주요 콘텐츠로 건너뛰기
iPhone 3GS Dock Connector Replacement
필요한 것
동영상 개요
  1. iPhone 3GS Dock Connector Replacement, Broken Glass: 1 단계, 이미지 3개 중 1개 iPhone 3GS Dock Connector Replacement, Broken Glass: 1 단계, 이미지 3개 중 2개 iPhone 3GS Dock Connector Replacement, Broken Glass: 1 단계, 이미지 3개 중 3개
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  2. iPhone 3GS Dock Connector Replacement, Dock Connector: 2 단계, 이미지 1개 중 1개
    • Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
  3. iPhone 3GS Dock Connector Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
    • Be very careful when opening the iPhone so that the cables under the display are not severed.
    • There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly.
    • Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
    • If the display assembly is too damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape maybe used.
  4. iPhone 3GS Dock Connector Replacement: 4 단계, 이미지 1개 중 1개
    • The display assembly is still connected to the iPhone by three cables, so don't try to remove it entirely just yet.
    • Rotate the display assembly up until it is at an angle of approximately 45 degrees.
    • Be careful. Sometimes cable 4 can stick to the back of the display assembly and can be pulled off and/or torn as you remove the display assembly.
  5. iPhone 3GS Dock Connector Replacement: 5 단계, 이미지 1개 중 1개
    • Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
    • Start from the ribbon and work your way towards the outside edge of the case.
  6. iPhone 3GS Dock Connector Replacement: 6 단계, 이미지 1개 중 1개
    • Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
    • Use a spudger to disconnect the black ribbon cable labeled "2."
  7. iPhone 3GS Dock Connector Replacement: 7 단계, 이미지 1개 중 1개
    • Use a spudger to flip up the white plastic tab holding the remaining ribbon cable in place. The white tab will rotate up 90 degrees, releasing the ribbon cable.
    • Slide the black ribbon cable out of its connector, and remove the display assembly from the iPhone.
  8. iPhone 3GS Dock Connector Replacement: 8 단계, 이미지 1개 중 1개
    • Insert your SIM eject tool or a paper clip into the hole next to the headphone jack.
    • Press down on the tool until the SIM card tray pops out.
    • Grasp the SIM card tray and slide it out of the iPhone.
  9. iPhone 3GS Dock Connector Replacement: 9 단계, 이미지 1개 중 1개
    • Use a spudger to disconnect the ribbon cable labeled "4."
  10. iPhone 3GS Dock Connector Replacement: 10 단계, 이미지 1개 중 1개
    • Use a spudger to disconnect the ribbon cable labeled "5."
  11. iPhone 3GS Dock Connector Replacement: 11 단계, 이미지 2개 중 1개 iPhone 3GS Dock Connector Replacement: 11 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the ribbon cable labeled "6."
    • If you have an iPhone 3GS, refer to picture 2 and use a spudger to disconnect the ribbon cable labeled "7."
  12. iPhone 3GS Dock Connector Replacement: 12 단계, 이미지 1개 중 1개
    • Carefully peel up the small sticker labeled "Do not remove."
  13. iPhone 3GS Dock Connector Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the following 8 screws:
    • Five 2.3 mm Phillips #00 screws with partial threads securing the logic board to the rear panel.
    • Two 2.3 mm Phillips #00 screws with full threads securing the logic board and camera.
    • One 2.9 mm Phillips #00 screw from beneath the "Do not remove" sticker.
  14. iPhone 3GS Dock Connector Replacement: 14 단계, 이미지 1개 중 1개
    • Use a spudger to gently remove the camera retaining clip, (formerly secured by the removed screw) and gently pry the camera up and out of its housing in the rear panel. The camera cannot be removed entirely yet because it's connected to the bottom of the logic board.
  15. iPhone 3GS Dock Connector Replacement: 15 단계, 이미지 1개 중 1개
    • Use a spudger to gently pry up the end of the logic board closest to the dock connector.
    • There is a small golden grounding tab on the logic board adjacent to the 'Do not remove' sticker. Be very careful this does not snag on the side of the case when prying up the logic board; it breaks easily! If you have signal problems after removing the logic board, check this ground tab.
    • If the board won't lift up, double check to make sure all 8 screws securing the logic board have been removed.
  16. iPhone 3GS Dock Connector Replacement: 16 단계, 이미지 1개 중 1개
    • Slide the logic board towards the dock connector and out of the iPhone.
  17. iPhone 3GS Dock Connector Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the following 3 screws:
    • Two 1.5 mm Phillips #00 screws, one on either side of the dock connector.
    • One 2.4 mm Phillips #00 screw near the ribbon cable labeled "4."
  18. iPhone 3GS Dock Connector Replacement: 18 단계, 이미지 1개 중 1개
    • Lift the dock connector assembly up and out of the iPhone.
    • When inserting the new assembly, ensure the screw holes of the assembly rest ABOVE the bezel's holes.
결론
다른 298명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Ben Eisenman
87,744 평판
안내서 59개를 작성함
11가이드 댓글
When closing the phone (Step 3 - but when going backwards) it is important to be aware of the the contact for the HOME button. They are two little gold contacts that have to hit against two solder points on the dock assembly. I managed to bend them a bit out of alignment, so when I closed up the iPhone the home button was no longer working. Easily fixed, but worth noting.
Peter - 답글
When replacing the connector you will have to desolder 4 small solder points, 2 per ribbon cable. They are easily desoldered by gently pressing the soldering iron tip to the top of the cable and gently peeling it away.
They can they be resoldered onto the new connector.
The solder points can be seen in step 16 just above the two 1.5mm screws.
scottreschke - 답글
Hi, I followed the instructions and all went well, except for now I have very bad reception problems. I keep getting 'No Service' and cant really make calls. :-(
Could I have damaged the antenna somehow? I have found the antenna stickers online for sale but havent found any instructions as to how to install it...
Any help would be much appreciated.
Thanks
Fu82 - 답글
the sample phone looks like a 3G nto a 3Gs. I have an extra wire connection on top of the dock connector in my 3Gs.
mlstrykher - 답글
If you're purchasing a Phillips screwdriver for this I'd highly recommend getting one that has a magnetic tip. I bought the cheaper screwdriver from iFixit but wish I would've sprung for the "professional" version (which I assume does have a magnetic tip). It can be done without it (I did it) but it took much longer than it would have otherwise.
wpaul - 답글
댓글 쓰기
조회 통계:
지난 24시간: 35
지난 7일: 270
지난 30일: 535
전체 시간: 226,865
