearable HD Video Camera Battery: 3 단계, 이미지 1/1
    • Use a Phillips #000 Screwdriver to loosen the 0.008 mm screw located between the USB and memory card slots.
    • This screw is really tiny and can easily fall off and get lost! Make use of a magnetic mat to hold it in place or better still put the magnetic clip to use for keeping the screw safe.
  4. iON SnapCam 1045 Wearable HD Video Camera Battery: 4 단계, 이미지 1/2 iON SnapCam 1045 Wearable HD Video Camera Battery: 4 단계, 이미지 2/2
    • Once again use the spudger to gently open the encasement.
    • The case is a little fragile and forceful entry could lead to damage of the plastic case. Thread carefully.
    • The Battery can be safely detached and replaced.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Olakunle
회원 가입일: 11/11/17
102 평판
안내서 1개 작성함
IUPUI, Team S3-G3, Wilson Fall 2017 IUPUI, Team S3-G3, Wilson Fall 2017 회원
IUPUI-WILSON-F17S3G3
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 12
전체 시간: 701
