주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
iPad 6 Wi-Fi Front Panel Assembly Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. iPad 6 Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: 1 단계, 이미지 1/2 iPad 6 Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: 1 단계, 이미지 2/2
    • Remove any tape covering the home button ribbon cable connector.
  2. iPad 6 Wi-Fi Front Panel Assembly Replacement: 2 단계, 이미지 1/3 iPad 6 Wi-Fi Front Panel Assembly Replacement: 2 단계, 이미지 2/3 iPad 6 Wi-Fi Front Panel Assembly Replacement: 2 단계, 이미지 3/3
    • Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
    • Carefully pull the home button ribbon cable straight out of the ZIF connector.
  3. iPad 6 Wi-Fi Front Panel Assembly Replacement: 3 단계, 이미지 1/3 iPad 6 Wi-Fi Front Panel Assembly Replacement: 3 단계, 이미지 2/3 iPad 6 Wi-Fi Front Panel Assembly Replacement: 3 단계, 이미지 3/3
    • Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
  4. iPad 6 Wi-Fi Front Panel Assembly Replacement: 4 단계, 이미지 1/2 iPad 6 Wi-Fi Front Panel Assembly Replacement: 4 단계, 이미지 2/2
    • Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
  5. iPad 6 Wi-Fi Front Panel Assembly Replacement: 5 단계, 이미지 1/2 iPad 6 Wi-Fi Front Panel Assembly Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Polyimide Tape
    $9.99
    구매
    • Remove the front panel assembly.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sam Goldheart
회원 가입일: 10/18/12
465,744 평판
안내서 538개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,767개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 132
