주요 콘텐츠로 건너뛰기
iPhone 11 Pro Rear Case Replacement
필요한 것
동영상 개요
  1. iPhone 11 Pro Rear Case Replacement, Remove the pentalobe screws: 1 단계, 이미지 2개 중 1개 iPhone 11 Pro Rear Case Replacement, Remove the pentalobe screws: 1 단계, 이미지 2개 중 2개
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
결론
다른 17명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Arty
회원 가입일: 10/27/19
30,969 평판
안내서 108개를 작성함
3가이드 댓글
how much for housing iphone 11 pro ? Thank you
daddy - 답글
If yo buy it from indonesia it only cost you arround $100-$200
izaz adityas -
I ordered a new charging port but it doesn’t seem to include a speaker element on the left side, and the charging connector module above the port. Can those be moved over from the old charging port?
lemonlev - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 47
지난 30일: 258
전체 시간: 21,775
