주요 콘텐츠로 건너뛰기
iPad Mini Wi-Fi Front Panel Assembly Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. iPad Mini Wi-Fi Front Panel Assembly Replacement, Front Panel: 1 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement, Front Panel: 1 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement, Front Panel: 1 단계, 이미지 3/3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    In case of broken glass, here are some hints:
    - I prefer 3M "3350" tape; a metalized polypropylene tape with an acrylic adhesive. It's a very thin, silvery HVAC tape, not your standard duct tape.
    - Test your tape to make sure it sticks really well to the glass.
    - Use isopropyl alcohol on a paper towel to remove fingerprints and other dirt to help the tape stick to the screen.
    - Use the widest tape you can find, and apply it evenly, without trapping bubbles, without crinkles: This greatly improves your chance of success with the suction cup later.
    - Cut tape pieces long enough and go over the (rounded) edge; afterwards carefully run a scalpel alongside the edge (between bezel and glass) to trim off any excess.
    - Don't overlap edges of the tape: butt-join them instead.
    - If needed: repeat in other direction.
    - If needed: Cut square piece of tape (size of suction cup) and place it where you want to lift the glass, so that the suction cup doesn't cover any butt-joins.
    Good luck, you brave person!
    volty - 답글
    This is the second broken screen I’ve fixed. Overlapped package tape carefully stuck to the glass and trimmed to the edges will contain most of the shards. I found that a hair dryer works for softening the glue. After getting under an edge with the suction cup I carefully followed the opening sequence using a combination of plastic picks and a single edge razor blade to get under the small pieces. It was slow going with lots of reheating with the dryer (about 45 minutes), but the taped glass came off without glass everywhere.
    Bill Roughen - 답글
  2. iPad Mini Wi-Fi Front Panel Assembly Replacement: 2 단계, 이미지 1/1
    • Handling it by the tab, place the heated iOpener on the side of the iPad to the left of the home button assembly.
    • Let the iOpener sit for about five minutes to soften the adhesive beneath the glass.
    I worked at it for over 2 hours before deciding to microwave the opener for 45 seconds at a time. That seemed to do the trick.
    jaromhyde - 답글
  3. iPad Mini Wi-Fi Front Panel Assembly Replacement: 3 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 3 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 3 단계, 이미지 3/3
    • Carefully place a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
    • Be careful to only lift the glass enough to insert an opening pick—any more and you may risk cracking the glass.
    This step is totally pointless if you have a shattered screen. The suction cup is rendered useless. Any tips on what to do if you can't get any suction due to a shattered screen?
    robloomis - 답글
    just pick out the glass shards if it is cracked that bad you are better off scrapping the digitizer
    echow2001 -
    for shattered screens I cover the screen with tape. I find packing tape works best for me.
    George - 답글
  4. iPad Mini Wi-Fi Front Panel Assembly Replacement: 4 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 4 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 4 단계, 이미지 3/3
    • While holding the glass up with the suction cup, slide the point of an opening pick into the gap between the glass and body of the iPad.
    • Don't insert the opening pick any deeper than the black bezel on the side of the display. Inserting the pick too far may damage the LCD.
    • Pull the suction cup's plastic nub to release the vacuum seal and remove the suction cup from the display assembly.
    you have to pull up on the suction cup harder than you might be comfortable with!
    jfaulks1 - 답글
    thanks jfaulks1 (I did not copy and paste lol)
    iliketrains kid - 답글
  5. iPad Mini Wi-Fi Front Panel Assembly Replacement: 5 단계, 이미지 1/1
    • Reheat and reapply the iOpener.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
    • Let it rest for a few minutes to reheat the left edge of the iPad.
  6. iPad Mini Wi-Fi Front Panel Assembly Replacement: 6 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 6 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 6 단계, 이미지 3/3
    • Place a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
    • Throughout the rest of the procedure, if you encounter significant resistance to sliding picks beneath the glass, stop and reheat the section you're working on. Forcing the picks risks cracking the glass.
