주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
iPad Mini Wi-Fi Logic Board Assembly Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. iPad Mini Wi-Fi Logic Board Assembly Replacement, Logic Board Assembly: 1 단계, 이미지 1/2 iPad Mini Wi-Fi Logic Board Assembly Replacement, Logic Board Assembly: 1 단계, 이미지 2/2
    • Use tweezers to peel up and remove the small piece of tape covering the front-facing camera cable connector.
  2. iPad Mini Wi-Fi Logic Board Assembly Replacement: 2 단계, 이미지 1/2 iPad Mini Wi-Fi Logic Board Assembly Replacement: 2 단계, 이미지 2/2
    • The front-facing camera cable connector is secured with pieces of tape that wrap up around the sides of the cable and are fastened to two small metal plates.
    • Use a plastic opening tool to gently pry the lower metal plate up from the front-facing camera cable connector.
    • Being careful not to break the plate or the tape attached to it, pry it up and fold it away from the front-facing camera cable connector.
  3. iPad Mini Wi-Fi Logic Board Assembly Replacement: 3 단계, 이미지 1/2 iPad Mini Wi-Fi Logic Board Assembly Replacement: 3 단계, 이미지 2/2
    • Gently pry the second (upper) metal plate up from the front-facing camera cable connector.
    • Again, carefully pry the plate up and away from the front-facing camera cable connector.
  4. iPad Mini Wi-Fi Logic Board Assembly Replacement: 4 단계, 이미지 1/2 iPad Mini Wi-Fi Logic Board Assembly Replacement: 4 단계, 이미지 2/2
    • Use a plastic opening tool to pry the front-facing camera cable's connector up from its socket on the logic board.
  5. iPad Mini Wi-Fi Logic Board Assembly Replacement: 5 단계, 이미지 1/2 iPad Mini Wi-Fi Logic Board Assembly Replacement: 5 단계, 이미지 2/2
    • Gently fold the front-facing camera cable up and out of the way of the logic board.
  6. iPad Mini Wi-Fi Logic Board Assembly Replacement: 6 단계, 이미지 1/2 iPad Mini Wi-Fi Logic Board Assembly Replacement: 6 단계, 이미지 2/2
    • Use tweezers to peel up and remove the small piece of tape covering the headphone jack cable connector.
  7. iPad Mini Wi-Fi Logic Board Assembly Replacement: 7 단계, 이미지 1/2 iPad Mini Wi-Fi Logic Board Assembly Replacement: 7 단계, 이미지 2/2
    • Use a plastic opening tool to gently pry the lower metal plate up from the headphone jack cable connector.
    • Being careful not to break the plate or the tape attached to it, pry it up and fold it away from the headphone jack cable connector.
  8. iPad Mini Wi-Fi Logic Board Assembly Replacement: 8 단계, 이미지 1/2 iPad Mini Wi-Fi Logic Board Assembly Replacement: 8 단계, 이미지 2/2
    • Pry the second (upper) metal plate up from the front-facing camera cable connector.
    • Again, carefully pry the plate up and away from the headphone jack cable connector.
  9. iPad Mini Wi-Fi Logic Board Assembly Replacement: 9 단계, 이미지 1/2 iPad Mini Wi-Fi Logic Board Assembly Replacement: 9 단계, 이미지 2/2
    • Use a plastic opening tool to pry the headphone jack cable's connector up out of its socket on the logic board.
    • Gently bend the headphone jack cable back, away from the logic board.
  10. iPad Mini Wi-Fi Logic Board Assembly Replacement: 10 단계, 이미지 1/2 iPad Mini Wi-Fi Logic Board Assembly Replacement: 10 단계, 이미지 2/2
    • Use a plastic opening tool to pry the rear-facing camera cable up from its socket on the logic board.
  11. iPad Mini Wi-Fi Logic Board Assembly Replacement: 11 단계, 이미지 1/2 iPad Mini Wi-Fi Logic Board Assembly Replacement: 11 단계, 이미지 2/2
    • Use tweezers to peel up and remove the small piece of tape covering the button ribbon cable ZIF connector.
  12. iPad Mini Wi-Fi Logic Board Assembly Replacement: 12 단계, 이미지 1/2 iPad Mini Wi-Fi Logic Board Assembly Replacement: 12 단계, 이미지 2/2
    • Use the tip of a spudger to lift up the tab on the button ribbon cable ZIF connector.
