이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Carefully grasp the home button with a pair of tweezers.
Gently lower and place the home button into the round opening located at the bottom of the front panel.
Using a pair of tweezers, place the first trapezoidal adhesive strip (minding its correct orientation) on the matching side of the home button mounting bracket.
Use a pair of tweezers to grasp the corner of one of the adhesive strips placed on the mounting bracket.
Lift and peel the brown backing up off the adhesive strip, revealing the clear adhesive strip.
Gently place the home button mounting bracket on top of the home button.
Place the largest L-shaped adhesive strip on the top left corner of the front panel.
Smooth the strip down from the center out, taking care to not trap any air bubbles between the strip and the front panel.
Place the thinnest L-shaped adhesive strip on the bottom left corner of the front panel.
Place the remaining thin L-shaped adhesive strip on the top right corner of the front panel, near the camera mounting bracket.
Place the straight adhesive strip on the right side of the front panel.
If you've already attached the digitizer cable, you'll have to work around/under it to attach this strip.
Place the last L-shaped adhesive strip on the bottom right corner of the front panel.
Lay the thin T-shaped adhesive strip between the bottom edge of the inner frame of the front panel and the camera mounting bracket. The longest edge should be flush with the inner frame.
Place the small hook-shaped adhesive strip below the left side of the home button mounting bracket.
Lay the final small rectangular adhesive strip to the left of the hook-shaped adhesive strip, immediately to the right of the thin L-shaped strip, and flush with the bottom of the front panel.
다른 24명이 해당 안내서를 완성하였습니다.
댓글 한 개
Unfortunately, as of my order shipped on 5/30/2019, this guide is obsolete. The new strips are in clear semi-rigid carrier, with transparent blue backing, The new adhesive strips:
There are now only four strips of adhesive, die cut to different shapes which are completely unlike those shown in this guide - two long, unwieldy strips that run the full length of each side and wrap partway onto the top & bottom, a third strip that wraps around the front-facing camera at the top (with no applicable instructions I put it on backward so it doesn’t fit the side strips), and a fourth little bitty strip with a half-arrowhead, about 5/8”/17mm long, that doesn’t come close to filling the 1-1/2”/4 cm gap between the home button and the right-side strip, but I stuck it on anyway,
As a result, these instructions are no longer relevant. Sorry Sam’s great effort is no longer useful.
