주요 콘텐츠로 건너뛰기
필요한 것
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. iPad Pro 12.9" 4th Gen 수리는 저희 서비스 설명서를 사용하십시오.
    최종 결론
    • The USB-C port is modular and can be independently replaced.
    • The lack of a physical home button eliminates a common failure point and may simplify repairs.
    • The battery is secured with both easier-to-remove stretch-release tabs and conventional, non-removable adhesive.
    • The LCD and front panel glass are fused together—simplifying the opening procedure, but increasing the cost of repair.
    • Gobs of adhesive hold most everything in place, making all repairs more difficult.
    수리 용이성 점수
    3
    수리 용이성 10점 중 3점
    (10은 가장 쉬운 수리를 뜻합니다)
Taylor Dixon
회원 가입일: 06/26/18
67,033 평판
안내서 94개 작성하였습니다
댓글 8개
Who manufactures the LiDAR hardware?
Shaun O'Flaherty - 답글
Looks like a ToF not real LiDAR. Apple marketing spin again
i.thanh -
https://tof-insights.com/time-of-flight-... Goes into details on pros and cons of a ToF versus LiDAR - and it appears there are many reasons why it makes sense to do a TOF LiDAR versus a full system when we are talking about a mobile device. Marketing spin, I hardly think so. It’s achieving the same functionality with many benefits on the device end.
Andrew C. A. -
When are you going to get a look at the IC’s in this?
Sean Davis - 답글
it actually is a lidar and not a time of flight camera
cool tech with mick - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 42
30일 전: 197
전체 시간: 52,263
