소개
Entering DFU Mode (Official Instructions)
1. Plug your device into your computer.
2. Turn off the device.
3. Hold the Power button for 3 seconds.
4. Hold the Home button without releasing the Power button for 10 seconds.
5. Release the Power Button but keep holding the Home button.
6. Keep holding the Home button until you are alerted by iTunes saying that it has detected a device in Recovery Mode
Make sure the device screen is blank and no logos are present. Same operation you can use for all other models of iPhone.
동영상 개요
ATTENTION, ATTENTION !!! You will lose all your data. Be sure that you have backup.
Open iTunes.
Enter the phone in DFU mode and connect it to the PC.
iTunes has detected an iPhone in recovery mode.
Follow the instructions and restore the iPhone.
That’s all!
That’s all!
다른 146명이 해당 안내서를 완성하였습니다.
댓글 19개
How fix Iphone 6 error 9
error 48 quien me puede ayudar
Pendant le mode récupération de l'iphone en mode dfu le téléphone se rallume seule et interrompre le téléchargement, même quand vous recommencez ça fais la même chose
Exactement j'ai le même problème et cela ne permet de faire une mise à jour
are we need a rom for iphone? u know. like the other device
Im Getting Error 40.. cant install update after restoring
Chris Neet - 답글
Omg, it just spoiled my phone
My phone it’s turning on
I’ve followed the procedures to flash, restore, update etc my iPhone 6s. It starts the process but then gives an error message saying couldn’t download or restore iPhone. Even if I try do a complete restore, it starts and gets to the 4gig download but I get a notification saying it couldn’t complete the process. Please help.
You can also follow the steps given in this tutorial to fix iphone 5s in dfu mode
dfu iphone 5s reset https://devicereset.online/2021/02/01/df...
Comment tu vas
Fonctionne bien!! Merci!
This doesn't help if you don't know the original Apple ID of the phone. You still need that or you can't get past the step where this video ends.
iTunes stuck on "Waiting for iPhone". it is a 6s, DFU mode has been recognized by iTunes. how to identify faulty component so i can movon to repair.
Bonsoir aidé moi svp j'arrive pas mettre mon iPhone se en mode récupération
Zoulkifoul Imorou - 답글
