소개
Hält dein Akku nicht mehr so lange wie früher? Ihn gegen einen Neuen auszutauschen ist ein Klacks.
동영상 개요
Falls das Displayglas gesprungen ist, halte die Bruchstücke zusammen und vermeide Verletzungen während des Reparaturvorgangs, indem du das Glas mit Tape zusammenhälst.
Lege sich überlappende Streifen von durchsichtigen Klebestreifen über das Display des iPhones, bis die gesamte Vorderseite bedeckt ist.
Entferne die zwei 3,7 mm Kreuzschlitzschrauben #00 von dem Ende des iPhones, an dem sich auch der Dockanschluss befindet.
Shesh - why doesn't the first line of step #1 say "Turn off your phone" by holding the power button down and shutting it down. I know you don't HAVE to do this, but it certain didn't feel right opening a device while the screen was humming along looking at me.
The power button is broken... that is why?
Do seriously consider ESD when getting to the internals. External connectors have ESD protection circuits, but these will not help if you touch the internals!
ok, I did it but the vibration stopped working… I don’t know why. Is there a way to fix it?
Entferne den Metallgriff vom Saugheber. Es ist einfacher und sicherer, am Saugheber direkt zu arbeiten, als mit dem Metallgriff.
Verwende einen kleinen Saugnapf in der Nähe des Home Buttons, um vorsichtig den unteren Teil der Display-Einheit anzuheben.
The small suction cup near the home button didn't quite work for me, but i found some kind of workaround: just use the suction of your iPhone-carkit (if you have one)
that works like a charm
Duck Tape also works. :)
Be really careful at this point not too pull too hard when you're trying to get the screen out - I did, the screen came out suddenly and I pulled all the connectors off :/
Tom George - 답글
put your fingers at power button end of phone, resting on edge of glass/bezel you can use them as lever so when you pull on suction at other end you don't need to apply much pressure and the cables underneath aren't ripped off
As a help to doing this step, put your thumb/fingers around the phone around the middle so it's cradled in your hand. Keep your fingers wrapped around and resting gently on the top of the screen with your thumb and the first few fingers. See how his thumb is sitting on the edge like that, but ready to 'catch' the screen when it comes up? Do that with your thumb and the tips of your fingers on the other side.
Now carefully use the suction cup to 'walk/rock' the screen out with a left-to-right while pulling up motions. With your fingers gently clamped around the phone and providing a little pressure on the edges overlapping the screen when the screen comes out, they'll catch the screen before you pull it up too far and yank the cables out.
I was very careful, but not careful enough removing the display with a suction cup, and Everything came unplugged in an instant. CAUTION: Pull with the suction cup near the round button, AND ALSO have someone else support the other end of the display so that only the end of the display with the round button comes out. I was very lucky.
I had no grip at all on the suction cup with my fingers. Problem solved by inserting the screw driver in the s-cup, which gave just the right leverage to control pulling loose the display assembly.
Klappe die Display-Einheit um ca. 45 Grad nach oben
When you get back to this step as you are reassembling it, it's tempting to test that you've got all the cables plugged in properly by switching the phone on and testing it. However the Home button will not work until the front panel is back in position, because the electrical connection is done by a pair of touch contacts which only work when the phone is assembled.
When the instructions say "Rotate the display assembly up until it is at an angle of approximately 45 degrees." they really mean "TILT THE HOME BUTTON END OF display assembly up until it is at an angle of approximately 45 degrees. Looking at the picture makes this step brain dead simple, but if you were using another iPhone to read the directions it would be easy to miss.
Halte die Display-Einheit weiter mit einer Hand fest und trenne mit dem Spudger in der anderen Hand das schwarze Flachbandkabel mit dem Label "1" (Kabel 1 ist für das Display).
What part is 1? My seems to keep dropping out and the ear speaker is not working. Is this what it is?
What are the flex cables #1, #2 and #3 for? There's a lot of questions about this, but no answers?!
SOMEONE has to know!?
Turbo Fredriksson로 부터 인용:
Aparently #3 is 'Earpiece & Proximity Sensor'.
Found the thread: What Ribbon "1" and "2" and "3" do?
