주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. iPad ClamCase 수리는 저희 서비스 설명서를 사용하십시오.
  1. iPad ClamCase, iPad ClamCase: 1 단계, 이미지 1/2 iPad ClamCase, iPad ClamCase: 1 단계, 이미지 2/2
    • You can skip the first 2 steps if you don't want to detach the upper and keyboard covers from each other.
    • Open the case and unpeel the 2 black stickers in the top corners of the keyboard.
    • This will reveal the 6 screws that attach the upper cover to the keyboard cover.
  2. iPad ClamCase: 2 단계, 이미지 1/2 iPad ClamCase: 2 단계, 이미지 2/2
    • Use the T9 Torx screwdriver to unscrew the 2 bigger screws in the middle of each side.
    • Use the T6 Torx screwdriver to unscrew the remaining 4 screws.
  3. iPad ClamCase: 3 단계, 이미지 1/2 iPad ClamCase: 3 단계, 이미지 2/2
    • Turn the keyboard cover over so the bottom is facing up. Manually remove the thin black covering that is attached to the bottom.
    • Be patient, the thin black covering might be really stuck to the bottom.
  4. iPad ClamCase: 4 단계, 이미지 1/1
    • Once the thin black covering is removed, you will see 15 screws.
    • Use the T6 Torx screwdriver to remove the screws.
  5. iPad ClamCase: 5 단계, 이미지 1/1
    • Once the screws are removed, lift off the bottom panel to access the keyboard and battery.
  6. iPad ClamCase: 6 단계, 이미지 1/1
    • You are done.
Izmet Barranco
회원 가입일: 12/12/12
213 평판
안내서 1개 작성함
댓글 2개
Awesome! I used this guide to disassemble my clam case and repair some nonfunctional keys. Thanks!
justin duff - 답글
Thanks for the dis-assembly guide. Justin, what did you have to do to fix the keys that were not working. I have on with a few keys not working, not even intermittently.
dick haynes - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 7
전체 시간: 7,727
