주요 콘텐츠로 건너뛰기
iPad 6 Wi-Fi Battery Replacement
필요한 것
  1. iPad 6 Wi-Fi Battery Replacement, Heat the left edge: 1 단계, 이미지 1/1
    • Heat an iOpener and apply it to the left edge of the device for two minutes.
  2. iPad 6 Wi-Fi Battery Replacement, Screen removal information: 2 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement, Screen removal information: 2 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement, Screen removal information: 2 단계, 이미지 3/3
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Antennas
    • Display cables
  3. iPad 6 Wi-Fi Battery Replacement, Anti-Clamp instructions: 3 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement, Anti-Clamp instructions: 3 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement, Anti-Clamp instructions: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Anti-Clamp
    $24.95
    구매
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. iPad 6 Wi-Fi Battery Replacement: 4 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 4 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 4 단계, 이미지 3/3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPad 6 Wi-Fi Battery Replacement: 5 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 5 단계, 이미지 2/2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. iPad 6 Wi-Fi Battery Replacement, Insert an opening pick: 6 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement, Insert an opening pick: 6 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement, Insert an opening pick: 6 단계, 이미지 3/3
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
  7. iPad 6 Wi-Fi Battery Replacement, Separate the left adhesive: 7 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement, Separate the left adhesive: 7 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement, Separate the left adhesive: 7 단계, 이미지 3/3
    • Insert a second opening pick into the gap you just created.
    • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
  8. iPad 6 Wi-Fi Battery Replacement: 8 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 8 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 8 단계, 이미지 3/3
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
  9. iPad 6 Wi-Fi Battery Replacement: 9 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 9 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 9 단계, 이미지 3/3
    • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
  10. iPad 6 Wi-Fi Battery Replacement, Heat the top edge: 10 단계, 이미지 1/1
    • Heat an iOpener and apply it to the top edge of the device for two minutes.
  11. iPad 6 Wi-Fi Battery Replacement, Separate the top left adhesive: 11 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement, Separate the top left adhesive: 11 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement, Separate the top left adhesive: 11 단계, 이미지 3/3
    • Rotate the pick around the top-left corner of the device to separate the adhesive.
  12. iPad 6 Wi-Fi Battery Replacement, Separate the top adhesive: 12 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement, Separate the top adhesive: 12 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement, Separate the top adhesive: 12 단계, 이미지 3/3
    • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
  13. iPad 6 Wi-Fi Battery Replacement: 13 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 13 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 13 단계, 이미지 3/3
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
  14. iPad 6 Wi-Fi Battery Replacement: 14 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 14 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 14 단계, 이미지 3/3
    • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
  15. iPad 6 Wi-Fi Battery Replacement, Heat the right edge: 15 단계, 이미지 1/1
    • Heat an iOpener and apply it to the right edge of the device for two minutes.
  16. iPad 6 Wi-Fi Battery Replacement, Separate the top right adhesive: 16 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement, Separate the top right adhesive: 16 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement, Separate the top right adhesive: 16 단계, 이미지 3/3
    • Rotate the pick around the top-right corner of the device to separate the adhesive.
  17. iPad 6 Wi-Fi Battery Replacement, Separate the right adhesive: 17 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement, Separate the right adhesive: 17 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement, Separate the right adhesive: 17 단계, 이미지 3/3
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
  18. iPad 6 Wi-Fi Battery Replacement, Heat the bottom edge: 18 단계, 이미지 1/1
    • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
  19. iPad 6 Wi-Fi Battery Replacement, Separate the bottom left adhesive: 19 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement, Separate the bottom left adhesive: 19 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement, Separate the bottom left adhesive: 19 단계, 이미지 3/3
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • Leave the pick in the bottom-left corner before moving to the next step.