1. Ribbon #1: Runs the LCD
2. Ribbon #2: Runs the digitizer
3. Ribbon #3: Earspeaker and various sensors on the iPhone face
Note that The connectors have a rubber-like Top surface. Make surre The spudger is inserted underneath that rubber piece. To disconnect, The connector ha to lifted upwards from the PC-Board (i.e. Orthogonally from the electronics board, as opposed to being moved sideways). holds true for all of those connectors, except for the one with the flip-tab.
Rotiere die Display-Einheit nach oben, bis sie in etwa vertikal steht. Dies ermöglicht einen leichteren Zugang zu den verbliebenen Kabeln, die nun getrennt werden müssen.
Trenne das schwarze Flachbandkabel, das mit einer "2" gekennzeichnet ist, mit einem Spudger. (Kabel 2 ist für das kapazitive Touch Panel).
Klappe die weiße Kunststofflasche um, die das Flachbandkabel "3" an Ort und Stelle hält. Der weiße Anschluss dreht sich um bis zu 90 Grad und das Flachbandkabel wird freigegeben.
Hole das schwarze Flachbandkabel aus seinem Anschluss und entferne die Display-Einheit vom iPhone.
On my 3G, the piece that flips up on the #3 connector was black and the connector itself was white, seemingly opposite of the pictures. I mistakenly tried to pry up the wrong piece, but fortunately didn't do too much damage before I realized this. My phone was replaced on warranty in February so this must be the case in some newer 3G's.
lolsen4로 부터 인용:
Thanks for the heads-up. I added a note so that people are aware that the colors may be reversed.
That flip tab on the #3 connector split in half and came off completely. Be careful. And if anyone knows where to buy a replacement flip tab, that'd be cool too :)
I should also note that I used a little flat head screwdriver when lifting the flip tab and the narrow pressure point is what cause it to split. Should of used a spudger.
I bought my black iPhone a full housing white cover off ebay. No phone shops seem to be able to change it for me.
If I follow this guide, will I be able to pull my phone apart, change the covers and put it back together?
That is, once I pull the phone apart, will it work properly once I put it back together again?
kristymic로 부터 인용:
Yes, if you take care and follow the instructions to the letter.
How on earth do I get the black ribbon cable back into its connector???
Cor Berkelaar로 부터 인용:
Cor, You have to slide the little bar on the connector away from the body of the connector before you can insert the ribbon cable into it. I know it's tight quarters, but even my meat hooks were able to finally get it inserted. The 'trick' is that once you have inserted the cable into the body of the connector, quickly slide the bar back toward the body as this will lock the cable into the connector. I hope this is helpful.
David
Is there a way of replacing the connector?
i have torn the top of the connector......... would that be the reason that the iPhone would not start even though the ribbon is in the connector and fastened secured with the white plastic tab is down.
I HAVE DONE IT GUYS SO THANK YOU.
Vishal Vaidya로 부터 인용:
Is there a way of replacing the connector? i have torn the top of the connector......... would that be the reason that the iPhone would not start even though the ribbon is in the connector and fastened secured with the white plastic tab is down.
You could replace it. That's what I'll have to do. Luckily my brother is great with soldering surface mounted components.
But if you had to ask if it can be replaced, you don't have knowledge to do it yourself! It's VERY difficult! Look among your friends or the 'Net. I found quite a lot of forums where they talk about the difficulty on replacing SMD's. Just mail one of them that seem to know what they're doin'...
cliffcurtis로 부터 인용:
http://www.earth2k.com/fpc-ribbon/
http://cgi.ebay.com/ws/eBayISAPI.dll?Vie...
I'm currently waiting for mine... :)
[quote|I'm currently waiting for mine... :)[/quote]
And my younger brother managed to replace it with only a couple of minutes whining about it's size :).
Works just fine now (exept that I can't seem to turn the darn thing off, even though I've also replaced the button harness!)
I have torn the top of the connector too and the iPhone is not starting.. Was that the reason? Did it work after replacing the connector?
lolsen4로 부터 인용:
Maybe it adds Value to the explanation to say that the piece that needs to be flipped up is located on the opposite side of where the ribbon cable exits the connector. It needs to flip upwards towards the ribbon cable.
