소개
Preq for removing the front panel. Specific to the iPad 3, also involves moving the LCD over.
필요한 것
Remove the four 2 mm Phillips #00 screws securing the LCD to the aluminum frame.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
What is the diameter/pitch of these screws in case someone (myself) loses them?
john Scrivener - 답글
At this step, since I was replacing the glass and the digitizer anyway, I simply cut the digitizer cable and set aside the largest piece of glass. Since the shattered section was over most of the digitizer cable, this made working with the remaining glass shards much easier.
medhatmactech - 답글