  20. iPad 6 Wi-Fi Battery Replacement, Separate the bottom adhesive: 20 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement, Separate the bottom adhesive: 20 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement, Separate the bottom adhesive: 20 단계, 이미지 3/3
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
  21. iPad 6 Wi-Fi Battery Replacement: 21 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 21 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 21 단계, 이미지 3/3
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
    • Only insert the pick up to 1 mm to avoid damaging the right antenna.
  22. iPad 6 Wi-Fi Battery Replacement: 22 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 22 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 22 단계, 이미지 3/3
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
  23. iPad 6 Wi-Fi Battery Replacement, Heat the right edge: 23 단계, 이미지 1/1
  24. iPad 6 Wi-Fi Battery Replacement: 24 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 24 단계, 이미지 2/2
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
  25. iPad 6 Wi-Fi Battery Replacement: 25 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 25 단계, 이미지 2/2
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
  26. iPad 6 Wi-Fi Battery Replacement, Separate the right adhesive: 26 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement, Separate the right adhesive: 26 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement, Separate the right adhesive: 26 단계, 이미지 3/3
    • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
  27. iPad 6 Wi-Fi Battery Replacement: 27 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 27 단계, 이미지 2/2
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
  28. iPad 6 Wi-Fi Battery Replacement, LCD: 28 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement, LCD: 28 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement, LCD: 28 단계, 이미지 3/3
    • Remove any tape obscuring the LCD screws.
  29. iPad 6 Wi-Fi Battery Replacement: 29 단계, 이미지 1/1
    • Remove the four Phillips #00 4.3 mm screws securing the LCD.
  30. iPad 6 Wi-Fi Battery Replacement: 30 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 30 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 30 단계, 이미지 3/3
    • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers. There may be glue around the screw holes that needs to be cut with a knife.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
    • Be gentle and keep an eye on the LCD cables as you flip the display over.
    • Lay the LCD on its face to allow access to the display cables.
    • Set the LCD down on a soft, clean, lint-free surface.
  31. iPad 6 Wi-Fi Battery Replacement, Battery connector information: 31 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement, Battery connector information: 31 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement, Battery connector information: 31 단계, 이미지 3/3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
  32. iPad 6 Wi-Fi Battery Replacement: 32 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 32 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 32 단계, 이미지 3/3
    • Remove the single 2.3 mm Phillips #000 screw securing the battery connector to the logic board.
    • To reduce the risk of a short, you can use a battery isolation pick to disconnect the battery.
    • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
    • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at a 15 degree angle.
    • Leave the battery blocker in place as you work.
  33. iPad 6 Wi-Fi Battery Replacement: 33 단계, 이미지 1/1
    • Remove the three 1.4 mm Phillips #000 screws from the display cable bracket.
  34. iPad 6 Wi-Fi Battery Replacement: 34 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 34 단계, 이미지 2/2
    • Use the flat end of a spudger to gently pry the display cable bracket straight up from the logic board.
    • The display cable connector is adhered to the underside of the bracket, so don’t push the spudger too far under the bracket, or you may damage the connector.
  35. iPad 6 Wi-Fi Battery Replacement: 35 단계, 이미지 1/1
    • Remove the LCD.
  36. iPad 6 Wi-Fi Battery Replacement, Front Panel Assembly: 36 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement, Front Panel Assembly: 36 단계, 이미지 2/2
    • Remove any tape covering the home button ribbon cable connector.
  37. iPad 6 Wi-Fi Battery Replacement: 37 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 37 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 37 단계, 이미지 3/3
    • Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
    • Carefully pull the home button ribbon cable straight out of the ZIF connector.
  38. iPad 6 Wi-Fi Battery Replacement: 38 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 38 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 38 단계, 이미지 3/3
    • Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
    • During reassembly, make sure that these connectors are completely seated in their sockets, or you may encounter display issues.
