소개
Use this guide to replace the plastic mute switch cover, not the electronic switch itself.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Remove the following 8 screws:
Five 2.3 mm Phillips #00 screws with partial threads securing the logic board to the rear case.
Two 2.3 mm Phillips #00 screws with full threads securing the logic board and camera.
One 2.9 mm Phillips #00 screw from beneath the "Do not remove" sticker.
Note for re-assembly:
The screw that goes next to the camera (bottom right orange highlighted screw) also has a metal strip that holds the camera in place.
Slide the logic board towards the dock connector and out of the iPhone.
When replacing the logic board after installing battery, connect the camera to the logic board before inserting it into the case. Then make sure to set the top section of the logic board (where the SIM tray is) in place before settling the rest of the board in place. This is important, as sometimes the SIM card slot will not align into place. Once the top section is in place, the bottom section can be maneuvered into place. You will know the logic board is correctly installed when the SIM tray is aligned with the opening in the iPhone case and the camera module seats neatly into its place.
Remove the following four screws:
Three 1.8 mm Phillips #00 screws securing the headphone jack and GPS antenna to the rear panel.
One 3.8 mm Phillips #00 screw in the plastic loop near the headphone jack.
다른 50명이 해당 안내서를 완성하였습니다.
댓글 3개
Hi,
thanks to your pictures I did the disassembling process successfully and i also reassembled my iphone afterwards. The problem is that the mute button has no effect on the software, which means that the IPhone is mute all the time no matter if I switch the button or not. Do you know what the problem could be?
Yes unfortunately that means you will need to replace the flex ribbon, cheap part on ebay but a pain to do, its one whole flex ribbon that controls the volume mute switch and power button, i have done it before as i had same issue, once tge motherboard and battery are out it took about 30mins, just make sure you dont rush and have time
bush tukka - 답글
that was back in 2012, %#*@ people cant see the date of the comment
