해당 분해도에 사용된 도구
소개
This is the teardown for a Clamcase for iPad 2.
해당 분해도는 수리 안내서가 아닙니다. iPad ClamCase 수리는 저희 서비스 설명서를 사용하십시오.
  1. You can skip the first 2 steps if you don't want to detach the upper and keyboard covers from each other. Open the case and unpeel the 2 black stickers in the top corners of the keyboard.
    • You can skip the first 2 steps if you don't want to detach the upper and keyboard covers from each other.
    • Open the case and unpeel the 2 black stickers in the top corners of the keyboard.
    • This will reveal the 6 screws that attach the upper cover to the keyboard cover.
  2. Use the T9 Torx screwdriver to unscrew the 2 bigger screws in the middle of each side. Use  the T6 Torx screwdriver to unscrew the remaining 4 screws.
    • Use the T9 Torx screwdriver to unscrew the 2 bigger screws in the middle of each side.
    • Use the T6 Torx screwdriver to unscrew the remaining 4 screws.
  3. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  4. Turn the keyboard cover over so the bottom is facing up.  Manually remove the thin black covering that is attached to the bottom. Be patient, the thin black covering might be really stuck to the bottom.
    • Turn the keyboard cover over so the bottom is facing up. Manually remove the thin black covering that is attached to the bottom.
    • Be patient, the thin black covering might be really stuck to the bottom.
  5. Once the thin black covering is removed, you will see 15 screws.
    • Once the thin black covering is removed, you will see 15 screws.
    • Use the T6 Torx screwdriver to remove the screws.
  6. Once the screws are removed, lift off the bottom panel to access the keyboard and battery.
    • Once the screws are removed, lift off the bottom panel to access the keyboard and battery.
  7. You are done.
    • You are done.
Izmet Barranco
회원 가입일: 2012년 12월 12일
213 평판
안내서 1개 작성함
Awesome! I used this guide to disassemble my clam case and repair some nonfunctional keys. Thanks!
justin duff - 답글
Thanks for the dis-assembly guide. Justin, what did you have to do to fix the keys that were not working. I have on with a few keys not working, not even intermittently.
dick haynes - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 37
전체 시간: 6,630
