소개
Replace the adhesive securing the front panel to the rear case of your iPad 2 GSM.
Before you begin peeling and sticking tape, it's important to have clean adhesion surfaces on both the front panel and the rear case. Use a spudger to scrape off any large excess bits of original adhesive, then clean all of the gluing surfaces with a paper towel and rubbing alcohol or Goof Off.
Throughout this procedure, it is recommended to peel up each adhesive strip as needed.
필요한 것
Carefully grasp the home button with a pair of tweezers.
Gently lower and place the home button into the round opening located at the bottom of the front panel.
다른 62명이 해당 안내서를 완성하였습니다.
댓글 2개
success , reconnecting the logic board to the wi-fi and blue tooth as well as the cell data attens. was a little difficult however a little planning and lay out helps for a perfect fit and fix I would recommend gloves for sure. goof off and alcohol and a lot of elbow grease was needed to remove the old adhesive . I used paper towel spread out to catch the extra glass, worked well. be extra careful if using a heat gun as lcd can be damaged. eye protection a must. good work fixit crew...