My confusion was to identify which connector I have in my phone, since everything in there is so tiny that it is hard to identify which is which. Maybe a zoom-in on the connector with the tab flipped up would be a good addition to the instructions also.
Be VERY careful when working with ribbon 3. I thought I was but when I got the phone back together the earpiece didn't work. While doing research to find out why, I discovered that ribbon 3 is very delicate and easy to damage. I'm now waiting for a new one... if I can't fix it, I'll have to get a new phone since I can't see myself hearing only via Bluetooth or speakerphone.
That step also had me thinking & reading for quite a while. Maybe a close-up picture of the connector might be helpful, seems that a lot of people screw up badly here.
My American 3GS white connector did not flip open. It split into 3 little pieces of white plastic when I tried lifting it with the spudger. The plastic seemed very brittle; the phone is 4 years old. Amazingly to me, I was able to slide the flex tail back in to position and it made all the necessary electrical contacts (at least for the time being). Wi-fi cable #6 was not properly seated after first assembly, but everything is working now! Thank for the help.
Dennis Smith
I strongly recommend that you review Step 7 of the 3GS 'Display,' 'Front Panel' or 'Front Panel Assembly' guide. As of this date (June 2015), only those three guides include a photo of a mock-up of Connector 3 that will provide you with detail that will help you avoid damaging that fragile connector.
Stecke dein SIM-Auswurfwerkzeug oder eine Büroklammer in das Loch neben der Kopfhörerbuchse.
Drücke das Werkzeug hinein, bis der SIM- Karteneinschub herauskommt.
Fasse den SIM-Karteneinschub und ziehe ihn aus dem iPhone heraus.
Trenne das Flachbandkabel "4" mit einem Spudger.
Note! Be EXTRA careful with this cable #4. Twist and brakes easily!
What if I have one of those thin film screen protectors applied, would the suction cup peel it right off instead of lifting the screen up?
zneumann66 - 답글
Trenne das Flachbandkabel "6" mit einem Spudger.
Those "6" and "7" antenna connectors are quite fragile.
Be very careful when assembling not to force the connector down; It should click actually quite easily once it's placed properly.
If you try to force the connection, it might easily be deformed, which would really be a pity.
Actually, I had to apply some pressure to #7 to get it back in place - I tried not to force it as advice above said, but it wouldn't go in. The pressure wasn't too strong, but it doesn't just slide right in.
iluxan -
I think the steps to replace the connectors 6 & 7 should be emphasized because of the size/fragility of the connectors.
satsho -
I agree with the others that cable 6 and 7 are very fragile and can be difficult to reattach. I was able to get #7 back on but #6 just wouldn't attach. I put too much pressure on it so now I have a cell phone without WiFi or GPS. I would rate the repairability of this phone lower than it is because of the 50-50 chance of flattening these connectors. My 3GS is now effectively an iPod, but with a new battery.
In hindsight I should have read over the whole recipe twice and looked at the comments before starting but I didn't because I thought I could do it and was impatient. I agree that there should be warning at the top to draw attention to the multiple wires that could be damaged when you do this.
My antenna doesn't work now and there is a small metal part that looks like a letter p that fell out of my phone. I thought it wouldn't matter till my friend said it might attach the antenna. Does anybody know where it is supposed to go?
The small metal part that looks like a "p" is a clip that holds the camera in place. You need to put it in place before you replace the screw immediately next to the camera. It's mentioned in step 12 of many of the guides.
#6 would not reattach. I spent an hour trying to reattach that ONE thing. I finally had to give up. What a complete waste of time.
I had edited this step months ago to add a warning to make VERY certain that the connector on the ribbon cable for #6 is centered on its mating connector on the motherboard before applying pressure to it. If it's not centered and you apply pressure you will very likely destroy both halves of the connector. The half attaced to the ribbon is replaced with the wifi antenna- very inexpensive. However, the half on the motherboard is tiny and soldered on. You'll need to get someone equipped to repair circuit boards.
When I ruined my #6 I ended up getting another phone. If you don't repair it, your phone will work but your wifi will not because #6 is the wifi connector.
