필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Handling it by the tab, place the heated iOpener on the side of the iPad to the left of the home button assembly.
Let the iOpener sit for about five minutes to soften the adhesive beneath the glass.
Carefully place a suction cup halfway up the heated side.
Be sure the cup is completely flat on the screen to get a tight seal.
While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
While holding the glass up with the suction cup, slide the point of an opening pick into the gap between the glass and body of the iPad.
Pull the suction cup's plastic nub to release the vacuum seal and remove the suction cup from the display assembly.
Reheat and reapply the iOpener.
Let it rest for a few minutes to reheat the left edge of the iPad.
Place a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
Continue moving the opening pick down the side of the display to release the adhesive.
If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
Take the first pick you inserted and slide it up toward the top corner of the iPad.
If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
Slide the opening pick around the top left corner of the iPad to separate the adhesive.
Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
Pull the pick out slightly, and slide the very tip gently along the top of the front-facing camera section of the top edge.
Leave the opening pick in the iPad slightly past the front-facing camera.
Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
Reheat the iOpener and place it on the remaining long side of the iPad—along the volume and lock buttons.
Slide the top right opening pick around the corner to fully release the top edge of the glass.
Leave this pick in place to keep the adhesive from re-sealing itself, and grab a new pick for the next step.
Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
Continue to slide the pick down the right edge of the iPad, releasing the adhesive.
Leave the opening picks in place and reheat the iOpener.
Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
Antennas
Home button cavity
Digitizer cable
The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
With a new pick, slice gently over the left-hand antenna, stopping before the home button.
Leave the pick in place before moving on.
Insert the tip of one last pick next to the previous step's pick, and slide it beneath the home button.
Insert the pick slightly deeper and work it back toward the home button.
At the top of the iPad opposite the home button, you should have a pick lodged into each corner. Twist the picks to lift the glass slightly, separating the last of the adhesive along all four edges.
Lift slowly and gently to further detach the adhesive along the lower edge.
Once all of the adhesive has been separated, open the front glass like a page in a book and rest it on your workspace.
The front-facing camera housing may stick to the front panel; peel up the housing and place it back over the camera to protect it.
Rock the camera housing up on one edge to free it from the adhesive and remove it from the front panel.
Return the front-facing camera housing to its recess in the rear case.
Use tweezers to peel up and remove the rectangular piece of foam tape covering the top right LCD screw.
Remove the triangular tape covering the lower right LCD screw.
If the tape is present, use the flat end of a spudger to pry the tape up and away, exposing the LCD screw beneath.
Remove the four 3.9 mm Phillips #000 screws securing the LCD to the rear case.
Use a pair of tweezers to peel up the small piece of tape connecting the LCD frame to the right speaker.
Use a pair of thin tweezers to pull up the top of the foam tape surrounding the LCD.
Use the tweezers to peel the foam tape up to expose the top of the LCD.
Insert the tip of a spudger between the LCD frame and the tape on the top of the LCD.
Slide the spudger along the space between the LCD frame and tape, separating the tape from the LCD frame.
Insert a guitar pick into the gap between the LCD and rear case, near the top of the left side of the LCD.
Bend the pick slightly away from the iPad, just enough to spread the gap between the LCD and rear case.
Insert the guitar pick into three more locations down the left side of the LCD and bend it over in each location, to slide the LCD over to the right side of the rear case.
Now switch to the right side of the LCD, and pry with the guitar pick in several places along the side to shift the LCD back to the left.
Insert the flat end of a spudger between the LCD frame and the metal backing plate.
Starting at the top right of the device, slide the spudger in between the LCD frame and metal backing plate, which will separate the adhesive as you push.
Repeat the previous procedure along the top of the LCD.
Insert the flat end of the spudger between the LCD frame and metal backing plate and gently push the spudger in across the top of the device, separating adhesive.
Continue with the left side of the LCD: insert the flat end of the spudger between the LCD and shield plate and insert the spudger as far as it will go.