  39. iPad 6 Wi-Fi Battery Replacement: 39 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 39 단계, 이미지 2/2
    • Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
  40. iPad 6 Wi-Fi Battery Replacement: 40 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 40 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Polyimide Tape
    $9.99
    구매
    • Remove the front panel assembly.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
  41. iPad 6 Wi-Fi Battery Replacement, Right Antenna: 41 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement, Right Antenna: 41 단계, 이미지 2/2
    • Insert a spudger under the antenna cable closest to the edge of the iPad and lift upward to disconnect the antenna cable connector.
  42. iPad 6 Wi-Fi Battery Replacement: 42 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 42 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 42 단계, 이미지 3/3
    • There are two large pieces of tape wrapped around the right antenna cable, securing it to the rear case.
    • Peel the tape up from the rear case.
    • While peeling the antenna tape up, leave it in place on the antenna cable to aid with reassembly.
  43. iPad 6 Wi-Fi Battery Replacement: 43 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 43 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 43 단계, 이미지 3/3
    • The antenna cable is anchored to the speaker with a small metal bracket. The bracket is permanently crimped to the antenna and adhered to the speaker enclosure.
    • Carefully insert an opening pick between the speaker enclosure and the antenna cable bracket.
    • Slide the pick toward the home button to cut the adhesive.
    • Push the bracket away from the speaker until it clears the tape underneath.
  44. iPad 6 Wi-Fi Battery Replacement: 44 단계, 이미지 1/1
    • Remove the following Phillips #000 screws securing the right antenna:
    • One 2.3 mm screw
    • Two 1.4 mm screws
  45. iPad 6 Wi-Fi Battery Replacement: 45 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 45 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 45 단계, 이미지 3/3
    • Insert the flat end of a spudger between the antenna and the speaker assembly.
    • Slide the spudger toward the home button to cut the foam adhesive securing the antenna.
  46. iPad 6 Wi-Fi Battery Replacement: 46 단계, 이미지 1/1
    • Remove the right antenna from the iPad.
  47. iPad 6 Wi-Fi Battery Replacement, Right Speaker: 47 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement, Right Speaker: 47 단계, 이미지 2/2
    • Insert a spudger under the left antenna cable and lift upward to disconnect the antenna cable connector.
  48. iPad 6 Wi-Fi Battery Replacement: 48 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 48 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 48 단계, 이미지 3/3
    • There are five pieces of tape wrapped around the left antenna cable covering the right speaker cable connector.
    • Fold the antenna cable out of the way.
  49. iPad 6 Wi-Fi Battery Replacement: 49 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 49 단계, 이미지 2/2
    • A bend in the speaker cable makes it difficult to peel the tape up from the end.
    • Instead, grip the tape just under the speaker and peel it down, away from the edge of the case.
    • Be careful with your tweezers—only grab and peel the tape, and not the cable beneath.
  50. iPad 6 Wi-Fi Battery Replacement: 50 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 50 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 50 단계, 이미지 3/3
    • Peel the tape toward the home button to uncover the speaker cable connector.
  51. iPad 6 Wi-Fi Battery Replacement: 51 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 51 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 51 단계, 이미지 3/3
    • Use the pointed end of a spudger to flip up the retaining flap on the right speaker cable connector.
    • Slide the speaker cable straight out of its ZIF connector.
  52. iPad 6 Wi-Fi Battery Replacement: 52 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 52 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 52 단계, 이미지 3/3
    • Remove the tape holding the speaker to the rear case.
  53. iPad 6 Wi-Fi Battery Replacement: 53 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 53 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 53 단계, 이미지 3/3
    • Carefully peel the LCD buffer tape up off of the rear case.
  54. iPad 6 Wi-Fi Battery Replacement: 54 단계, 이미지 1/1
    • Remove the 2.2 mm Phillips #000 screw securing the speaker to the rear case.
  55. iPad 6 Wi-Fi Battery Replacement: 55 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 55 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 55 단계, 이미지 3/3
    • Insert a fingernail or the flat end of a spudger in the groove in the speaker housing, near the corner of the rear case.
