이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Connects the iPhone to a computer or charger via iPhone cable.
필요한 것
동영상 개요
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
다른 298명이 해당 안내서를 완성하였습니다.
댓글 11개
When closing the phone (Step 3 - but when going backwards) it is important to be aware of the the contact for the HOME button. They are two little gold contacts that have to hit against two solder points on the dock assembly. I managed to bend them a bit out of alignment, so when I closed up the iPhone the home button was no longer working. Easily fixed, but worth noting.
When replacing the connector you will have to desolder 4 small solder points, 2 per ribbon cable. They are easily desoldered by gently pressing the soldering iron tip to the top of the cable and gently peeling it away.
They can they be resoldered onto the new connector.
The solder points can be seen in step 16 just above the two 1.5mm screws.
Hi, I followed the instructions and all went well, except for now I have very bad reception problems. I keep getting 'No Service' and cant really make calls. :-(
Could I have damaged the antenna somehow? I have found the antenna stickers online for sale but havent found any instructions as to how to install it...
Any help would be much appreciated.
Thanks
the sample phone looks like a 3G nto a 3Gs. I have an extra wire connection on top of the dock connector in my 3Gs.
mlstrykher - 답글
If you're purchasing a Phillips screwdriver for this I'd highly recommend getting one that has a magnetic tip. I bought the cheaper screwdriver from iFixit but wish I would've sprung for the "professional" version (which I assume does have a magnetic tip). It can be done without it (I did it) but it took much longer than it would have otherwise.
