주요 콘텐츠로 건너뛰기
iPhone 11 Pro Back Glass Replacement
동영상 개요
  1. iPhone 11 Pro  Back Glass Replacement, Choose The Right Laser Drawing: 1 단계, 이미지 1개 중 1개
    • Place the iPhone 11 Pro back glass under the probe for focusing. Then place the iPhone 11 Pro back glass on the operating panel.
    • Choose ‘iPhone 11 Pro’ from the model list and click ‘Load’ to load the drawing.
  2. iPhone 11 Pro  Back Glass Replacement, Scan The Back Glass With Laser: 2 단계, 이미지 1개 중 1개
    • Adjust the laser light scanning area on the back glass.
    • Once finished, get the parameter set and click ‘Mark’ to scan the back glass with the laser light.
  3. iPhone 11 Pro  Back Glass Replacement, Scan The Glass Around The Triple-lens Camera With Laser: 3 단계, 이미지 1개 중 1개
    • The laser light scanning didn’t work well with the triple-lens camera area here.
    • After several attempts and experiments, REWA LAB successfully completed a specialized drawing for the triple-lens camera area.
    • Scan the triple-lens camera area again with the laser with the help of the drawing.
  4. iPhone 11 Pro  Back Glass Replacement, Separate The Back Glass From The Mid-frame: 4 단계, 이미지 1개 중 1개
    • The scanned back glass can be separated easily. However, the glass around the triple-lens camera needs further operation.
    • Our commonly used tools failed to remove the glass here, so we used a glass cutter, a grinding tool, a Sculpture Knife and a Cutting Nipper to remove the glass around the triple-lens camera.
    • Once completed, remove residual black adhesive with the Laser Machine.
  5. iPhone 11 Pro  Back Glass Replacement, Big Hole Back Glass: 5 단계, 이미지 1개 중 1개
    • The camera holder ring of iPhone 11 series is harder and comes with thick inside walls, adding to the difficulty of polishing. Meanwhile, the camera lens can also be easily damaged during polishing.
    • So we highly recommend replacement back glass with a big camera hole for iPhone 11 series back glass repair.
결론
Due to the special arrangement of the three cameras of iPhone 11 Pro, the space between the three cameras is also narrow, adding to the difficulty of back glass separating. Therefore, the Laser Machine may be the safest and most efficient solution for iPhone 11 Pro back glass repair.
다른 12명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Phryne
회원 가입일: 11/17/19
21,441 평판
안내서 18개를 작성함
1가이드 댓글
Et un fois réparer ça tiens 3 mois vue que le châssis et quasiment toujours plier suite au choc ou la vitre arrière est pas coller et ceux séparé avec le temps…
niko rad - 답글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 39
지난 30일: 151
전체 시간: 102,594