  7. iPad Mini Wi-Fi Front Panel Assembly Replacement: 7 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 7 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 7 단계, 이미지 3/3
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  8. iPad Mini Wi-Fi Front Panel Assembly Replacement: 8 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 8 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 8 단계, 이미지 3/3
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
    • If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
  9. iPad Mini Wi-Fi Front Panel Assembly Replacement: 9 단계, 이미지 1/1
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
    I left my iOpener on the bezel the entire time I slid picks in. worked great
    jfaulks1 - 답글
  10. iPad Mini Wi-Fi Front Panel Assembly Replacement: 10 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 10 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 10 단계, 이미지 3/3
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
    Gezz this is though! Cracked the glass while replacing it.
    Padraic Hoselton - 답글
    :( sad (rip glass lol)
  11. iPad Mini Wi-Fi Front Panel Assembly Replacement: 11 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 11 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 11 단계, 이미지 3/3
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • The third image shows where the front-facing camera and housing are in the iPad.
    • Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
  12. iPad Mini Wi-Fi Front Panel Assembly Replacement: 12 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 12 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 12 단계, 이미지 3/3
    • Pull the pick out slightly, and slide the very tip gently along the top of the front-facing camera section of the top edge.
  13. iPad Mini Wi-Fi Front Panel Assembly Replacement: 13 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 13 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 13 단계, 이미지 3/3
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
    • Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
  14. iPad Mini Wi-Fi Front Panel Assembly Replacement: 14 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 14 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 14 단계, 이미지 3/3
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
    Shattered my screen pretty bad here, making it so that whenever I continued to move the pick the glass separated and I couldn’t continue moving it. Be VERY gentle moving the pick; almost no force is required.
    Jasper Holden - 답글
  15. iPad Mini Wi-Fi Front Panel Assembly Replacement: 15 단계, 이미지 1/1
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining long side of the iPad—along the volume and lock buttons.
  16. iPad Mini Wi-Fi Front Panel Assembly Replacement: 16 단계, 이미지 1/2 iPad Mini Wi-Fi Front Panel Assembly Replacement: 16 단계, 이미지 2/2
    • Slide the top right opening pick around the corner to fully release the top edge of the glass.
    • Leave this pick in place to keep the adhesive from re-sealing itself, and grab a new pick for the next step.
  17. iPad Mini Wi-Fi Front Panel Assembly Replacement: 17 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 17 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 17 단계, 이미지 3/3
    • Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
  18. iPad Mini Wi-Fi Front Panel Assembly Replacement: 18 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 18 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 18 단계, 이미지 3/3
    • Continue to slide the pick down the right edge of the iPad, releasing the adhesive.
  19. iPad Mini Wi-Fi Front Panel Assembly Replacement: 19 단계, 이미지 1/1
    • Leave the opening picks in place and reheat the iOpener.
    • Remember not to overheat the iOpener—no more than once every ten minutes.
    • Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
  20. iPad Mini Wi-Fi Front Panel Assembly Replacement: 20 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 20 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 20 단계, 이미지 3/3
    • Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
    • Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
    • There are quite a few things to avoid beneath the lower bezel, so study the third image closely:
    • Antennas
    • Home button cavity
    • Digitizer cable
    • The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
  21. iPad Mini Wi-Fi Front Panel Assembly Replacement: 21 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 21 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 21 단계, 이미지 3/3
    • Leave the pick from the last step in place to prevent the adhesive from re-sealing.
    • With a new pick, slice gently over the left-hand antenna, stopping before the home button.
    • Only slide the pick from the outer edge toward the center of the iPad. Do not move the pick back toward the outer edge, as moving in this direction may damage the antenna.
    • If you need to slide the pick over the lower section more than once, remove it and re-insert at the outer edge, and slide inwards.
    • Leave the pick in place before moving on.
  22. iPad Mini Wi-Fi Front Panel Assembly Replacement: 22 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 22 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 22 단계, 이미지 3/3
    • Insert the tip of one last pick next to the previous step's pick, and slide it beneath the home button.
    • Stop about an inch from the right-hand side to avoid cutting the digitizer cable.
    • Insert the pick slightly deeper and work it back toward the home button.