Months ago I wrote and placed an edit into step 10 which read something like this:
" Be very certain that the #6 connector half on the ribbon cable is perfectly concentric with the #6 connector half on the mother board before applying pressure. This may require a magnifying glass or jewelers' loupe. Failure to ensure proper alignment of these connector halves prior to applying pressure will destroy both connector halves."
At some point someone removed this much needed edit. WHY???????
"concentric" is not the right word. Try "parallel and aligned".
No, actually concentric is exactly correct. When the center of the circle in the ribbon is exactly over the center of the connector on the board the respective circles of the connector halves are CONCENTRIC and properly aligned.
Entferne die folgenden acht Schrauben
Fünf 2,3 mm Kreuzschlitzschrauben #00 mit Teilgewinden, die das Logic Board am hinteren Gehäuse befestigen.
Zwei 2,3 mm Kreuzschlitzschrauben #00 mit vollen Gewinden, mit denen Logic Board und Kamera befestigt sind.
Eine 2,9 Kreuzschlitzschraube #00, die sich unterhalb des "Do not remove"-Stickers befindet.
Beachte beim Wiederzusammenbau:
Die Schraube neben der Kamera (die orange markierte Schraube unten rechts) weist zusätzlich eine Metallleiste auf, welche die Kamera an Ort und Stelle hält.
My battery had swollen - so much so that the back cover was bulged. So when I was removing screws, I was really careful and did every-other-one first on one side, and then the other, then back to the first side, etc. Even in doing that, one of the screws went flying...somewhere...I never did find it, but it hasn't seemed to effect anything. And when I do find it I know I can get back in my phone to put it back.
I didn't have a removable screw in the bottom right with a metal strip, there was a fastening in there without a Philips type depression, but the camera came out with the board. Not sure if the last person in here before me broke something, as there was an aftermarket battery in the phone with no adhesive. However the camera works after putting it all back together
panchocole - 답글
Verwende einen Spudger, um die Kamera vorsichtig nach oben und aus ihrer Einfassung auf dem hinteren Gehäuse zu hebeln.
After removing the 2.3 mm Phillips #00 screw attached to the camera a small retaining clip may be present.
Take note of its position and orientation for later reinstallation.
John Zemko - 답글
3G and 3GS camera enclosure: As I was transplanting a 3G cover onto a 3GS, I realized as I was trying to re-assemble the camera that it would not fit: the 3GS camera does not fit in the 3G enclosure. Luckily, you can remove just the camera enclosure from the 3GS and transplant it to the 3G. It's dirty, I broke the ring, I transplanted some of the double face tape... but in the end it worked.
Heble das Logic Board vorsichtig an dem Ende, wo sich der Dock Anschluss befindet, mit einem Spudger nach oben.
When removing the logic board, a slight push towards the top of the phone, will "unclip" the bottom edge of the logic board near the "Do Not Remove" screw.
When reinserting the logic board, there is a tab in the top edge of the rear shell case that the edge of the logic board goes under. It is the edge closest to the camera.
Without this "comfortable" fit, you won't be able to get the SIM in.
The camera itself also has an element of "comfortable" Fit.
If the “Do not remove”-sticker is damaged it’s a warranty thing I suppose? It doesn’t have any function, does it?
Lasse das Logic Board in Richtung Dock Anschluss und aus dem iPhone heraus gleiten.
Wenn du das Logic Board wiedereinsetzt, nachdem du den Akku installiert hast, verbinde die Kamera mit dem Logic Board, bevor du es in das Gehäuse einsetzst. Stelle dann sicher, dass du die obere Seite des Logic Boards (wo sich das SIM Fach befindet) in Position bringst, bevor du den Rest des Boards zurechtrückst.
Das ist wichtig, da sich der SIM Karten Slot manchmal nicht richtig ausrichtet. Du weißt, dass das Logic Board in der richtigen Position sitzt, wenn das SIM Fach hinter der Öffnung im iPhone Gehäuse sitzt und das Kameramodul richtig an seinem Platz sitzt.
Lenore로 부터 인용:
When reversing directions for reassembly, the logic board needs to be clipped into the clips on the side.
