주요 콘텐츠로 건너뛰기
iPad Pro 12.9" 2nd gen Screen Replacement
필요한 것
    • Follow this video guide from start to finish and enjoy!
결론
Did you follow all the steps? Yes! Then enjoy!
다른 15명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Fix It Planet
회원 가입일: 05/29/15
1,603 평판
안내서 3개를 작성함
5가이드 댓글
Kann man beim 12.9 Gen2 NUR das Glas tauschen? Das display geht 1a aber ich habe mehrere risse auf dem schutzglas. Möchte nicht dafür auch das display tauschen…..
sim sem - 답글
@simsem I'm wondering the same thing. Did you find out if it was possible ? Is the glass reparable without changing the whole screen itself ?
Shldnet -
If you get the replacement screen with daughterboard attached you don’t need to solder anything.
Gregg Stanley - 답글
That is correct …. but if you solder it on yourself you reuse the original daughter board instead of throwing it away and save some money to boot. Seems reasonable if you can do it.
Fix It Planet -
I replaced the screen but it the touch screen is randomly unresponsive at times. Mostly on the middle right of the screen. I would have to touch same area couple of times for it to response. The unit is on the latest iOS 15.1. Any thoughts?
Chio Phanh - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 21
지난 30일: 116
전체 시간: 44,483