    • Again, be sure to only slide the pick toward the center of the iPad when it is fully inserted; otherwise you may damage the antenna beneath the glass.
  23. iPad Mini Wi-Fi Front Panel Assembly Replacement: 23 단계, 이미지 1/1
    • Reheat and reapply the iOpener to the top bezel of the iPad.
  24. iPad Mini Wi-Fi Front Panel Assembly Replacement: 24 단계, 이미지 1/2 iPad Mini Wi-Fi Front Panel Assembly Replacement: 24 단계, 이미지 2/2
    • Be very careful with this step. Take your time and ensure the adhesive is hot and soft, and that you've been through all of the adhesive with an opening pick. Don't be afraid to stop and reheat.
    • At the top of the iPad opposite the home button, you should have a pick lodged into each corner. Twist the picks to lift the glass slightly, separating the last of the adhesive along all four edges.
    • If you encounter a significant amount of resistance, stop twisting. Leave the picks in place, reheat, and reapply the iOpener to the problem areas, and run a pick through the sticking point one more time.
  25. iPad Mini Wi-Fi Front Panel Assembly Replacement: 25 단계, 이미지 1/2 iPad Mini Wi-Fi Front Panel Assembly Replacement: 25 단계, 이미지 2/2
    • Lift slowly and gently to further detach the adhesive along the lower edge.
    Really, add a few more pics and a few more picks, see how long and difficult you can make this guide. 26 steps to get the top screen off is ridiculous.
    B. A. Computer Services - 답글
  26. iPad Mini Wi-Fi Front Panel Assembly Replacement: 26 단계, 이미지 1/2 iPad Mini Wi-Fi Front Panel Assembly Replacement: 26 단계, 이미지 2/2
    • Once all of the adhesive has been separated, open the front glass like a page in a book and rest it on your workspace.
    • If reusing the front panel assembly during reassembly, you will need to replace the display adhesive. Use our display adhesive application guide to reapply your display adhesive and reseal your device.
    I recommend wearing latex gloves or be sure not to put too many finger prints on the front or back of this front glass when lifting it or completing the remainder of the steps. I made this mistake and upon installing the new LCD and putting the iPad back together I realized that I left a few finger prints on the inside of the front glass. After re-securing the adhesive strips putting the iPad back together there are now unremovable fingerprints visible when the LCD is turned off. Just a recommendation on the gloves or be sure to wipe both sides of the front glass clean before putting all back together.
    Christian Screen - 답글
  27. iPad Mini Wi-Fi Front Panel Assembly Replacement: 27 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 27 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 27 단계, 이미지 3/3
    • The front-facing camera housing may stick to the front panel; peel up the housing and place it back over the camera to protect it.
    • Rock the camera housing up on one edge to free it from the adhesive and remove it from the front panel.
    • Return the front-facing camera housing to its recess in the rear case.
    this didn’t happen to me BUT the glue was still sticking to the top of the glass because one pick had gone OVER the glue and the other under, so I had to pull the glue off and cut it with scissors
    jfaulks1 - 답글
    OK this was glue, it was the tape from step 35!
    jfaulks1 - 답글
  28. iPad Mini Wi-Fi Front Panel Assembly Replacement, LCD Assembly: 28 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement, LCD Assembly: 28 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement, LCD Assembly: 28 단계, 이미지 3/3
    • Small pieces of foam tape cover the top and bottom right-hand screws securing the LCD to the rear case.
    • Use tweezers to peel up and remove the rectangular piece of foam tape covering the top right LCD screw.
    • Remove the triangular tape covering the lower right LCD screw.
  29. iPad Mini Wi-Fi Front Panel Assembly Replacement: 29 단계, 이미지 1/2 iPad Mini Wi-Fi Front Panel Assembly Replacement: 29 단계, 이미지 2/2
    • The top left LCD screw may be covered by adhesive tape from the front panel.
    • If the tape is present, use the flat end of a spudger to pry the tape up and away, exposing the LCD screw beneath.
  30. iPad Mini Wi-Fi Front Panel Assembly Replacement: 30 단계, 이미지 1/1
    • Remove the four 3.9 mm Phillips #000 screws securing the LCD to the rear case.