Although I would say "needs to be slipped under the clips on the side". The most obvious clip is next to the camera, facing south (if the camera is in the NE corner). There is a corresponding clip on the opposite side of the north end the logic board, facing east (a bit east of the #6 ribbon cable).
It's still possible to get all the screws back in with the logic board above the clips (trust me), but it's a serious barnus because the SIM card holder won't fit back in and the camera will be pointing a bit askew ... and you'll have to pull all the screws back out and figure out what you did wrong (and why you had a naggling suspicion the logic board wasn't placed quite right).
I would recommend sliding in the SIM card tray *before* putting any screws back, just to make sure.
Slipping the SIM card in first is a helpful suggestion.
My motherboard actually was not quite lined-up as mentioned, and so after the SIM didn't fit, I was able to pull and reposition the motherboard properly before proceeding.
johnhart로 부터 인용:
When putting it back together, it helps with alignment to put in the SIM Card tray. This beats having all your screws back in and finding out it's misaligned. Put the logic board 5/6 the way in, and insert the SIM Card tray like normal. Allow it to guide your logic board into the proper place.
When re-installing the mother board ensure that all of the previoulsly diconnected connector cables are out of the way and do not become trapped by the motherboard.
Heble den Akku mit einem Spudger vom hinteren Gehäuse weg. Der Akku ist rundherum mit einem Klebestreifen befestigt.
I successfully completed these steps to dry out a wet phone. While everything inside was dry as a bone, I never did remove the battery since the adhesive was so strong.
I found the spudger far too weak to even attempt the removal of the battery. Instead, I used a folding bone (something I've had for years that's used for making perfect folds in heavy printmaking paper) however, I was still bending the battery far more than I was comfortable with. Since my mission was not to mess with or replace the battery anyways I just left it alone.
Excellent directions!
Installed and the phone is working... You'd think Apple didn't want us to be able to replace the battery. Good directions.
I've done all the steps and phone switches on and works just fine with the one exception that I do have a signal! Is it possible I've damaged the aerial in the process? The strange thing is that on checking the networks I can see T-Mobile, but not 02, so implies something is working. All very odd. Currently my iPhone has become an iPod! Erkk
Any tips?
You most likely forgot to re-atatch the antenna. It is one of the connecters you unhooked after the first 3...its located in the top left of the case..Its a circular connecter.
John로 부터 인용:
Any tips?
Sorry...Its the connecter on the bottom left..Rectangular shaped
John로 부터 인용:
Any tips?
I put back together my iPhone and put it in a new shell but I just finished and the power button won't work what could i have done wrong?
thomas manning로 부터 인용:
oh also the vibrate button won't work any ideas there?
I managed to replace the mute button without removing the on/off button :o)
Was able to peel the ribbons without removing the battery. Worked great with a 3G. Thanks
midiman127 - 답글
Instructions and notes made this fairly easy to do. I had one scary moment where my screen would not turn on but a Hard Reset on the phone fixed it.
any help welcome,just changed the battery on the wife's iPhone after it took a little swim,it wouldn't charge after drying out and i thought a new battery would be the answer,phone switches on ok and everything works except it won't charge on any of our proven chargers.guess something on the main board's knackered. if you have any ideas i would be a very happy chap.
Just a little tip I thought I might add. I would recommend having a digital camera handy to taking snap shots before proceeding with each step, so that you can see exactly how it originally looked at each stage. Once you've gotten to the battery section, just pop the card from the camera into a computer or applicable device and you now have a simple guide for reassembly that is specific to your device.
Also, it may be prudent to take a picture of the screws laid out in a tray along side the phone in the same positions they came out of.
Agree with others - spooger will almost certainly break if you try to pry it out using just that and you can't pull hard enough on the plastic tab. Even on my 2 year old phone, the glue was still *quite* good at holding the battery in.
I used an equally small flat-blade screwdriver and gently walked around the battery lifting against the bottom plastic and the edge of the phone being careful NEVER to touch any of the flat-cable wires. While you can pry against the bottom since there is nothing under it (just double-check since there are some wires running along the side of the phone and the pressure you need to remove the battery would damage the wires if you pryed on them), you need to be careful against the edge of the phone. It's cheap plastic. You can pry against it, but I dared not use more force than enough to start hearing the adhesive start to rip/creak loose. SLOWLY walking around the battery at safe pry points several times finally loosened it enough that I could pull it out. GO SLOW.
