주요 콘텐츠로 건너뛰기
iPad 3G Home Button Switch Replacement
필요한 것
  1. iPad 3G Home Button Switch Replacement, Display Assembly: 1 단계, 이미지 3개 중 1개 iPad 3G Home Button Switch Replacement, Display Assembly: 1 단계, 이미지 3개 중 2개 iPad 3G Home Button Switch Replacement, Display Assembly: 1 단계, 이미지 3개 중 3개
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. iPad 3G Home Button Switch Replacement: 2 단계, 이미지 2개 중 1개 iPad 3G Home Button Switch Replacement: 2 단계, 이미지 2개 중 2개
    • The iPad shown in the photos may look slightly different from your iPad, but the procedure is the same.
    • Insert a metal spudger between the right edge of the display assembly and the rear panel assembly.
    • Rotate the spudger away from you to release the tabs along the top edge of the display.
  3. iPad 3G Home Button Switch Replacement: 3 단계, 이미지 2개 중 1개 iPad 3G Home Button Switch Replacement: 3 단계, 이미지 2개 중 2개
    • Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
    • Pry the display assembly away from the rear panel.
  4. iPad 3G Home Button Switch Replacement: 4 단계, 이미지 2개 중 1개 iPad 3G Home Button Switch Replacement: 4 단계, 이미지 2개 중 2개
    • Continue prying the display assembly away from the rear panel along the bottom and left edges of the iPad.
    • Use extreme caution as you approach the top edge of the iPad. The digitizer ribbon cable is located near the edge of the rear panel and can easily be damaged.
  5. iPad 3G Home Button Switch Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the display assembly away from the rear panel assembly by its bottom edge.
    • Do not excessively lift the display assembly off the rest of the iPad, as a fragile antenna cable with very little slack still connects the two components.
  6. iPad 3G Home Button Switch Replacement: 6 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry the antenna connector closest to the bottom of the iPad up off its socket on the communications board.
  7. iPad 3G Home Button Switch Replacement: 7 단계, 이미지 1개 중 1개
    • In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
    • Digitizer
    • Ambient Light Sensor
    • Display Data Cable
  8. iPad 3G Home Button Switch Replacement: 8 단계, 이미지 3개 중 1개 iPad 3G Home Button Switch Replacement: 8 단계, 이미지 3개 중 2개 iPad 3G Home Button Switch Replacement: 8 단계, 이미지 3개 중 3개
    • Use the edge of an iPod opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board.
    • Be sure you are flipping up the retaining flap, not the socket itself.
    • Pull the digitizer ribbon cables straight out of their sockets.
  9. iPad 3G Home Button Switch Replacement: 9 단계, 이미지 1개 중 1개
    • Use an iPod opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
  10. iPad 3G Home Button Switch Replacement: 10 단계, 이미지 2개 중 1개 iPad 3G Home Button Switch Replacement: 10 단계, 이미지 2개 중 2개
    • Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab.
    • Pull the cable connector away from its socket.
    • Pull the connector parallel to the face of the logic board.
  11. iPad 3G Home Button Switch Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the display assembly from the rear panel assembly.
  12. iPad 3G Home Button Switch Replacement, Home Button Switch: 12 단계, 이미지 1개 중 1개
    • Remove the two T5 Torx screws securing the home button switch board to the display frame.
  13. iPad 3G Home Button Switch Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the home button switch board from the display frame.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Andrew Bookholt
596,398 평판
안내서 619개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 18
전체 시간: 26,848