    In my case the 4 screws are not the same. One is 4mm, and 3 of 3.5mm, or better 2 x 3.5mm and one 3.45mm. I put the longest one at the left edge at left of the LCD flat cable.
    mitja
    Mitja Jankovic - 답글
    Hi Mitja. I just checked the measurements with an electronic digital caliper. I got 3.9 mm for all four screws. Are you sure it was the same model? Thanks.
    Walter Galan -
    The top left screw is longer than the other 3 - iPad mini Retina Wi-Fi.
    sandro - 답글
    On mine the top right screw is longer
    oliver - 답글
    top right is longer on an ipad mini 2 retina wifi 32GB
    sagert - 답글
    ipad mini wifi no screws are longer
  31. iPad Mini Wi-Fi Front Panel Assembly Replacement: 31 단계, 이미지 1/2 iPad Mini Wi-Fi Front Panel Assembly Replacement: 31 단계, 이미지 2/2
    • Use a pair of tweezers to peel up the small piece of tape connecting the LCD frame to the right speaker.
    I wonder what does this sticker stands for…
    K8L - 답글
  32. iPad Mini Wi-Fi Front Panel Assembly Replacement: 32 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 32 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 32 단계, 이미지 3/3
    • A thin strip of foam tape on the LCD frame is covering a piece of tape connecting the LCD to the panel beneath it. To proceed, you'll have to break and peel up some of the foam tape to expose the tape hidden beneath.
    • Use a pair of thin tweezers to pull up the top of the foam tape surrounding the LCD.
    • Be careful not to touch the LCD with the tweezers, as you may damage the display.
    • Use the tweezers to peel the foam tape up to expose the top of the LCD.
  33. iPad Mini Wi-Fi Front Panel Assembly Replacement: 33 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 33 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 33 단계, 이미지 3/3
    • Insert the tip of a spudger between the LCD frame and the tape on the top of the LCD.
    • Slide the spudger along the space between the LCD frame and tape, separating the tape from the LCD frame.
    I finished a successful replacement of my screen following these instructions. Thanks.
    Step 36 (remove tape from LCD perimeter), however, seems unnecessary. I ended up spending a lot of time separating the tape from the LCD frame only to discover it was not necessary for steps 37-44 and actually made things really difficult for step 45-46 (removing the tape near the speakers). Finally, steps 45-46 can be skipped since it is much easier to remove this tape once you flip the LCD over (Step 55).
    Kenneth Snyder - 답글
  34. iPad Mini Wi-Fi Front Panel Assembly Replacement: 34 단계, 이미지 1/2 iPad Mini Wi-Fi Front Panel Assembly Replacement: 34 단계, 이미지 2/2
    • The LCD is glued to the metal LCD shield plate behind it along the top, left, and right edges. In order to safely loosen this adhesive, you'll be using a guitar pick to shift the LCD a couple of millimeters left and right several times.
    • Insert a guitar pick into the gap between the LCD and rear case, near the top of the left side of the LCD.
    • Bend the pick slightly away from the iPad, just enough to spread the gap between the LCD and rear case.
    I found a very simple method for removing the LCD from the metal shield. Slightly lift one of the top corners and insert a 1' piece of fishing line. Insert the line under the other top corner placing the length between the LCD and shield. Once in place, gently pull each end toward the bottom of the LCD breaking the adhesive as you go. This will make things much easier than using the picks and possibly breaking the LCD.
    bababooey - 답글
    The fishing line trick is amazing… although i had already broken the LCD when i saw that comment. Good Learn!
    Brandon Lukasik - 답글
    This step is what destroys my LCDs :(
    Dan Harris - 답글
    Just destroyed my LCD as well. A red warning remarking is missing here! The LCD assembly is very fragile an cannot be bent, even slightly!!
    brauliox - 답글
    I have broken about 10 of the 50 or so iPad minis that I have repaired. I always try to have a LCD on hand. I’ll have to try the fishing line trick!
    northstar - 답글
    I also recommend doing step 45 first (removing the two pieces of foam tape at the bottom).
    northstar - 답글
    I was able to do this the first time w/out damaging the LCD simply by following the instructions to the letter, slowly and carefully. The only thing I did differently was to follow Northstar’s instructions to remove the two pieces of tape at the bottom of the LCD before beginning.
