주요 콘텐츠로 건너뛰기
iON SnapCam 1046 Lite Camera Lens and Cover Replacement
필요한 것
  1. iON SnapCam 1046 Lite Camera Lens and Cover Replacement, Camera Lens and Cover: 1 단계, 이미지 1/2 iON SnapCam 1046 Lite Camera Lens and Cover Replacement, Camera Lens and Cover: 1 단계, 이미지 2/2
    • Remove any external skins placed on the device. To do so, simply lift up and peel to remove.
  2. iON SnapCam 1046 Lite Camera Lens and Cover Replacement: 2 단계, 이미지 1/1
    • Firmly pull on the back clip in order to remove.
  3. iON SnapCam 1046 Lite Camera Lens and Cover Replacement: 3 단계, 이미지 1/1
    • Use a Phillips head screwdriver to remove the four 4mm PH00 screws located on the sides of the device. All screws are located under each of the grey covers for the microSD card and the microUSB insert.
  4. iON SnapCam 1046 Lite Camera Lens and Cover Replacement: 4 단계, 이미지 1/3 iON SnapCam 1046 Lite Camera Lens and Cover Replacement: 4 단계, 이미지 2/3 iON SnapCam 1046 Lite Camera Lens and Cover Replacement: 4 단계, 이미지 3/3
    • Grab a metal or plastic opening tool and insert it into the middle slot on the bottom of the camera and lightly pry open.
    • Locate the camera lens in the bottom left-hand corner of the picture which can be replaced by replacing the entire cover. The back of the cover is also shown. The camera is now located in the top right-hand corner of the picture.
결론
Once the camera lens and cover have been replaced, reassemble the iON SnapCam Lite by following these steps in reverse order.
Kyle Whittaker
회원 가입일: 11/20/17
101 평판
안내서 1개 작성함
IUPUI, Team S22-G4, Bayer Fall 2017 IUPUI, Team S22-G4, Bayer Fall 2017 회원
IUPUI-BAYER-F17S22G4
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 11
전체 시간: 156