    • Pull the speaker down, away from the corner of the case.
  56. iPad 6 Wi-Fi Battery Replacement: 56 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 56 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 56 단계, 이미지 3/3
    • Use a spudger to help pull the speaker out from under the edge of the rear case.
    • Remove the right speaker from the iPad.
  57. iPad 6 Wi-Fi Battery Replacement, Upper Component Cable Bracket: 57 단계, 이미지 1/1
    • Remove the three 1.4 mm Phillips #000 screws securing the upper component cable bracket.
  58. iPad 6 Wi-Fi Battery Replacement: 58 단계, 이미지 1/1
    • Remove the upper component cable bracket.
    • If you have the Wi-Fi/Cellular model, your iPad will look slightly different and will require the removal of two additional screws to access components covered by this bracket.
  59. iPad 6 Wi-Fi Battery Replacement, Logic Board: 59 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement, Logic Board: 59 단계, 이미지 2/2
    • There are two remaining pieces of tape securing the left antenna cable to the rear case.
  60. iPad 6 Wi-Fi Battery Replacement: 60 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 60 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 60 단계, 이미지 3/3
    • Push the bracket away from the speaker until it is clear of the tape underneath.
  61. iPad 6 Wi-Fi Battery Replacement: 61 단계, 이미지 1/1
    • Remove the following Phillips #000 screws:
    • Two 1.4 mm screws
    • One 2.3 mm screw
  62. iPad 6 Wi-Fi Battery Replacement: 62 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 62 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 62 단계, 이미지 3/3
  63. iPad 6 Wi-Fi Battery Replacement: 63 단계, 이미지 1/1
    • Remove the left antenna from the iPad.
  64. iPad 6 Wi-Fi Battery Replacement: 64 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 64 단계, 이미지 2/2
    • Remove the tape covering the left speaker cable connector.
  65. iPad 6 Wi-Fi Battery Replacement: 65 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 65 단계, 이미지 2/2
    • Use the pointed end of a spudger to flip up the retaining flap on the left speaker cable connector.
  66. iPad 6 Wi-Fi Battery Replacement: 66 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 66 단계, 이미지 2/2
  67. iPad 6 Wi-Fi Battery Replacement: 67 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 67 단계, 이미지 2/2
  68. iPad 6 Wi-Fi Battery Replacement: 68 단계, 이미지 1/1
  69. iPad 6 Wi-Fi Battery Replacement: 69 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 69 단계, 이미지 2/2
    • Gently fold the left speaker ribbon cable up so that it will clear the battery when you slide the speaker enclosure out.
  70. iPad 6 Wi-Fi Battery Replacement: 70 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 70 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 70 단계, 이미지 3/3
  71. iPad 6 Wi-Fi Battery Replacement: 71 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 71 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 71 단계, 이미지 3/3
    • Remove the left speaker from the iPad.
  72. iPad 6 Wi-Fi Battery Replacement: 72 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 72 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 72 단계, 이미지 3/3
    • Use the flat end of a spudger to disconnect the front-facing camera connector from the logic board.
    • Pry up only on the connector—not on the socket itself.
    • Fold the front-facing camera cable out of the way.
    • There is a bit of conductive adhesive between the gold-colored cable contacts. Be sure to apply pressure to readhere these contacts during reassembly.
  73. iPad 6 Wi-Fi Battery Replacement: 73 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 73 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 73 단계, 이미지 3/3
    • Use the flat end of a spudger to disconnect the rear-facing camera connector from the logic board.
    • Fold the rear-facing camera cable out of the way.
  74. iPad 6 Wi-Fi Battery Replacement: 74 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 74 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 74 단계, 이미지 3/3
    • Use the flat end of a spudger to disconnect the headphone jack connector from the logic board.
    • Newer iPad units have a loop of tape connecting this connector to its socket on the the logic board. This tape must be cut in order to disconnect the headphone jack.