    Jenny Lawson - 답글
    I found a good way to remove the LCD without breaking it. Once you finish to clean up around the LCD just lift a bit one of the white metal backing plate and insert in the gap a plastified playing card under le LCD and slowly make your way to the center of the LCD. Repeat on the other side and the LCD will lift up intact.
    lemerise - 답글
    nothing Brocken after
    (I did not read the comments before doing it lol)
  35. iPad Mini Wi-Fi Front Panel Assembly Replacement: 35 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 35 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 35 단계, 이미지 3/3
    • Insert the guitar pick into three more locations down the left side of the LCD and bend it over in each location, to slide the LCD over to the right side of the rear case.
  36. iPad Mini Wi-Fi Front Panel Assembly Replacement: 36 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 36 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 36 단계, 이미지 3/3
    • Now switch to the right side of the LCD, and pry with the guitar pick in several places along the side to shift the LCD back to the left.
    • Repeat this and the previous step a few times, until the LCD is easily moved left and right.
  37. iPad Mini Wi-Fi Front Panel Assembly Replacement: 37 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 37 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 37 단계, 이미지 3/3
    • In the next few steps, you'll be sliding a spudger between the LCD and the metal backing plate to fully separate the LCD from the adhesive beneath.
    • Insert the flat end of a spudger between the LCD frame and the metal backing plate.
    • Be sure to get the spudger between the LCD frame and backing plate, and not beneath the plate. Prying up on the plate will damage it, because it is screwed down to the rear case beneath the LCD.
  38. iPad Mini Wi-Fi Front Panel Assembly Replacement: 38 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 38 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 38 단계, 이미지 3/3
    • Starting at the top right of the device, slide the spudger in between the LCD frame and metal backing plate, which will separate the adhesive as you push.
    • The goal is to separate the adhesive, not to pry the LCD up, so keep the pointed tip of the spudger as low as possible to prevent bending the LCD.
    • If inserting the spudger causes the corner of the LCD to bend up, repeat the steps with the guitar pick to further loosen the adhesive.
    These steps were hard. I was too scared that I was going to brake the LCD. Luckily I got it off! Don’t know how delicate these things are and how much force they can take.
  39. iPad Mini Wi-Fi Front Panel Assembly Replacement: 39 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 39 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 39 단계, 이미지 3/3
    • Repeat the previous procedure along the top of the LCD.
    • Insert the flat end of the spudger between the LCD frame and metal backing plate and gently push the spudger in across the top of the device, separating adhesive.
  40. iPad Mini Wi-Fi Front Panel Assembly Replacement: 40 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 40 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 40 단계, 이미지 3/3
    • Continue with the left side of the LCD: insert the flat end of the spudger between the LCD and shield plate and insert the spudger as far as it will go.
    • At this point the LCD should be loosened from the adhesive holding it. If it is not, re-insert the spudger on the right side or top to fully free the LCD.
  41. iPad Mini Wi-Fi Front Panel Assembly Replacement: 41 단계, 이미지 1/1
    • Lift the LCD up a couple inches from the rear case to ensure it's free from the adhesive.
    When I did it I found that the adhesive sticking was mainly on the edges, so if you take a spudger and just break that adhesive carefully it will help. Be gentle lifting the lcd as it’s very breakable.
    Jasper Holden - 답글
  42. iPad Mini Wi-Fi Front Panel Assembly Replacement: 42 단계, 이미지 1/2 iPad Mini Wi-Fi Front Panel Assembly Replacement: 42 단계, 이미지 2/2
    • Two wide strips of tape connect the LCD to the speakers.
    • While holding the LCD with one hand, Insert the flat end of a spudger into the gap between this tape and the left speaker.
    • Gently pull the LCD away from the speakers while rotating the spudger outward to separate the tape from the speaker.
