주요 콘텐츠로 건너뛰기
iPhone 11 Lightning Connector Assembly Replacement
필요한 것
동영상 지침
결론
다른 56명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Arty
회원 가입일: 10/27/19
31,189 평판
안내서 108개를 작성함
21가이드 댓글
I would rather have a picture and written step by step, he doesn’t say some parts what is called
Dulce Vidal - 답글
Me too. I would appreciate knowing the size and type of all screws and standoffs and where they go.
I most likely mixed up a few of them and now the screen stays black.
Kim Mace -
First, DISCONNECT the battery before ANY connections, and the battery should be the last thing you re-connect. And you DO NOT need to remove the logic board.
Gregg Stanley - 답글
Just completed this repair. Wow it’s tricky but as echoed above, I would try and disconnect battery first although design of the iPhone 11 makes it very difficult to do this. Also, definitely don’t remove logic board and you don’t have to remove the battery either. Removing battery possibly makes it very slightly easier but if you take your time it’s not necessary. Good luck
richarddillon - 답글
IS not there a problem with at chip on the charging flex, that causes warnings and or re-boots I have been reading about somewhere?I mean, fitting it is easy enough, but APPPPle keeps annoying customers trying to stop them going to independent shops or doing repairs themselves!
JoeBlog - 답글
댓글 쓰기
조회 통계:
지난 24시간: 74
지난 7일: 420
지난 30일: 1,744
전체 시간: 83,510
