주요 콘텐츠로 건너뛰기
iPad Mini 6 USB-C Port Replacement
필요한 것
  1. iPad Mini 6 USB-C Port Replacement, Apply tape to a cracked screen: 1 단계, 이미지 1/3 iPad Mini 6 USB-C Port Replacement, Apply tape to a cracked screen: 1 단계, 이미지 2/3 iPad Mini 6 USB-C Port Replacement, Apply tape to a cracked screen: 1 단계, 이미지 3/3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. iPad Mini 6 USB-C Port Replacement, Heat the bottom edge: 2 단계, 이미지 1/1
    • Completely power off your device before you begin.
    • Apply a heated iOpener to the bottom edge of the device for 90 seconds to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  3. iPad Mini 6 USB-C Port Replacement, Screen removal information: 3 단계, 이미지 1/3 iPad Mini 6 USB-C Port Replacement, Screen removal information: 3 단계, 이미지 2/3 iPad Mini 6 USB-C Port Replacement, Screen removal information: 3 단계, 이미지 3/3
    • While you're waiting for the adhesive to loosen, note the following:
    • The areas at the top and bottom of the screen are sensitive to prying.
    • Don't insert a pick more than 3 mm to avoid damaging the screen.
    • There's a long circuit board attached to the screen that sits parallel to the left edge.
    • Don't insert a pick more than 1.5 mm to avoid damaging the circuit board.
    • The first two images are mirrored for demonstration purposes.
  4. iPad Mini 6 USB-C Port Replacement, Insert an opening pick: 4 단계, 이미지 1/3 iPad Mini 6 USB-C Port Replacement, Insert an opening pick: 4 단계, 이미지 2/3 iPad Mini 6 USB-C Port Replacement, Insert an opening pick: 4 단계, 이미지 3/3
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    • Don't insert the pick more than 1.5 mm to avoid damaging the circuit board.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  5. iPad Mini 6 USB-C Port Replacement, Separate the bottom adhesive: 5 단계, 이미지 1/3 iPad Mini 6 USB-C Port Replacement, Separate the bottom adhesive: 5 단계, 이미지 2/3 iPad Mini 6 USB-C Port Replacement, Separate the bottom adhesive: 5 단계, 이미지 3/3
    • Slide the pick along the bottom edge of the device towards the bottom-right corner.
    • Leave the pick in to prevent the adhesive from resealing.
  6. iPad Mini 6 USB-C Port Replacement, Heat the right edge: 6 단계, 이미지 1/1
    • Apply a heated iOpener to the right edge of the device for 90 seconds to loosen the adhesive underneath.
  7. iPad Mini 6 USB-C Port Replacement, Separate the bottom-right corner adhesive: 7 단계, 이미지 1/3 iPad Mini 6 USB-C Port Replacement, Separate the bottom-right corner adhesive: 7 단계, 이미지 2/3 iPad Mini 6 USB-C Port Replacement, Separate the bottom-right corner adhesive: 7 단계, 이미지 3/3
    • Rotate the opening pick around the bottom-right corner of the device.
  8. iPad Mini 6 USB-C Port Replacement, Separate the remaining adhesive: 8 단계, 이미지 1/2 iPad Mini 6 USB-C Port Replacement, Separate the remaining adhesive: 8 단계, 이미지 2/2
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
    • When you slice near the front camera, don't insert the pick more than 1.5 mm to avoid damaging or smearing the camera.
  9. iPad Mini 6 USB-C Port Replacement, Reposition the screen: 9 단계, 이미지 1/3 iPad Mini 6 USB-C Port Replacement, Reposition the screen: 9 단계, 이미지 2/3 iPad Mini 6 USB-C Port Replacement, Reposition the screen: 9 단계, 이미지 3/3
    • If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
    • Don't try to remove the screen all the way yet; it's still connected to the frame by a flex cable.
    • With the bottom of the device facing you, pull the right edge of the screen up and towards the left edge of the device.
    • Rest the screen upside down and parallel to the frame before continuing.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
  10. iPad Mini 6 USB-C Port Replacement, Unfasten the display cable bracket: 10 단계, 이미지 1/2 iPad Mini 6 USB-C Port Replacement, Unfasten the display cable bracket: 10 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove the five 1.2 mm-long screws securing the frame bracket to the frame.
  11. iPad Mini 6 USB-C Port Replacement, Remove the display cable bracket: 11 단계, 이미지 1/2 iPad Mini 6 USB-C Port Replacement, Remove the display cable bracket: 11 단계, 이미지 2/2
    • Use tweezers, or your fingers, to remove the display cable bracket from the frame.
  12. iPad Mini 6 USB-C Port Replacement, Disconnect the display: 12 단계, 이미지 1/3 iPad Mini 6 USB-C Port Replacement, Disconnect the display: 12 단계, 이미지 2/3 iPad Mini 6 USB-C Port Replacement, Disconnect the display: 12 단계, 이미지 3/3
    • Use the flat end of a spudger to pry up and disconnect the display cable's two press connectors secured to the frame.
  13. iPad Mini 6 USB-C Port Replacement, Remove the screen: 13 단계, 이미지 1/2 iPad Mini 6 USB-C Port Replacement, Remove the screen: 13 단계, 이미지 2/2
    • Remove the screen from the frame.
  14. iPad Mini 6 USB-C Port Replacement, Disconnect the battery: 14 단계, 이미지 1/2 iPad Mini 6 USB-C Port Replacement, Disconnect the battery: 14 단계, 이미지 2/2
    • The the flat end of a spudger to pry up and disconnect the battery's press connector secured to the frame.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  15. iPad Mini 6 USB-C Port Replacement, Disconnect the USB-C port: 15 단계, 이미지 1/2 iPad Mini 6 USB-C Port Replacement, Disconnect the USB-C port: 15 단계, 이미지 2/2
    • Use the flat end of a spudger to pry up and disconnect the USB-C port's press connector secured to the frame.
  16. iPad Mini 6 USB-C Port Replacement, Separate the USB-C port's adhesive: 16 단계, 이미지 1/3 iPad Mini 6 USB-C Port Replacement, Separate the USB-C port's adhesive: 16 단계, 이미지 2/3 iPad Mini 6 USB-C Port Replacement, Separate the USB-C port's adhesive: 16 단계, 이미지 3/3
    • The bottom of the USB-C port's flex cable is lightly adhered to the frame.
    • Insert an opening pick between the frame and the bottom of the flex cable.
    • Slice the adhesive while prying with the pick to separate the cable from the frame.
  17. iPad Mini 6 USB-C Port Replacement, Unfasten the USB-C port: 17 단계, 이미지 1/2 iPad Mini 6 USB-C Port Replacement, Unfasten the USB-C port: 17 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove the two 1.7 mm screws securing the USB-C port to its bracket.
    • These screws are positioned perpendicular to the frame, so getting at them with a screwdriver may be difficult; use plenty of downward force to avoid stripping them.
  18. iPad Mini 6 USB-C Port Replacement, Remove the USB-C port: 18 단계, 이미지 1/2 iPad Mini 6 USB-C Port Replacement, Remove the USB-C port: 18 단계, 이미지 2/2
    • Use your fingers to remove the USB-C port from the frame.
결론
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad mini 6 Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
75,135 평판
안내서 360개 작성하였습니다
iFixit iFixit 회원
Community
141 회원들
안내서 17,707개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 30
30일 전: 140
전체 시간: 1,428
