주요 콘텐츠로 건너뛰기
iPad Mini 2 Wi-Fi Front Panel Replacement
단지 전제 조건
이 안내서는 다른 안내서의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. iPad Mini 2 Wi-Fi Front Panel Replacement, Front Panel: 1 단계, 이미지 2개 중 1개 iPad Mini 2 Wi-Fi Front Panel Replacement, Front Panel: 1 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to lift the digitizer cable connector straight up off of its socket.
    • Be careful as you lift the connector from the socket—the pins in the socket are extremely fragile and can easily break!
  2. iPad Mini 2 Wi-Fi Front Panel Replacement: 2 단계, 이미지 3개 중 1개 iPad Mini 2 Wi-Fi Front Panel Replacement: 2 단계, 이미지 3개 중 2개 iPad Mini 2 Wi-Fi Front Panel Replacement: 2 단계, 이미지 3개 중 3개
    • Slide the spudger under the battery side of the digitizer board to begin separating it from the rear case.
    • Lift the digitizer board up to free the last of the adhesive.
  3. iPad Mini 2 Wi-Fi Front Panel Replacement: 3 단계, 이미지 1개 중 1개
    • Lift and remove the front panel from the iPad.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
471,489 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,418개를 작성함
댓글 2개
I'll give this quide a 3/5. The problem is the end where you just say reverse the steps. That is an easy out that too many people use. There are important things to do when re-assembling that are not pointed out that may come back to bite you just attempting to reverse the steps. I do like the stepped pictures showing before and after views. Overall the process is not that bad other than removing the broken glass which breaks a lot more as you go. A hair dryer on high worked fine for warming up the glue, you just need to be aware of cleaning the area of glass bits before turning it on. Glad I didn't pay somebody big bucks to do this job.
italternatives - 답글
Due reassebling its really important to bend the digitizer cable with a spudger inside the case. If you just press the Front down the cable will be between adhensive and case. So near the home button, it won't fit very well!!
itf7o - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 3
전체 시간: 6,543