    • Fold the headphone jack cable out of the way.
  75. iPad 6 Wi-Fi Battery Replacement: 75 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 75 단계, 이미지 2/2
    • Use the flat end of a spudger to disconnect the microphone cable connector from the logic board.
  76. iPad 6 Wi-Fi Battery Replacement: 76 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 76 단계, 이미지 2/2
    • Remove any tape covering the upper button assembly cable connector.
  77. iPad 6 Wi-Fi Battery Replacement: 77 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 77 단계, 이미지 2/2
    • Use the pointed end of a spudger to flip up the retaining flap on the upper button assembly cable connector.
  78. iPad 6 Wi-Fi Battery Replacement: 78 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 78 단계, 이미지 2/2
    • Slide the upper button assembly cable straight out of its ZIF connector.
  79. iPad 6 Wi-Fi Battery Replacement: 79 단계, 이미지 1/1
    • Remove the two 3.3 mm Phillips #000 screws securing the Lightning port.
    • To find these screws, hold the iPad vertically and look down at the Lightning port.
  80. iPad 6 Wi-Fi Battery Replacement: 80 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 80 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 80 단계, 이미지 3/3
    • In the next steps, you will use an iOpener to apply heat to the rear case of the iPad to soften adhesive holding the logic board in place.
    • As you reheat and place the iOpener in each of the indicated locations, leave it in place for at least a minute to soften the adhesive through the rear case.
    • The adhesive is in the form of six pieces of black foam tape—refer to this step as you work at heating and prying to keep track of where each piece is located.
  81. iPad 6 Wi-Fi Battery Replacement: 81 단계, 이미지 1/1
    • Place a heated iOpener over the rear-facing camera end of the iPad, and let it sit for at least a minute to soften the adhesive through the rear case.
    • More time won't hurt, but you may need to reheat your iOpener and reapply it if you leave it on the rear case for too long.
  82. iPad 6 Wi-Fi Battery Replacement: 82 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 82 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 82 단계, 이미지 3/3
    • As you complete the next few steps, prying adhesive securing the logic board in place, always start by testing gently to see if the adhesive is softened. If not, reheat the iOpener and reapply it to the back of the rear case.
    • Carefully insert an opening pick under the logic board, between the front-facing camera and the battery.
    • Slide the pick toward the front-facing camera connector, and stop at the bend in the logic board.
  83. iPad 6 Wi-Fi Battery Replacement: 83 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 83 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 83 단계, 이미지 3/3
    • Slide an opening pick under the logic board from the front-facing camera to the rear facing camera.
  84. iPad 6 Wi-Fi Battery Replacement: 84 단계, 이미지 1/1
    • Place a heated iOpener along the bottom edge of the iPad.
    • Again, let the iOpener sit for at least a minute to soften the adhesive through the rear case.
  85. iPad 6 Wi-Fi Battery Replacement: 85 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 85 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 85 단계, 이미지 3/3
    • The Lightning connector cable is stuck to the case with some adhesive. To detach the adhesive you will be sliding an opening pick between the cable and the case. Be very careful not to cut the Lightning connector cable itself.
    • Insert an opening pick under the Lightning cable where it meets the logic board.
    • Slide the pick down and around the bend in the cable.
  86. iPad 6 Wi-Fi Battery Replacement: 86 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 86 단계, 이미지 2/2
    • Continue to slide the opening pick under the cable, stopping before the cable bends to the Lightning connector.
    • Move slowly and carefully. If the opening pick does not slide easily, apply more heat and try again. If you use excessive force, you will likely slip and sever the Lightning connector cable.
  87. iPad 6 Wi-Fi Battery Replacement: 87 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 87 단계, 이미지 2/2
    • Finally, slide the opening pick between the battery and the Lightning connector itself to separate the last of the adhesive underneath the cable.
