이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Insert a SIM card eject tool or paper clip into the hole next to the headphone jack.
Press down on the paper clip until the SIM card tray pops out.
Insert a metal spudger into the slot between the dock connector and the antenna cover. Gently pry up near the two tabs to create a small gap between the antenna cover and the silver front bezel.
Insert an iPod opening tool in the gap between the antenna cover and the front bezel. The wedge of the tool should be pointing towards the antenna cover. Slide the tool around the corner and up until you reach the metal backing.
Repeat the same procedure on the other side of the dock connector.
Grasp the antenna cover on either side and slide it up and away from the iPhone. This requires some force. If it does not come free, ensure that the antenna cover is lifted up enough to free the catches.
Remove the three Phillips #00 screws securing the rear panel to the iPhone.
The small square hole is the location to insert the dental pick in the next step.
Start removing the rear panel on the side with the buttons.
Slide the dental pick completely into the square hole. You may need to wiggle the tool and apply a good amount of force to get it to go all the way.
Pry up the rear panel by pulling the dental pick counterclockwise in a quick motion. Apply force perpendicular to the plane of the display assembly. You may be afraid to go fast, but going slowly is more likely to bend the case.
Use a spudger to free the rear panel from the iPhone along the corner and top.
Repeat the same procedure on the other side of the iPhone. Slide the dental pick completely into the square hole. You may need to wiggle the tool and apply a good amount of force to get it to go all the way.
Pry up the rear panel by pulling the dental pick clockwise in a quick motion. Apply force perpendicular to the plane of the display assembly. You may be afraid to go fast, but going slowly is more likely to bend the case.
The rear panel is still attached to the iPhone by the headphone jack cable, so don't entirely remove the rear panel from the iPhone just yet.
Use a spudger to disconnect the headphone jack cable from the logic board.
Peel up the orange tape securing the white antenna cable to the side of the iPhone.
Use a spudger to disconnect the two antenna cables from the communications board. Apple used a small dab of glue on these connections, which may make removing the antenna connections harder.
Remove the following 3 screws:
One Phillips #00 screw securing the logic board to the iPhone near the camera.
Two Phillips #00 screws, one on either corner of the logic board.
Use a spudger to disconnect the camera connector.
Lift the camera out of the iPhone.
Working from the edge opposite the battery connectors, insert a spudger between the battery and the plastic frame and pry up on the battery. It is attached to the casing with an adhesive, but should slowly come free.
Slide a spudger beneath the logic board on the side opposite the battery connector and pry up slightly. Don't lift up too far, because there are still four attached connectors on the bottom of the logic board.
In a similar manner, slide a spudger beneath the logic board where the camera was. Again, don't lift up too far yet as there are still four attached connectors on the bottom of the logic board.
Lift up the logic board slightly and slide a spudger beneath the logic board to disconnect the display ribbon cable.
After freeing the first connector, slide the spudger further towards the battery and the center of the iPhone to disconnect the speaker connector.
Go to the other side of the logic board and use a spudger to disconnect the touch sensor cable on the under side of the logic board.
Slide a spudger beneath the black locking bar and pry up to rotate the bar 90 degrees (the bar is already rotated in the picture).
Hold both the battery and the logic board assembly and slide both parts away from the orange antenna and out of the iPhone.
Remove the three Phillips #00 screws securing the front bezel to the iPhone.
Rotate the iPhone 90 degrees and remove the two Phillips #00 screws from the bottom of the iPhone.
Rotate the iPhone 90 degrees and remove the three Phillips #00 screws from the side of the iPhone.
Rotate the iPhone 90 degrees and remove the two Phillips #00 screws from the top of the iPhone.
다른 154명이 해당 안내서를 완성하였습니다.
댓글 4개
I'll second rafa74's comment: be VERY careful about putting too much stress on the TINY cable that connects the Home button to the rest of its assembly! I ripped mine as well. You have to slowly separate the Home button's plastic sub-assembly from the display module itself (with a kitchen knife, for example). Otherwise the moment you start parting the display module from the mid-board, you run the risk of tearing the Home button cable... it's far too easy.
This guide neglects to point out some very important things at the end of the removal process. For example, that the glass is glued to the phone, or which connectors have to come with the display assembly on the way out.
This is my first opening session and sounds great !!! Thanks I fix it
I swapped motherboard + battery between 2 original iPhone models, but now on one the touchscreen won’t work even if the connector is attached. The flat looks PERFECT, that’s what bothers me the most, the connector looks also greet, same goes for the “slot” on the motherboard. What is going on? I needed to literarily detach the display assembly from the mid frame, tough, to also swap the 2 displays assemblies (long story). Do the touch for some reason won’t work until I put the bezel and all the screws? Thanks