If you have the plastic spudger that comes in the kit, it will most likely break when trying to remove the battery. A butter knife worked extremely well, however ...
Agree with this comment. Prying the battery up from its adhesive was the hardest part of this repair, and yes, I did break the spudger thingy.
Barb -
Since I didn't have a hair dryer (never needed one) I used a 500W construction lamp... Those things get very hot. The battery came free relatively easy.
DefCharlie - 답글
Had to use pliers to slowly pull the battery free by it's tab. When you reverse the steps to reassemble the phone - make sure to get all 6 (or 7 for the 3GS) cables plugged back in. I forgot connector 5 and had to take the phone back apart. Then realized the next day I also had missed connector 6 (wifi). So because I reassembled too quickly the first time - I got to do all the steps 3 times! But phone works perfectly now with a new battery.
Actually broke the plastic spludger trying to get the battery off. Considered it the hardest part of the tutorial. I kept looking at it to see if I hadn't ruined something.Asides from this, reassembling was fairly quick although there was no sliding back of the logic board for me on a 3G. Turned it back on, tested sound, microphone and wifi. All seems good. Thanks alot for all the help guys.
I've made all the disassembling process with no problems, but when I put the logic board back the battery starts getting hot and hotter. Any suggestions??
When I put the new battery in, it was a smidge too far toward the bottom. As a result the logic board didn't quite fit back into place and I was unable to put two screws back in. However, the repair seems successful and my phone is working now. Additional guidance on installing the battery would help.
The new battery that I have had air pocket in it. It kinda bloated. The logic board would not fit back perfectly because of the bloated battery.
So using a sharp cutter, I cut a bit hole. Pssssttt... the air came out. Watch out for the chemical smell. Using a good tape, tape back the hole. Double did that to make sure.
Don't know whether I supposed to do that or not, but sending back the battery to ifixit was not an option as I live on the other side of the planet.
any one can help me fix my iphone 3g. i was using it the other day when it suddenly turned off by itself and i cant turn it back on, any tips?
OK, I replaced the battery following the instructions (was more of a struggle than I thought it would be to get the logic board back in place) and put it all back together. All appears to be working fine except the Camera. The Camera App will not open the camera to let me take either a photo video. As the camera is never disconnected from the logic board I am puzzled as to what could be the issue. Very frustrating. Any ideas?
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
다른 928명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 35개
I replaced the battery in both my iPhone and my wife's in the same session. Using the slideshow and directions I was able to successfully do the replacement. Of course my iPhone was the first one done so as to gain some experience before tackling my wife's iPhone. I had two minor issues in reassembling mine. Firstly, I completely missed re-installing the number 3 cable. It wasn't till I was reassembling my wife's iPhone that I realized I'd missed it. Not sure what it supports as I had my phone up and running, checked the GPS, etc while it wasn't connected. Secondly, my camera wasn't seated properly and I got the strangest imagery when I launched it. All green and black, looking like one of those ghost buster reality shows using night vision. Fortunately, both issues were easy to correct. Outstanding directions and slides! Oh yeah finally, the kits for the battery comes with both a #00 Phillips screwdriver and a spudge, however, I ordered the extra spudge and got one that is better suited for prying the battery up.
Hey,
first of all - BIG UPS AND THX for everything.
That means FAST shipping to germany and the great tutorials, manuals etc.
I did change the battery in less than 15 minutes whit ur manual this was easy as.... dunno :).
the "hardest part" was to remove the battery from the cover - but with a bit of tact it works fine.
So thx :)
Incredibly easy to make the swap. Thanks for the great writeup. I was able to complete the battery replacement within about 20 minutes. I've swapped an iPod battery before and although this was a bit more complex it really wasn't that tough. Anyone who's a bit handy should be able to complete it with no trouble at all. Thanks.
