주요 콘텐츠로 건너뛰기
iON SnapCam 1046 Lite Battery Replacement
필요한 것
  1. iON SnapCam 1046 Lite Battery Replacement, Camera Lens and Cover: 1 단계, 이미지 1/2 iON SnapCam 1046 Lite Battery Replacement, Camera Lens and Cover: 1 단계, 이미지 2/2
    • Remove any external skins placed on the device. To do so, simply lift up and peel to remove.
  2. iON SnapCam 1046 Lite Battery Replacement: 2 단계, 이미지 1/1
    • Firmly pull on the back clip in order to remove.
  3. iON SnapCam 1046 Lite Battery Replacement: 3 단계, 이미지 1/1
    • Use a Phillips head screwdriver to remove the four 4mm PH00 screws located on the sides of the device. All screws are located under each of the grey covers for the microSD card and the microUSB insert.
  4. iON SnapCam 1046 Lite Battery Replacement: 4 단계, 이미지 1/3 iON SnapCam 1046 Lite Battery Replacement: 4 단계, 이미지 2/3 iON SnapCam 1046 Lite Battery Replacement: 4 단계, 이미지 3/3
    • Grab a metal or plastic opening tool and insert it into the middle slot on the bottom of the camera and lightly pry open.
    • Locate the camera lens in the bottom left-hand corner of the picture which can be replaced by replacing the entire cover. The back of the cover is also shown. The camera is now located in the top right-hand corner of the picture.
  5. iON SnapCam 1046 Lite Battery Replacement, Battery: 5 단계, 이미지 1/2 iON SnapCam 1046 Lite Battery Replacement, Battery: 5 단계, 이미지 2/2
    • Use a nylon spudger to gently pry the four tabs holding the motherboard in place.
  6. iON SnapCam 1046 Lite Battery Replacement: 6 단계, 이미지 1/2 iON SnapCam 1046 Lite Battery Replacement: 6 단계, 이미지 2/2
    • Lift the motherboard to reveal the battery compartment. Remove the thermal tape holding it in place and replace battery.
    • WARNING: Lithium Battery!
결론
Travis Leondis
회원 가입일: 11/20/17
101 평판
안내서 1개 작성함
IUPUI, Team S22-G4, Bayer Fall 2017 IUPUI, Team S22-G4, Bayer Fall 2017 회원
IUPUI-BAYER-F17S22G4
5 회원들
안내서 4개 작성하였습니다
댓글 2개
Can you please list the battery specifications for selecting the correct replacement battery?
Thank you for the posting and assistance.
james - 답글
Where can I find a replacement battery?
Issis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 15
전체 시간: 514