    I recommend removing these two pieces of foam tape prior to loosening and lifting the LCD.
    northstar - 답글
  43. iPad Mini Wi-Fi Front Panel Assembly Replacement: 43 단계, 이미지 1/2 iPad Mini Wi-Fi Front Panel Assembly Replacement: 43 단계, 이미지 2/2
    • Insert the flat end of the spudger into the gap between the right speaker and the LCD tape.
    • While pulling the LCD away from the speakers, rotate the spudger outward, widening the gap and releasing the tape from the speaker.
  44. iPad Mini Wi-Fi Front Panel Assembly Replacement: 44 단계, 이미지 1/2 iPad Mini Wi-Fi Front Panel Assembly Replacement: 44 단계, 이미지 2/2
    • Flip the LCD over and rest it on top of the front panel glass.
    • Do not attempt to remove the LCD from the iPad, as it is still connected by its data cable.
  45. iPad Mini Wi-Fi Front Panel Assembly Replacement, LCD Shield Plate: 45 단계, 이미지 1/1
    • Remove the following screws securing the LCD shield plate to the rear case of the iPad:
    • Two 2.6 mm Phillips #00
    • Thirteen 1.7 mm Phillips #00
    • One additional 1.7 mm Phillips #00 on some devices.
    At the iPad mini retina Wi-Fi there are only 7 screws.
    sandro - 답글
    On my iPad Mini (Gen 1 WiFi; A1432), these are not #00 screws, but #000 screws. They're much tinier than the first four screws that held the LCD tabs in place. The #00 driver sorta works, but requires a lot of force to get traction. The #000 driver works like a charm, though.
    volty - 답글
    On my 1432 there were mixed in 4 tiny #000 screws holding the shield plate aong the right side. Looks like these can be mixed in without consequence as they are shorter anyway
    gfriedman99 - 답글
    I have a missing plate and screws
    Keah Smith - 답글
  46. iPad Mini Wi-Fi Front Panel Assembly Replacement: 46 단계, 이미지 1/2 iPad Mini Wi-Fi Front Panel Assembly Replacement: 46 단계, 이미지 2/2
    • Insert the flat end of a spudger underneath the center of the LCD shield plate from the bottom end of the iPad.
    • Pry up on the spudger to free the plate from the sides of the rear case.
  47. iPad Mini Wi-Fi Front Panel Assembly Replacement: 47 단계, 이미지 1/1
    • Remove the LCD shield plate from the iPad.
    theres a lip on the rear case that prevents you from lifting this straight out, be careful to not bend the plate.
    jfaulks1 - 답글
    Once the LCD is clear of the shield, wiggle a long plastic spudger up the center between the shield and the battery to gently bend the shield. That will help in getting it away from the sides and make it easier to come out.
    Bill Shannon - 답글
  48. iPad Mini Wi-Fi Front Panel Assembly Replacement, Battery Connector: 48 단계, 이미지 1/1
    • Remove the three 1.3 mm Phillips #00 screws securing the connector shield to the logic board.
    • Be sure to not substitute these three screws with any other screws, specifically the screws securing the LCD shield plate to the rear case of the iPad. Any slightly longer screws may strip the screw holes and result in irreparable damage to the logic board.
    Note: These three screws are smaller than the rest of the screws holding the larger LCD shield although they look similar. If you substitute the larger screws, you will pop a screw bracket which can damage the board on both the mini original and mini 2 retina. I just wrote a blog post about how this happens: http://mendonipadrehab.com/entries/gener...
    jessabethany - 답글
    Hi jessabethany. Thank you for the warning. I read your blog post and found it to be very informative. Thanks for adding the warning to the step. It will most definitely help others avoid any damage to the logic board. Thanks!
    Walter Galan -
    Be careful: At iPad mini retina Wi-Fi there are thw short and one longer screw! Don't mix them!
    sandro - 답글
  49. iPad Mini Wi-Fi Front Panel Assembly Replacement: 49 단계, 이미지 1/1
    • Use a pair of tweezers to grasp and remove the connector shield from the iPad.