  13. iPad Mini Wi-Fi Logic Board Assembly Replacement: 13 단계, 이미지 1/2 iPad Mini Wi-Fi Logic Board Assembly Replacement: 13 단계, 이미지 2/2
    • Use tweezers to pull the button ribbon cable straight out of its ZIF socket on the logic board.
  14. iPad Mini Wi-Fi Logic Board Assembly Replacement: 14 단계, 이미지 1/3 iPad Mini Wi-Fi Logic Board Assembly Replacement: 14 단계, 이미지 2/3 iPad Mini Wi-Fi Logic Board Assembly Replacement: 14 단계, 이미지 3/3
    • Gently peel back the wide piece of tape covering the top of the right speaker.
  15. iPad Mini Wi-Fi Logic Board Assembly Replacement: 15 단계, 이미지 1/3 iPad Mini Wi-Fi Logic Board Assembly Replacement: 15 단계, 이미지 2/3 iPad Mini Wi-Fi Logic Board Assembly Replacement: 15 단계, 이미지 3/3
    • Continue peeling the tape, and remove it from the iPad.
  16. iPad Mini Wi-Fi Logic Board Assembly Replacement: 16 단계, 이미지 1/3 iPad Mini Wi-Fi Logic Board Assembly Replacement: 16 단계, 이미지 2/3 iPad Mini Wi-Fi Logic Board Assembly Replacement: 16 단계, 이미지 3/3
    • Use the flat end of a spudger to disconnect the two bottom antenna cable connectors from their sockets on the logic board.
  17. iPad Mini Wi-Fi Logic Board Assembly Replacement: 17 단계, 이미지 1/2 iPad Mini Wi-Fi Logic Board Assembly Replacement: 17 단계, 이미지 2/2
    • Use the tip of a spudger to peel back the small piece of tape covering both antenna cables on the bottom right side of the iPad.
    • Leave the lower part of the tape stuck to the back of the rear case to aid in reassembly.
  18. iPad Mini Wi-Fi Logic Board Assembly Replacement: 18 단계, 이미지 1/2 iPad Mini Wi-Fi Logic Board Assembly Replacement: 18 단계, 이미지 2/2
    • With the tip of a spudger, peel up the larger piece of tape covering both antenna cables near the bottom of the rear case.
    • Do not try to remove this piece of tape; it is wrapped around the top antenna cable.
  19. iPad Mini Wi-Fi Logic Board Assembly Replacement: 19 단계, 이미지 1/3 iPad Mini Wi-Fi Logic Board Assembly Replacement: 19 단계, 이미지 2/3 iPad Mini Wi-Fi Logic Board Assembly Replacement: 19 단계, 이미지 3/3
    • Use the tip of a spudger to pry the small metal retaining clip off the left antenna cable, then de-route the cable from the clip.
  20. iPad Mini Wi-Fi Logic Board Assembly Replacement: 20 단계, 이미지 1/2 iPad Mini Wi-Fi Logic Board Assembly Replacement: 20 단계, 이미지 2/2
    • De-route the antenna cable from the corner of the iPad.
  21. iPad Mini Wi-Fi Logic Board Assembly Replacement: 21 단계, 이미지 1/2 iPad Mini Wi-Fi Logic Board Assembly Replacement: 21 단계, 이미지 2/2
    • Use the tip of a spudger to remove the small piece of tape securing the antenna cable in the bottom right corner of the iPad.
  22. iPad Mini Wi-Fi Logic Board Assembly Replacement: 22 단계, 이미지 1/1
    • Peel the cable back from the corner of the iPad.
  23. iPad Mini Wi-Fi Logic Board Assembly Replacement: 23 단계, 이미지 1/3 iPad Mini Wi-Fi Logic Board Assembly Replacement: 23 단계, 이미지 2/3 iPad Mini Wi-Fi Logic Board Assembly Replacement: 23 단계, 이미지 3/3
    • Use the tip of a spudger to pry the antenna cable tape up from the rear case of the iPad.
    • Gently pull the antenna cable out of the way as you work along the piece of tape, to keep it from resealing.
  24. iPad Mini Wi-Fi Logic Board Assembly Replacement: 24 단계, 이미지 1/2 iPad Mini Wi-Fi Logic Board Assembly Replacement: 24 단계, 이미지 2/2
    • Pull the antenna cable from the slot behind the Lightning connector.
결론
Andrew Optimus Goldheart
회원 가입일: 10/17/09
502,656 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,718개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 45
