소개
回顾近来苹果各项以教育为中心的活动,苹果似乎减少了把iPad定位为一个“不断革新的产品”,转而设定为“不断改进的产品”。从产品规格不难得知苹果对iPad进行了两个主要的大更新——处理器升级以及Apple Pencil的支持。苹果是否还对其他部件进行了更新?让我们以拆解见证事实吧
필요한 것
동영상 개요
好,上课!让我们欢迎新生:iPad 6。那么iPad 6,给我们介绍下你自己吧
苹果(Apple)A10 Fusion处理器,辅以M10协处理器
9.7英寸多点触控视网膜显示屏,分辨率2048X1536(264PPI),并且为非全贴合屏幕
32GB或128GB可选存储空间
8MP后置1080P iSight摄像头+1.2MP前置720P FaceTime高清摄像头
802.11a/b/g/n/ac 双频段MIMO Wi-Fi + Bluetooth 4.2
Touch ID指纹识别+3轴陀螺仪+加速度计+气压计+环境光传感器
支持Apple Pencil
이 단계에 사용된 도구:Battery Blocker$3.99
这次的拆解我们买一送一,一方面为你们展示新iPad,另一方面展示iFixit的新物件
在取下一堆十字螺丝后,我们可以取出LCD显示屏,并且将其与主板断开连接
安全第一,在接下来的操作前先让我们把电池隔断片插入电池与主板的接口,防止静电击穿
Where can I buy iPad 6 fpc
battery connectors? Is it interchangable with an iPad pro 2g?
Kris Payne - 답글
In this step, the photo on the far left shows the two cables that were severed on my iPad by the blue plastic triangle tools. Consequently, my digitizer is FUBAR!
The photo on the far right shows a different iPad than the one I have. Several parts are different or missing altogether. This photo should have a warning.
Hi Bradford,
As stated in the introduction, this is a teardown of the iPad 6, not a repair manual. When actual guides are written for this device, you will find them here.
이 단계에 사용된 도구:iFixit Adhesive Remover$19.99
主板被胶水牢牢地粘在了背板上,该用上我我们的胶水去除剂了
太棒了!这些胶水很快失去黏性,随后主板能被我们取出
不幸的是,Lightning接口排线也被我们一并取下,一个频繁被使用的部件意味着极易损坏,而在此,你需要非常困难的微焊操作来取下这个原本可以依靠接口取下的部件
This is disappointing. I have seen too many iPad Airs with borked charging circuits, with behaviors like battery won’t charge but unit boots or will only boot when powered by a 2.1A block, but won’t sync. Apple has to be aware of this, and it is often attributed to a bad charging controller IC. Considering that many schools are giving iPads to kids to take home, and that parents may be less than judicious about sourcing “good” iPad chargers (Five Below, anyone?) and policing good cable management, this is lamentable on Apple’s part.
到现在为止,我们并没有找到更多的大更新操作,或许苹果在主板上有些小手脚呢
苹果(Apple)A10 Fusion APL1W24 SoC(与iPhone 7同款芯片)配以镁光(Micron)2 GBD9VBD LPDDR4 SDRAM预封装
苹果(Apple)343500203-A0应该是电源管理集成电路,可能是iPad 5上343S001441-A0的改进版
两个博通(Broadcom)BCM15900B0触屏控制器,同样在10.5英寸 和12.9英寸的iPad Pro上被找到过
you have scematic ipad 6 this ?
Can I upgrade the flash memory from 32 to 64 or higher
sojib paul - 답글
我们很高兴看到苹果公司继续使用了来自iPad 5上的电池,型号为A1484,容量为32.9 Wh。
我们并没有感到高兴因为他们也带来了和iPad 5上一样的修复阻碍粘合剂。
苹果给我们带来一次前所未有的轻松移除iPad电池的希望,但是我们从未在以前见过这样的事情发生。
好消息是你已经得到了可替换的电池的机会,而且如果你是一家为大量iPad提供服务的组织,你只需要购买一个部件就可以囊括多个型号了。(就是说,如果你把原来的电池放在服务的第一位的话就是这样。)
Very flawed guide - there is no way to use the pick to start the removal of the digitizer. Ridiculous to think that the suction cup and heat will do anything useful. Further, the lack of explanation and correct detail for the Cellular model resulted in the ruination of my device - karked the cellular module because they lack the documentation for it. Karked the digitizer because again, detail wasn't correct. Wasted money, wasted device. i think the guide was pretty bad at explaining where you can actually go and where you can actually not go. It was also terrible at explaining how to reassemble with the adhesive.
다음 번역가들에게 특별히 감사 드립니다:
80%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 40개
Great tear down glad to see separate digitizer!
Same! I support several school districts, and the cost of Air 2 screens have made them unfixable at the current price point.
Hi, which toolkit is represented in step 5?
Looks like a new 112 bit tool kit with two handles! Don’t see it listed in the store yet ;-}
Dan -
I need that kit now!!!!!!!!!
