이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The iOpener is an insulated, heat-retaining bag that can be heated in a microwave and used to transfer heat to the adhesive along the edge of an iPad or similar device.
Follow these basic instructions to get started with your new (black, liquid-filled) iOpener. For the white, solid-filled iOpener, follow this guide instead.
For detailed instructions specific to your device and repair, see our set of iPad repair guides.
필요한 것
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Lay the iOpener clear-side down, flat on the edge of the device, over an adhesive seal you wish to heat. The liquid will flatten the iOpener against the surface, ensuring good heat conduction.
Let the bag sit on the device for approximately 90 seconds before attempting to open the front panel.
At this point you should be able to begin prying under the screen with a plastic opening tool. Be sure to see your device's specific guide for where and how to do this.
다른 583명이 해당 안내서를 완성하였습니다.
댓글 41개
I bought two of these, and I can't get an iPad 2 to open using the iOpener; I'm going to keep trying, but heads up, it's not as easy as 1-2-3. I'll update if I get it to work.
I used a flat toaster maker and turned it off and on as required, Fixed my Ipad mini ok.
Step 2 says to wait 5 minutes between reheating, step 4 says to wait 3 minutes.
Also, do you sell the "this is a microwave" stickers? xD
Mark Brown - 답글
Did you ever find out where to get those stickers? XD
That's just a label printer label using a fancier font, I think.
towo -