  50. iPad Mini Wi-Fi Front Panel Assembly Replacement: 50 단계, 이미지 1/2 iPad Mini Wi-Fi Front Panel Assembly Replacement: 50 단계, 이미지 2/2
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector and not on the socket itself. If you pry up on the logic board socket, you may break the connector entirely.
    Make sure you disconnect the battery. If not and ipad is still on you can have problems with the LCD backlight. To fix that problem you have to solder
    Mattis - 답글
    I may be experiencing the backlight problem you mentioned. What connection needs to be soldered?
    Grillwrecka -
    Have an issue - heard that if you don't disconnect the battery a fuse is blown. I need help to fix the blown fuse.
    Andrew Kivell -
    There is an extensive thread in Answers about iPad mini backlight problems.Th screen stays black after a digitizer replacement.
    jessabethany -
    After unplugging the battery place a guitar pick in-between the two connections.
    While continuing to work on the iPad you may inadvertently cause the two connections to touch.
    Michael Vovaris - 답글
    Yeah, you need to put the pick in between the connections so the battery doesn't touch the logic board connector and blow a fuse and make your backlight not turn on. You really don't want to have to solder the 2 connections together, especially if you don't know how, like me! I will use your comment's advice when working.
    WolfyHD - 답글
    I put a piece of cellotape on the contact side of the connector and could happily forget about it while getting on with the rest of the repair.
    Rory Filer - 답글
  51. iPad Mini Wi-Fi Front Panel Assembly Replacement, LCD: 51 단계, 이미지 1/2 iPad Mini Wi-Fi Front Panel Assembly Replacement, LCD: 51 단계, 이미지 2/2
    • Use a plastic opening tool to pry the LCD connector from its socket on the logic board.
    • Do not pry against the large IC next to the connector, or you may break it. Gently pry from the side of the connector as shown.
    Putting the iPad back together: While plugging the LCD Connector back in, take your time finding the socket on the logic board. Do no use pressure until you are certain it is seated properly. Trust me, if you take your time you will know its seated correctly.
    Does it shares the same shape/size of the LCD connector between the ipad mini wifi only WHITE and the other one ipad mini 32gb BLACK?
    muhammadbukhari10 - 답글
  52. iPad Mini Wi-Fi Front Panel Assembly Replacement: 52 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 52 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 52 단계, 이미지 3/3
    • The LCD is still connected to the rest of the iPad by two wide strips of adhesive tape that run up from the inside of the rear case to the front bottom LCD frame.
    • While holding the LCD with one hand, insert the flat end of a spudger between the LCD and tape on the iPad's right side.
    • Slide the spudger outward, separating the tape, while gently lifting up on the LCD to pull it away from the tape.
    • It may help to twist the spudger, to spread the gap the rest of the way and separate the LCD from the tape.
    Removing this tape and such to take the LCD off completely is unneccessary when replacing just the glass and digitizer, the digitizer cable is easily removed without further work to the LCD
    Dave Davidson - 답글
    When this tape damage, how we can take a new?
    Muhammed Kilic - 답글
    When this tape are damage, how we can order and take a new one?
    Muhammed Kilic - 답글
    Following from Nick H’s comment about LCD removal being unnecessary - I tried that first and got my broken glass OUT of the assembly by threading it thru a limited space beneath the LCD. Later when trying to reseat the digitizer connector I gave up and removed the LCD anyhow. Not that much extra work but a LOT easier to install the digitizer and reseat the connector without having to navigate around the LCD and its cable. Removal of the tape holding the LCD was easy - there are two short lengths of rubber or foam along the bottom edge of the LCD that faces the outside world. Remove those(save them) and then _carefully_ peel up the tape; I saw some metallic looking residue underneath. Later when re-assembling everything, I put the tape back and then those two short lengths of foam.
    Rory Filer - 답글
    on mine this tape was already loose.
    jfaulks1 - 답글
  53. iPad Mini Wi-Fi Front Panel Assembly Replacement: 53 단계, 이미지 1/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 53 단계, 이미지 2/3 iPad Mini Wi-Fi Front Panel Assembly Replacement: 53 단계, 이미지 3/3
    • While still holding the LCD up with one hand, move on to the iPad's left side and repeat the previous step's procedure to separate the second piece of tape.