The battery is the same, but will an Air 1/iPad 5 digitizer work? Will it still support pencil?
try it iFixit!?
I don’t think Air 1/iPad 5 digitizer will work on iPad 6, as the connector’s orientation is different.
Gorilla -
Why is the iFixit Adhesive Remover not for sale?
Normally it would be. Currently it’s available as part of several part + toolkit sets, but the standalone product is being updated. Check again soon ;)
oof thats $@$*!&
The LCD is the same as Air 5?
Jesus Ruiz - 답글
As ever iFixit hates Apple for designing parts that simply don’t go wrong in the first place.
Follow the money. If iFixit can’t sell parts then they give low scores.
As a consumer, not failing beats fixability every day of the week.
That’s an odd claim, the iPad 6 is patterned off of the 5, which also earned a 2, and we sell loads of parts for it. Similarly, our iPad 5 digitizer glass has over 11,000 views to date, that’s a lot of views for something that never goes wrong. Durability is great, but entropy will win eventually, and fixability is a good indicator for recyclability. Glued down batteries are dangerous and time-consuming to recycle, increasing e-waste.
Has anyone seen if digitisers are available yet? too soon I’m guessing, already had a customer in with one dropped the day after he bought it….
Tom French - 답글
So many POSITIVE descriptors for IFIXIT to do these tear downs. . . . . informative, professional, timely, waste-reducing, cost-saving, headache-minimizing and list could go on. BEST in the industry.
bob breuer - 답글
Anyone seen the digitizer yet for the 6th generation yet? ETA maybe?
I'm in need of the digitizer and the LCD Screen for the A1893 iPad 2018. Anyone know if the Air 1 LCD will be compatible or where to find a digitizer?
Thank You!
You might try Ali express. Will take forever but they can likely ship you one.
It is way too bad that Apple has used battery this small.I was intending to buy one until I see the horribly tiny battery.Come on,Apple.You are better than this.
wow very interesting
is this the ipad 2018?
yes it is the model from 2018
What kind of adhesive do you use to glue back the glass?
We would recommend pre-cut adhesive strips like these.
My ipad 6 gen does not look like this at all, on the top there is a black rectangular shaped piece where the front camera sits and there is a hole in the back metal casing to make space for it. That plastic piece is the part thats broken, What is it called and where can i buy one?
Also checked my friends ipad 6 gen as well and it has this as well. The back of these ipad 6’s look nothing like the one in this pictures.
Hi Ryan,
I think the iPad model you have is the Wi-Fi + Cellular model, while our teardown unit is the Wi-Fi only model. The black plastic rectangular piece allows for the cellular radios to penetrate through the aluminum case properly to ensure cell service. You may have to replace the entire back cover to fix the broken plastic part.
Does anybody know if the power button assembly can be replaced like the iPad 5 and some other iPads? I have a customer that has damaged their iPad to where that needs to be replaced. I didn’t want to mess with it too much unless I knew there was a part for it but I haven’t seen a power button assembly replacement unless I am not looking good enough.
@car34 Based on the X-ray, that component looks really similar to the one in the previous generation. I’m sure it’s replaceable. Whether or not it’s the same part or compatible with the iPad 5 version, I couldn’t say—my guess would be the button cover is identical, with maybe 50/50 odds the underlying flex cable is the same.
Who made the lcd? Why don’t you mention??
where to get a new display of an ipad 2017 9.7’’ please advice?
My son’s iPad screen shattered. So instead of buying a new iPad I figured I would turn it into a teaching moment for my son. I was replacing both the screen and a new home button.
Warning:
If you have a shattered screen please beware that it can be difficult to remove and leave a lot of tiny shards of glass. It was a mess.
I purchased the “iOpener” kit - which was all I needed.
Time: 4 hours
Recommended Equipment:
- Can of compressed air
- Adhesive or double sided cello tape.
- Soft anti-static and anti scratch cloths
Pro Tip:
If your screen is really shattered, I recommend leaving it in the sun for a half hour or so to really get it loose.
If you’re replacing both the screen and a new home button, don’t forget the washer ring that holds the home button in place. So if you are doing a screen and home button replacement, grab that washer and even the delicate gasket off the old home button otherwise it won’t stay snug in place. I really wish the home button kit shipped with those items intact.
genial por muestrando, quiero repararlo ahora!
I was so glad that there is separate digitizer as my warranty was finished. The screen was cracked so bad i got !#^&@@ and pull off some of it and noticed that the digitizer was separate and my god the LCD was perfectly intact. At that point I decided to get my replacement digitizer from ifixit. I was very happy that it came with the adhesive already around the edges. I followed the repair guide but still it took me almost 2 hours as I was being extra carful not to damage the LCD. For future references tape the broken screen with clear tape then proceeded to remove it as it will keep the little shards from flying over the place and most of all make sure to use protective eyewear as I said those little shards will fly as I got one in the eye.
Thank you ifixit
