주요 콘텐츠로 건너뛰기
iPhone 16 Pro LiDAR Sensor Removal
단지 전제 조건
이 가이드는 전제 조건 전용 가이드입니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
필요한 것
  1. iPhone 16 Pro LiDAR Sensor Removal, Prepare the phone for disassembly: 1 단계, 이미지 2개 중 1개 iPhone 16 Pro LiDAR Sensor Removal, Prepare the phone for disassembly: 1 단계, 이미지 2개 중 2개
    • Allow the phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from the phone.
    • Hold the power and either volume buttons and slide to power off the phone.
  2. iPhone 16 Pro LiDAR Sensor Removal, Tape over any cracks: 2 단계, 이미지 2개 중 1개 iPhone 16 Pro LiDAR Sensor Removal, Tape over any cracks: 2 단계, 이미지 2개 중 2개
    • If the screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Pro LiDAR Sensor Removal, Mark your opening picks: 3 단계, 이미지 3개 중 1개 iPhone 16 Pro LiDAR Sensor Removal, Mark your opening picks: 3 단계, 이미지 3개 중 2개 iPhone 16 Pro LiDAR Sensor Removal, Mark your opening picks: 3 단계, 이미지 3개 중 3개
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 16 Pro LiDAR Sensor Removal, Remove the pentalobe screws: 4 단계, 이미지 2개 중 1개 iPhone 16 Pro LiDAR Sensor Removal, Remove the pentalobe screws: 4 단계, 이미지 2개 중 2개
    • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
  5. iPhone 16 Pro LiDAR Sensor Removal, Disconnect the LiDAR sensor: 5 단계, 이미지 3개 중 1개 iPhone 16 Pro LiDAR Sensor Removal, Disconnect the LiDAR sensor: 5 단계, 이미지 3개 중 2개 iPhone 16 Pro LiDAR Sensor Removal, Disconnect the LiDAR sensor: 5 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry up and disconnect the LiDAR sensor press connector.
  6. iPhone 16 Pro LiDAR Sensor Removal, Remove the LiDAR Sensor: 6 단계, 이미지 2개 중 1개 iPhone 16 Pro LiDAR Sensor Removal, Remove the LiDAR Sensor: 6 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the two screws securing the LiDAR sensor:
    • One 1.7 mm‑long screw
    • One 3.0 mm‑long screw
  7. iPhone 16 Pro LiDAR Sensor Removal: 7 단계, 이미지 2개 중 1개 iPhone 16 Pro LiDAR Sensor Removal: 7 단계, 이미지 2개 중 2개
    • Use your fingers or tweezers to lift and remove the LiDAR sensor.
결론
To reassemble your iPhone, follow these instructions in reverse order.
After your repair, calibrate a genuine replacement LiDAR sensor using Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers community for help.
작성자
1다른 기여자 명과 함께
Nick Schultz
회원 가입일: 03/24/24
37,572 평판
안내서 226개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,764개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 8
전체 시간: 124
