주요 콘텐츠로 건너뛰기
해당 분해도는 수리 안내서가 아닙니다. iPhone 13 Pro 수리는 저희 서비스 설명서를 사용하십시오.
  1. iPhone 13 Pro Full Chip ID, iPhone 13 Pro Full Chip ID: 1 단계, 이미지 1/1
    • Logic board, side 1:
    • Apple APL1W07 A15 Bionic SoC layered with what's most likely 6 GB of SK Hynix LPDDR4X SDRAM
    • Apple APL1098 power management IC
    • Apple 338S00762-A1 power management IC
    • STMicroelectronics STB601A05 power management IC
    • Apple 338S00770-B0 power management IC
    • Texas Instruments TPS65657B0 display power management IC
    • NXP Semiconductor CBTL1616A0 display port multiplexer
  2. iPhone 13 Pro Full Chip ID: 2 단계, 이미지 1/1
    • Logic board, side 1 (cont.):
    • Texas Instruments CD3710A1 VCSEL array driver
    • Texas Instruments USB 2.0 dual repeater
    • ON Semiconductor DC-DC converter
    • Possibly a NXP Semiconductor power management IC
    • Possibly a NXP Semiconductor load switch
  3. iPhone 13 Pro Full Chip ID: 3 단계, 이미지 1/1
    • Apple/USI U1 ultra-wideband chip
    • Skyworks SKY58271-19 front-end module
    • Skyworks SKY58276-17 front-end module
    • Likely a Broadcom AFEM-8225 front-end module
    • Likely a Skyworks SKY59723 power amplifier module
    • Likely a Murata 141 RF switch module
    • Likely Broadcom filters
  4. iPhone 13 Pro Full Chip ID: 4 단계, 이미지 1/1
    • Alps HSCDTD00xA electronic compass
  5. iPhone 13 Pro Full Chip ID: 5 단계, 이미지 1/1
    • Logic board, sides 2 and 3:
    • 128 GB of Kioxia NAND flash memory
    • STMicroelectronics ST33Jxxx secure microcontroller w/ eSIM
    • Possibly an Apple/Cirrus Logic 338S00817 audio processor
    • Apple/Cirrus Logic 338S00739 audio codec
    • Apple/Cirrus Logic 338S00537 audio amplifier
    • Broadcom BCM59365 wireless power receiver
    • Likely an Analog Devices haptic driver
  6. iPhone 13 Pro Full Chip ID: 6 단계, 이미지 1/1
    • Logic board, sides 2 and 3 (cont.):
    • Qualcomm PMX60 power management IC
    • Apple 338S00616 power management IC
    • Texas Instruments LM3567A1 LED flash driver
    • Likely a STMicroelectronics DC-DC converter
    • Nexperia 74AVC1T45 3-state voltage level translator/transceiver
    • Nexperia LSF0101 1-bit bidirectional voltage level translator
  7. iPhone 13 Pro Full Chip ID: 7 단계, 이미지 1/1
    • USI 339S00761 WiFi/Bluetooth module
    • Qualcomm SDX60M 5G modem
    • Possibly a Qualcomm SDR868 5G RF transceiver
    • Broadcom AFEM-8215 front-end module
    • Possibly a Skyworks SKY53838-17 front-end module
    • NXP Semiconductor SN210V NFC controller with secure element
    • Likely a Skyworks SKY57217 power amplifier module
  8. iPhone 13 Pro Full Chip ID: 8 단계, 이미지 1/1
    • Qualcomm QET510 envelope tracker
    • Qualcomm QET5100 envelope tracker
    • Likely a Qorvo envelope tracker
    • Likely a Skyworks SKY514xx RF switch module
    • Likely Skyworks RF switch
    • Likely Murata antenna switch module
    • Antenna tuning switch
  9. iPhone 13 Pro Full Chip ID: 9 단계, 이미지 1/1
    • Bosch Sensortec 6-axis accelerometer/gyroscope
Craig Lloyd
회원 가입일: 02/10/16
36,293 평판
안내서 82개 작성하였습니다
댓글 7개
Which one is the wifi/bt chip?
u2f u2f - 답글
Refer to Step 7,
There is no WiFi/BT chip on the main board. Instead, Apple uses USI 339S00761 WiFi/Bluetooth module .
JJ Wu -
Is barometer still Bosch’s solution?
JJ Wu - 답글
Does anyone know anything more about the USI 339S00761 WiFi/Bluetooth module? Specifically, it would be really interesting to understand if there is Bluetooth LE Audio capabilities hidden there.
Gustaf Rosell - 답글
please i need a help my iphone 13 pro i try to restore and gave me error unable to restore idevice (-1)
izeko mobile - 답글
댓글 쓰기
조회 통계:
24 시간 전: 23
7일 전: 182
30일 전: 845
전체 시간: 47,332