  88. iPad 6 Wi-Fi Battery Replacement: 88 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 88 단계, 이미지 2/2
    • Pull the Lightning connector straight out of its recess in the rear case.
  89. iPad 6 Wi-Fi Battery Replacement: 89 단계, 이미지 1/1
    • Place a heated iOpener on the left side of the rear case, where the logic board is adhered.
    • Let the iOpener sit for at least a minute to soften the adhesive through the rear case.
  90. iPad 6 Wi-Fi Battery Replacement: 90 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 90 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 90 단계, 이미지 3/3
    • Insert a plastic opening tool in the rectangular gap in the upper area of the logic board, and pry the logic board up from the rear case.
    • While keeping the opening tool underneath the logic board, slide it down the length of the gap to free the upper end of the logic board from the adhesive.
  91. iPad 6 Wi-Fi Battery Replacement: 91 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 91 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 91 단계, 이미지 3/3
    • Pry up the logic board at the lower edge of the rectangular gap, near the EMI shield.
    • Lift the end of the logic board slowly. If you encounter significant resistance, stop prying and reapply the iOpener.
  92. iPad 6 Wi-Fi Battery Replacement: 92 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 92 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 92 단계, 이미지 3/3
    • Slide an opening pick under the logic board between it and the battery.
    • Slide the pick from the base to the center of the logic board to cut the adhesive.
    • Take care not to cut the battery with the opening pick; a punctured battery can be very dangerous. If you encounter resistance, reheat and reapply the iOpener.
  93. iPad 6 Wi-Fi Battery Replacement: 93 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 93 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 93 단계, 이미지 3/3
    • Slide the pick up the length of the logic board.
    • Once the adhesive has been cut, pry the battery side of the logic board upward off of the rear case.
  94. iPad 6 Wi-Fi Battery Replacement: 94 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 94 단계, 이미지 2/2
    • Continue to lift the logic board along the edge nearest the battery, until you can get an opening pick against the far edge of the logic board.
    • Cut any adhesive holding the outer edge of the logic board to the rear case.
  95. iPad 6 Wi-Fi Battery Replacement: 95 단계, 이미지 1/1
    • Remove the logic board from the iPad.
  96. iPad 6 Wi-Fi Battery Replacement, Battery: 96 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement, Battery: 96 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement, Battery: 96 단계, 이미지 3/3
    이 단계에 사용된 도구:
    iFixit Adhesive Remover
    $19.99
    구매
    • The following steps instruct you to use heat to soften the glue securing the battery. A safer alternative is to inject a solvent, such as iFixit adhesive remover, between the battery and rear case to dissolve the adhesive.
    • Reheat the iOpener in the microwave for 30 seconds.
    • Remember to be careful not to overheat the iOpener during the repair procedure. Wait at least two minutes before reheating the iOpener, and never microwave it for more than 30 seconds.
    • Place the heated iOpener in the center of the back of the iPad. Let it sit there for 90 seconds to soften the battery adhesive.
    • Move the iOpener to the right (away from the rear-facing camera), and let the iOpener sit for another 90 seconds.
    • Finally, move the iOpener to the right-hand edge of the iPad for 90 seconds.
    • The iOpener may cool significantly between sittings—if it does, reheat for another 30 seconds between each position.
  97. iPad 6 Wi-Fi Battery Replacement: 97 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 97 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 97 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Throughout the following procedure, you'll be sliding thin plastic cards between the battery and rear case of the iPad, to separate the adhesive securing the battery. Be careful to keep the cards as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals.
    • Insert a plastic card under the lower battery cell, at the lower right-hand corner.
    • If you encounter significant resistance, re-heat the iOpener and repeat the previous step to give the adhesive more time to soften.
  98. iPad 6 Wi-Fi Battery Replacement: 98 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 98 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 98 단계, 이미지 3/3
    • With the card roughly halfway inserted, slide it toward the top of the iPad, stopping before the battery contact post.