    • Insert the flat end of a spudger between the LCD frame and tape, and slide outward while gently lifting up on the LCD.
  54. iPad Mini Wi-Fi Front Panel Assembly Replacement: 54 단계, 이미지 1/2 iPad Mini Wi-Fi Front Panel Assembly Replacement: 54 단계, 이미지 2/2
    • Lift and remove the LCD from the iPad Mini.
  55. iPad Mini Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: 55 단계, 이미지 1/2 iPad Mini Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: 55 단계, 이미지 2/2
    • Be very careful to pry evenly on the digitizer connector, and not on the socket at all. The socket and connector are very delicate and if you damage either, your digitizer won't work.
    • To minimize stress on the socket, try prying under the short edge of the connector, rather than the long edge which is shown in these images.
    • Gently pry the digitizer connector up from its socket on the logic board.
  56. iPad Mini Wi-Fi Front Panel Assembly Replacement: 56 단계, 이미지 1/2 iPad Mini Wi-Fi Front Panel Assembly Replacement: 56 단계, 이미지 2/2
    • Gently pry the digitizer cable board up from the rear case.
    Be careful not to dislodge any of the surface mount components next to the connectors. This is sometimes a reason for the digitiser not working.
    Simon - 답글
    There is adhesive holding it down, so it may take some time to get it off. It helped me to push with my spudger on the piece with the yellow text instead from the same side.
    Jasper Holden - 답글
    I put the iOpener under the iPad to weaken the adhesive for this step.
    Nathan Lloyd - 답글
  57. iPad Mini Wi-Fi Front Panel Assembly Replacement: 57 단계, 이미지 1/2 iPad Mini Wi-Fi Front Panel Assembly Replacement: 57 단계, 이미지 2/2
    • Lift and remove the front panel from the iPad.
    == After step 55 ==
    Before installing your new digitizer (front panel), make sure to put the necessary bends on the new digitizer's ribbon cable. Look at the old panel that you've removed to see the bends that you'll need to make. Without doing this, once you are at the last step of laying down the digitizer, the cable may bunch-up in between the glass and the iPad's aluminum frame. Thus, it will not allow that corner to sit flush and glue down. If you didn't make the bends, you can use the tweezers at that point to situate the cable. It is just easier to do this beforehand. Do not make the bends as if you were folding paper. You run the risk of damaging the ribbon by doing so. You just want enough pressure to make the cable retain a bend. Again, look at and copy the cable from your old panel.
    Good Luck!!!!
    Mike - 답글
    If your panel is shattered, you may want to have some canned air to get rid of all those pesky little glass pieces that fly everywhere. I used a Giottos air blaster because that is all I had at my disposal.
    Mike -
    might be better to use a vacuum for safety reasons. you really dont want glass shards all over the place
    gfriedman99 - 답글
    If your case corners are damaged from being dropped, seal across the corners with wide packing tape, then grind them out carefully with a small motor tool. Use a corner piece from the broken screen (adhesive side upwards) as the template. Keep removing aluminium until screen piece above fits snug and flat. Remove all traces of metal filings before reassembly.
    Jennifer Fordyce - 답글
    Good tip! Most times the corners are damaged.
    northstar -
결론
다른 32명이 해당 안내서를 완성하였습니다.
Andrew Optimus Goldheart
회원 가입일: 10/17/09
502,810 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 3개
25 steps of advertising the bag full of rice, seriously?
Dave - 답글
Isn't it popcorn? =) It smells like popcorn
marcoac14 -
i say you have too many steps.
and youre missing some too.
i'd put that bad boy in the dehydro for 30 mins and the lcd and glass come out like butta.
spudger on the top and the lcd comes off like nothing!
60C
30mins
remember to also cover all the contacts on the new digi so you don't short it.
if you're wondering which, theyre on the bottom, look at the OEM glass and look at the replacment, see the gold that isn't covered?
cover it, as well as transfer the magnets over to the new glass.
presto!
you win!
Cheers guys hope i helped!
Jojo Melara - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 21,878