Great instructions, very clear. A couple points:
1) The screwdriver I had wasn't working that well, so I had to use a different one. I found that a 0# worked fine (although I suspect a 00# would work better.0
2) When I reassembled the phone, the home button didn't work. You really need to press down on the bottom of the screen when you screw the bottom screws (by the dock connector) back in. Otherwise, the contacts for the home button won't reliably hit.
dlinsalata - 답글
Don't get too impatient once the whole thing is together and it doesn't turn on. Let it charge for 10 minutes or so, then try to turn it on. The battery is fully drained when you get it (or at least mine was).
If anyone is looking for a way to extend the battery life of an iPhone 3G or 3GS, I found this product on Amazon.com for under $14.00 and it works great.
my local apple authorised repairer quoted me €80 to replace the battery in an old iPhone 3g that my daughter was using, after some searching i came across this site and decided to take a chance on the replacement kit!
once it arrived it took me approx 15 minutes to replace the old battery, some of the ribbon connectors were fiddly to reconnect but overall an easy- moderately difficult job!
great step by step help tho! thanks a lot
For those who wanted to know what all the connectors are for in one place (there seemed to be a lot of inconsistent or incomplete posts in this guide and throughout the site), here are the connector summaries in one place for the 3GS model (3G is different):
1. LCD Display
2. Digitizer/Touchscreen
3. Ear speaker, Proximity Sensor
4. Charging Port, Microphone, Speaker
5. Audio Controls (Headphone Jack, Volume Buttons, Silent Switch)
6. GPS, WiFi, Bluetooth Antennas
7. Cell/WWAN Antennas
Try using a pair of tweezers, or straighten out the cable and let it slide back in. Also is the tab lifted up?
Just made the replacement of the battery for this iPhone 3G in 35 minutes. Very carefully of course.
For me the trickiest parts were with connector of the screen number 3, basically placing it back but it is easy though. Don't use your plastic tools to remove the battery but also don't use a very strong metal tool! it is sticked in, so patience and side by side a little push every time.
Love the feeling of going against this "programmed due dating" on devices.... against the corporate greed, no matter how much I love Apple products!!!
Enjoy and thanks iFixit KEEP IT UP!!!
ampjonline - 답글
Thanks, works with no major pb. And the fix helped me realize that I must return to my ophtalmologist...
In #11 you can just scrape the sticker off to get to the screw. It's not like it's under warranty any longer :)
Brian Peat - 답글
zneumann66 - 답글
I successfully replaced the battery but now my touchscreen will not work. Connector #2 seems to be in place fine so I'm not sure what I may have done incorrectly. Any ideas? Thanks.
1.) Turn off your device before beginning this replacement.
2.) Add tweezers to the tools, they will come in handy when trying to reinsert the screws and various connectors, especially #3 (ear speaker/proximity) which is more like slide the ribbon back in, doesn't "pop off" like the others.
3.) The batteries were seated using a two sided adhesive tape. It's pretty strong stuff for such a small amount of tape (cut to shape) and will require a small amount of force. This is something the little spudgers aren't quite capable of dealing with. Tips broke off on mine, but I have two kits so no big deal. I suggest you use the sides of the back case and slowly, patiently, work the battery up from each side.
4.) Reassembly will go smoother if you removed the screws and set them in groups, in order to keep them organized. Reinstall using a lightly magnetized phillips screw driver (if you didn't buy the kit with tools, a small "00" size from a precision or eye glass repair set phillips screwdriver set should work).
Both my wife and I have had the same problems: phone reboots itself when opening a power hungry app like the camera, maps... So I ordered two battery replacement kits, downloaded the step by step guides and some notes to add in.
All in all, it took me about 25 minutes to complete the first one (mine, a 3G) and then much less time to do my wife's (3GS) and another noteworthy piece of advice:
When you complete reassembly and for some reason the screen doesn't seem to light up, don't panic, reboot the hard way: hold the home AND the power button down for a few seconds (10-30 seconds, you'll see when) and it will cause the unit to reboot the device. Should see screen light up.
