주요 콘텐츠로 건너뛰기
소개
Use this guide to remove your SIM card.
  1. Use a SIM eject tool or an uncoiled paperclip to eject the SIM card tray. Use a SIM eject tool or an uncoiled paperclip to eject the SIM card tray.
    • Use a SIM eject tool or an uncoiled paperclip to eject the SIM card tray.
    My iPad 2 doesn’t have a SIM card slot.
    Nolan Clewell - 답글
  2. Pull the SIM tray out of its slot and remove it from the iPad 2. If replacing the SIM card, pop it out of its tray and install the new one.
    • Pull the SIM tray out of its slot and remove it from the iPad 2.
    • If replacing the SIM card, pop it out of its tray and install the new one.
    What if SIM card is stuck inside a slot?!
    You know - modern SIM-cards are produced in all-in-one format - when you can plug-out normal SIM, micro-SIM and nano-SIM from the same plastic form.
    Dmitry Bond - 답글
결론
다른 19명이 해당 안내서를 완성하였습니다.
Walter Galan
666,995 평판
안내서 1,203개 작성하였습니다
댓글 3개
Someone deserves a gold medel for this guide...
thegoldhammer - 답글
My iPad 2 does not have the sim card slot shown above.
patrickpeterson2 - 답글
my iPad 2, labelled as a model A1397, does not appear to have this micro SIM opening. Is there a SIM for GSM and no SIM for CDMA?
rspydell - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 20
30일 전: 93
전체 시간: 59,760