Lift the LCD up a couple inches from the rear case to ensure it's free from the adhesive.
While holding the LCD with one hand, Insert the flat end of a spudger into the gap between this tape and the left speaker.
Gently pull the LCD away from the speakers while rotating the spudger outward to separate the tape from the speaker.
Insert the flat end of the spudger into the gap between the right speaker and the LCD tape.
While pulling the LCD away from the speakers, rotate the spudger outward, widening the gap and releasing the tape from the speaker.
Remove the following screws securing the LCD shield plate to the rear case of the iPad:
Two 2.6 mm Phillips #00
Thirteen 1.7 mm Phillips #00
One additional 1.7 mm Phillips #00 on some devices.
Insert the flat end of a spudger underneath the center of the LCD shield plate from the bottom end of the iPad.
Pry up on the spudger to free the plate from the sides of the rear case.
Remove the three 1.3 mm Phillips #00 screws securing the connector shield to the logic board.
Use a pair of tweezers to grasp and remove the connector shield from the iPad.
Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
Use a plastic opening tool to pry the LCD connector from its socket on the logic board.
While holding the LCD with one hand, insert the flat end of a spudger between the LCD and tape on the iPad's right side.
Slide the spudger outward, separating the tape, while gently lifting up on the LCD to pull it away from the tape.
While still holding the LCD up with one hand, move on to the iPad's left side and repeat the previous step's procedure to separate the second piece of tape.
Insert the flat end of a spudger between the LCD frame and tape, and slide outward while gently lifting up on the LCD.
To minimize stress on the socket, try prying under the short edge of the connector, rather than the long edge which is shown in these images.
Gently pry the digitizer connector up from its socket on the logic board.
Reheat the iOpener in the microwave for one minute.
Place the heated iOpener on the back of the iPad, along the center. Let it sit there for 90 seconds to soften the battery adhesive.
Move the iOpener to the right of the back of the iPad (the side opposite the rear-facing camera), and let the iOpener sit for another 90 seconds.
If the iOpener cools significantly between sittings, reheat it for another minute.
Flip the iPad back over and insert a plastic card between the top left battery and the rear case.
Press the card in further, breaking as much of the adhesive holding in the battery as you can.
Remove the plastic card and reinsert it underneath the top right corner of the battery.
Again, press the card in further, to break more of the adhesive behind the battery.
Leave this card in place to prevent the adhesive from resetting.
Insert a second plastic card beneath the bottom left corner of the battery.
Slowly push the card in further, breaking more of the adhesive between the battery and the rear case.
Remove the card and reinsert it, beneath the bottom right corner of the battery.
Grasp both cards and slowly pull the right side of the battery up about two inches from the rear case.
Peel slowly and try to keep the battery as straight as possible.
While lifting the right side of the battery up with one hand, use a plastic card to cut any adhesive still holding the battery down to the rear case.
다른 58명이 해당 안내서를 완성하였습니다.
7 Comments
What a great guide! Using this, I was able to disassemble my iPad Mini and replace the batter for around $30. I used a heat gun (carefully, 10 seconds at a time) instead of the microwaveable sock thingy. Everything went perfectly, just like in the pictures and instructions. Thanks again!
For the re-assembly, do we need to apply fresh adhesive to keep the digitizer from coming loose?
pfaulconer - 답글
It is a !&&* of work, but it works at least from being capable to do it and it went relativerly smoothly. But!!! Even if for sure I didn’t break anything, the iPad doesn’t work at all. It looks to me as for sure nothing went wrong during the change and repair process, that simply the new battery is broken, or is there any trick to get it running like in other cases were a battery activation process is required? I’m really disappointed after all this work and being so careful with each step during the process!!!
Thanks for this tutorial. What else could I use for heating a tablet? This is the most questionable part I think. Anything else is a quite usual and simple at least for me.
