소개
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Follow this guide to detach the right antenna cable from the frame on an iPad Pro 9.7".
필요한 것
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
이 단계에 사용된 도구:Anti-Clamp$24.95
Elevate the iPad enough for the Anti-Clamp's arms to rest above and below the screen.
Pull the blue handle towards the hinge to disengage opening mode.
Position the suction cups near the top edge of the iPad—one on the front, and one on the back.
Push down on the cups to apply suction to the desired area.
Push the blue handle away from the hinge to engage opening mode.
Turn the handle clockwise until you see the cups start to stretch.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
Use picks to ensure most of the adhesive has been cut through on the top, left, and bottom sides.
Twist the top and bottom picks to separate the display assembly from the rear case.
Use a Phillips screwdriver to remove the eleven 1.3 mm screws securing the EMI shield.
Slide the battery blocker underneath the left side of the logic board's battery connector at a 35 degree angle.
Leave the battery blocker in place as you work.
Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the logic board to the left and right of the battery connection.
Wait one minute for the isopropyl alcohol to weaken the adhesive under the logic board.
Try to insert the battery blocker. If the logic board doesn't easily lift up, apply a few more drops of isopropyl alcohol.
Use a Phillips screwdriver to remove the three 1.3 mm Phillips screws securing the display cable bracket.
Use the flat end of the spudger to disconnect the display assembly connector from the motherboard socket.
Use the flat end of a spudger to disconnect the right antenna's coaxial connector from its socket.
Use the flat end of a spudger to disconnect the left antenna's coaxial connector from its socket.
Use the flat end of a spudger to lift the bundled left and right antenna cables away from the frame.
Use a pair of tweezers to remove the adhesive that was securing the bundled antenna cables to the frame.
Use a pair of tweezers to peel up the sticker bundling the left and right antenna cables together.
Use a pair of tweezers to lift up the small sticker near the lower right speaker securing the right antenna to the frame.
Use the pointed end of a spudger to detach the foam spacer adhered to the second right antenna sticker.
Use a pair of tweezers to detach the large right antenna sticker between the logic board and the antenna.
