주요 콘텐츠로 건너뛰기
iPad Air 3 Screen Replacement
필요한 것
  1. iPad Air 3 Screen Replacement, Screen: 1 단계, 이미지 2개 중 1개 iPad Air 3 Screen Replacement, Screen: 1 단계, 이미지 2개 중 2개
    • Cracked near home button its important to not break home button flex cable
    • Apply heat to the screen! Do NOT SKIP THIS STEP
    • Make sure to turn it off if you can to prevent breaking the backlight filter
    • Pry with splicer around the edges
    • Display cables are on the bottom of screen opening up like an upside-down note pad
  2. iPad Air 3 Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Lift from the top like so
    • Display Cables
  3. iPad Air 3 Screen Replacement: 4 단계, 이미지 3개 중 1개 iPad Air 3 Screen Replacement: 4 단계, 이미지 3개 중 2개 iPad Air 3 Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Set screen up a little bit to get to power connection
    • Power connection has PH000 screw holding it together
    • Slide a card under connection
    • Its very important to disconnect battery try turning it on make sure it is off to avoid further damage to ipad
  4. iPad Air 3 Screen Replacement: 5 단계, 이미지 2개 중 1개 iPad Air 3 Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Lift display back up to get to the display cables
    • Unscrew 2 PH000 Screws from display cable bracket
    • Use the flat end of plastic spudger to lift off connections
    • There is 4 flex cables that need disconnecting
  5. iPad Air 3 Screen Replacement: 6 단계, 이미지 3개 중 1개 iPad Air 3 Screen Replacement: 6 단계, 이미지 3개 중 2개 iPad Air 3 Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Whoohoo we got it off now clean the edges for any broken glass
    • Keep track of rubbers covering proximity light sensor on the top
    • Light covers place on top of proxmity sensors
  6. iPad Air 3 Screen Replacement: 7 단계, 이미지 3개 중 1개 iPad Air 3 Screen Replacement: 7 단계, 이미지 3개 중 2개 iPad Air 3 Screen Replacement: 7 단계, 이미지 3개 중 3개
    • APPLY HEAT TO HOME BUTTON 15-20 Seconds should do the trick
    • If heat is not applied you might break the home button along with the touch ID. If you replace the home button touch ID will not work anymore
    • Take of home button flex cover
    • Use flat end of spudger to pry up home button flex connector
  7. iPad Air 3 Screen Replacement: 8 단계, 이미지 3개 중 1개 iPad Air 3 Screen Replacement: 8 단계, 이미지 3개 중 2개 iPad Air 3 Screen Replacement: 8 단계, 이미지 3개 중 3개
    • Reapply heat if you spent to much time getting flex unhooked
    • Pry with splicer under the home button bracket car
    • Clean glass around gasket
  8. iPad Air 3 Screen Replacement: 9 단계, 이미지 2개 중 1개 iPad Air 3 Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Install home button on new screen I recommend using liquid adhesive for this!
    • Push the home button a couple of times to make sure it stills on and make sure it is clicking!
  9. iPad Air 3 Screen Replacement: 10 단계, 이미지 2개 중 1개 iPad Air 3 Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Connect all 4 Flex cables to the logic board!
    • Now at the bottom of the new screen screw in the battery connection to test the new screen!
  10. iPad Air 3 Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Test screen drawing on the notes make sure it works!
    • Adhere new screen with preinstalled adhesive and clap it!
결승점
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Mark D Schlossman
회원 가입일: 09/25/19
7,089 평판
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 29
지난 30일: 131
전체 시간: 3,557