@jonatgree, probably a bad battery. I bought one on ebay (from China) and had a similar problem. Bought another one from ifixit and the phone worked fine.
hsm6second - 답글
I am soooo sad; it took me ages to follow all the instructions (not least of my initial obstacles was the fact that what i needed was a Phillips NOT a screwdriver! An anomaly which puzzles me muchly…) & removing the logic-board was a nightmare (basically, it was 'stuck' & broke my spudger, etc) - finally, succeeded in replacing battery & put everything back as-was except now NONE of the screws would stay put, for some reason, except the two @ the bottom of the phone (which one removes prior to opening it up); so plugging it in, to my initial joy, the familiar apple logo showed up…but then disappears. And that's that! So far, nothing moves beyond this start-up point of the apple logo showing up on the screen for a few seconds after plugging it in to the recharger. I hoped at first this was just the new battery recharging, but…? Beforehand, I could use the phone as long as it was plugged in, i.e. the battery wouldn't hold a charge. But now, so far, I can't use it @ all. Does anyone have any suggestions, please?
Try redoing the installation, taking time to make sure all the screws are of proper size and that everything fits neatly. Once you have the new battery in, it will probably have no charge to start, so you may need to let it stay on a charger for a while for a full charge, it will turn on by itself if you let it stay on the charger, it needs 5% battery at least to be able to load up. Does it give you a battery charging picture, battery needs charge picture, or did you try turning it on and get the apple logo?
Eric H -
Thank you, Eric H; after posting I did of course re-open, re-examine, re-align…& have got it now as far as trying to Restore on my computer BUT so far am NOW coming up against a mysterious 'Error 23' (generated from the iTunes/Apple site), which indicates a hardware problem BUT does NOT specify which!? I'm not going to open it again, as I feel with a phone this age, I'm jeopardising/taking a risk with each re-opening. But yes, the battery is charging - now the problem is that I don't have the contents of the phone, & can't seem to get them! Terribly disappointing & meantime I don't have a phone! Will try one last round of attempts to solve/get past this mysterious Error 23, as THAT now seems to be the problem. :(
Could this possibly be a compatibility issue? Maybe you broke something really small such as a resistor on the motherboard which is causing this, make sure to backtrack and check for everything that got touched to see if you missed or broke something along the way, better to do it right the first time than have to do it all over again. Also i think i remember small metal frounding clips, make sure they are properly cleaned and properly seeated.
Eric H -
Fantastic information, never done a phone before, but I replaced the battery on the iPhone 3 very easy and in about 40mins and it works great,very chuffed
i cant on mi IPHone i ned reset
I agree with many of the comments. It didn’t take long and i had everything i needed in my toolkit. The guides were great but i think a small amount of technical knowhow will be helpful. It hard to see what tools are mentioned for what job but i figuredit out easily enough. I was nervous to put it back together so i would tell people keep your tools oranganized and how you place things down around you and watch facings of pieces. I just followed the directions in reverse. I am concerned the seal fit after popping it out isn’t as snug as before but i’llget over that.
Soon, my battery and docking panel will arrive. Much appreciation for all the comments I have reviewed while waiting for a storm to strike….all comments were very helpful, building quite supportively on the guide’s author. I love my little 3G, as it contains or supports all I need, along with the feelings from simply holding it!
took me hours, partly becus i was so compulsive about keeping the screws in a schematic pic to maintain correct position of each one, and also i had to redo several several operations while assembling due to trapping ribbon cable connectors under board, etc. but the worst was that i was utterly defeated by ribbon cable connector #6, i must have had it a tiny bit misaligned when i first pressed it together and the resulting distortion prevented subsequent re-connection despite over an hour of fussing and trying to re-shape this nearly-microscopic and quite inaccessible component, which is labeled as the BT, WiFi & GPS antenna connector. so finally i taped over it to hold the connector in position, and reassembled the display onto the shell with a bit of spongy foam rubber over it to ( i desperately hope) keep the conductors in contact.
fired it up and it acted normal, seems to detect WiFi and BT signals but haven’t really used it yet. battery showed 63% but rapidly dropped to 54%, then slowly diminished.
Thanks for the great instructions. I replaced the battery in the old 3G and got concerned only when reconnecting the cables’ tiny plugs. Clear and concise layout!
Marty Bond - 답글
