주요 콘텐츠로 건너뛰기
iPhone 3G Home Button Replacement
필요한 것
  1. iPhone 3G Home Button Replacement, Broken Glass: 1 단계, 이미지 1/3 iPhone 3G Home Button Replacement, Broken Glass: 1 단계, 이미지 2/3 iPhone 3G Home Button Replacement, Broken Glass: 1 단계, 이미지 3/3
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  2. iPhone 3G Home Button Replacement, Home Button: 2 단계, 이미지 1/1
    • Remove the 2 Phillips #00 screws at the bottom of the iPhone, located on both sides of the dock connector.
    The guide is ok, but maybe you should just rename it to "Home Button Troubleshooting"
    as it is misleading to have "Replacement" in the title. People are expecting you to explain how to take the home button out and place the new one in.
    Jessica - 답글
  3. iPhone 3G Home Button Replacement: 3 단계, 이미지 1/2 iPhone 3G Home Button Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Suction Handle
    $2.99
    구매
    • Attach the small suction cup to the iPhone, above the home-button.
    • Grip the suction cup, and start lifting the display slowly, and gently, making sure not to remove the display completely. There are still ribbon cables connecting the display assembly to the motherboard.
    • In some cases, the suction cup just won't adhere to the screen! You could use a heavy duty suction cup, or duct tape to pry off the screen. However, if you do not plan on replacing the screen, I do not suggest that you use duct tape.
    • Lift the display to a 45 degree angle.
  4. iPhone 3G Home Button Replacement: 4 단계, 이미지 1/3 iPhone 3G Home Button Replacement: 4 단계, 이미지 2/3 iPhone 3G Home Button Replacement: 4 단계, 이미지 3/3
    • Use a spudger to disconnect ribbon cable(s) 1, 2, and 3.
    • Just a reminder. The 3rd cable is actually connected to the board by a port, which requires an inset connector.
    • Lift up the black tab on the back of the inset connector port, and then the 3rd ribbon should slide right out.
  5. iPhone 3G Home Button Replacement: 5 단계, 이미지 1/1
    • After connectors 1, 2, and 3 are detached, you can lift the display assembly off completely, and set apart the case for the iPhone, you will only need the assembly for now.
    • Sorry for the bad image quality.
  6. iPhone 3G Home Button Replacement: 6 단계, 이미지 1/1
    • It will be easy to locate the home-button assembly from here.
    • Make sure the cable that runs into the home button assembly is not damaged or loose. This cable is indicated in the image here with a rectangular marker.
  7. iPhone 3G Home Button Replacement: 7 단계, 이미지 1/2 iPhone 3G Home Button Replacement: 7 단계, 이미지 2/2
    • If the cables are all fine, or making sure the cables are firmly placed does not work, check the dock connector for any broken pins, especially the areas I highlighted with the circular red markers. If any pins are broken, you might want to buy new cables, because repairing these pins requires a lot of experience and precision tools.
    • If this STILL doesn't work, check the pins on the cables connected to the home-button (marked with a red marker in second image.) Again, if any pins are broken, you might want to buy new cables, or a new home-button, because these pins are very fragile and hard to fix.
  8. iPhone 3G Home Button Replacement: 8 단계, 이미지 1/1
    • If any cables or pins are broken , you could buy new cables, as mentioned before. However, if the home-button screws are broken or missing, or the home-button is completely broken, you might want to buy a new home button assembly. This assembly is displayed on this step's adjoining image.
    This Guide is garbage. Doesn't even show you how to get the actually button and flex cable out of the screen assembly.
    F -
    Zachariah - 답글
    Exactly, how do i take the old home button out?
    Mini Legoman -
결론
다른 41명이 해당 안내서를 완성하였습니다.
erthw46uhw4t
회원 가입일: 05/01/12
1,841 평판
안내서 1개 작성함
iTweakTech Fixers iTweakTech Fixers 회원
Community
5 회원들
안내서 2개 작성하였습니다
댓글 5개
Please add comments to help me figure out what to improve about my guide!
erthw46uhw4t - 답글
hmm, but how do i REALLY get the home button changed? sad.
christian witt - 답글
So following your instructions I found that one of the "springs" on the home button assy was missing. I ordered a replacement assembly but I can't figure out how to replace that assembly. Do I need to take the whole display apart?
Any inputs would be greatly appreciated.
Cheers,
Hans
merchants - 답글
fix3g on my LG phone
jason hickmon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 29
30일 전: 69
전체 시간: 96,819