  99. iPad 6 Wi-Fi Battery Replacement: 99 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 99 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 99 단계, 이미지 3/3
    • Lift the card up from the rear case slightly to allow it to pass over the battery contact mounting post.
    • Slide the card from the center of the battery cells to the upper right corner of the battery.
  100. iPad 6 Wi-Fi Battery Replacement: 100 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 100 단계, 이미지 2/2
    • Place a second plastic card about halfway under the left hand battery cell to prevent it from readhering when you reapply the iOpener.
  101. iPad 6 Wi-Fi Battery Replacement: 101 단계, 이미지 1/1
    • Place an iOpener on the right side of the battery, opposite the cards, to loosen the adhesive.
  102. iPad 6 Wi-Fi Battery Replacement: 102 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 102 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 102 단계, 이미지 3/3
    • Slide the card around the lower right corner of the battery.
  103. iPad 6 Wi-Fi Battery Replacement: 103 단계, 이미지 1/2 iPad 6 Wi-Fi Battery Replacement: 103 단계, 이미지 2/2
    • Slide the plastic card to the lower left corner of the battery.
  104. iPad 6 Wi-Fi Battery Replacement: 104 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 104 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 104 단계, 이미지 3/3
    • Press the card in further, breaking as much of the adhesive holding in the battery as you can.
    • Place the plastic card underneath the lower left corner of the battery.
  105. iPad 6 Wi-Fi Battery Replacement: 105 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 105 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 105 단계, 이미지 3/3
    • Slide the card around the upper right corner of the battery.
    • Be extremely careful to slide the card over the front-facing camera and headphone jack cables to avoid cutting them.
  106. iPad 6 Wi-Fi Battery Replacement: 106 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 106 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 106 단계, 이미지 3/3
    • Slide the plastic card to the upper left corner of the battery.
    • Be careful to slide the card over the front-facing camera and headphone jack cables to avoid cutting them.
  107. iPad 6 Wi-Fi Battery Replacement: 107 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 107 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 107 단계, 이미지 3/3
    • Place the plastic card underneath the upper left corner of the battery.
  108. iPad 6 Wi-Fi Battery Replacement: 108 단계, 이미지 1/3 iPad 6 Wi-Fi Battery Replacement: 108 단계, 이미지 2/3 iPad 6 Wi-Fi Battery Replacement: 108 단계, 이미지 3/3
    • Grip both cards firmly and twist them to lift the battery off of the rear case.
    • Remove the battery from the rear case.
결론
다른 35명이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
252,736 평판
안내서 526개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 9개
analyzing the structure of the arrangement of the components, is it necessary to remove everything? I think you could only remove the battery without removing the logic card.
Vik Ledesma - 답글
Hi Vik,
While it may not be necessary to remove the logic board to remove the battery, we found that it is the safest option. Removing the logic board first allows you to pry the battery around all the edges while keeping the bending to a minimum.
Arthur Shi -
Geez, 111 steps to remove the battery and how many to reassemble? Insanity!!
rudyfs2 - 답글
Thanks for a great guide! I left out steps 47 to 100 as some suggested and it worked fine for just replacing the battery. I was aware that the issue may be the bending of the battery and, therefore, iFixit does not recommend skipping these steps. However it worked fine for me. My tip is to allow yourself enough time to loosen the battery from the adhesive and keep the heated iOpener always underneath the section of the battery that you are working on. This way the adhesive softens and allows you to loosen the battery step by step. - It took me 3 hours of which the first hour was trying to figure out how to get Step 9 done. It took me a while to have the iOpener at the right temperature. So, be patient.
marcelflueeler - 답글
The guide worked perfectly, thanks! But now there is an issue with the battery after reassembling. The iPad can‘t be charged and it turns itself off every 5min.
Any ideas?
Jonas (Dschounäs) - 답글
댓글 쓰기
조회 통계:
24 시간 전: 60
7일 전: 393
30일 전: 1,834
전체 시간: 59,430
