주요 콘텐츠로 건너뛰기
iPhone 3GS Logic Board Replacement
필요한 것
  1. iPhone 3GS Logic Board Replacement, Broken Glass: 1 단계, 이미지 3개 중 1개 iPhone 3GS Logic Board Replacement, Broken Glass: 1 단계, 이미지 3개 중 2개 iPhone 3GS Logic Board Replacement, Broken Glass: 1 단계, 이미지 3개 중 3개
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  2. iPhone 3GS Logic Board Replacement, Logic Board: 2 단계, 이미지 1개 중 1개
    • Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
  3. iPhone 3GS Logic Board Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
    • Be very careful when opening the iPhone so that the cables under the display are not severed.
    • There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly.
    • Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
    • If the display assembly is too damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape, or thick, clear packing tape may be used.
  4. iPhone 3GS Logic Board Replacement: 4 단계, 이미지 1개 중 1개
    • The display assembly is still connected to the iPhone by several cables, so don't try to remove it entirely just yet.
    • Rotate the display assembly up until it is at an angle of approximately 45 degrees.
  5. iPhone 3GS Logic Board Replacement: 5 단계, 이미지 1개 중 1개
    • Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
  6. iPhone 3GS Logic Board Replacement: 6 단계, 이미지 1개 중 1개
    • Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
    • Use a spudger to disconnect the black ribbon cable labeled "2."
  7. iPhone 3GS Logic Board Replacement: 7 단계, 이미지 1개 중 1개
    • Use a spudger to flip up the white plastic tab holding the remaining ribbon cable in place. The white tab will rotate up 90 degrees, releasing the ribbon cable.
    • Slide the black ribbon cable out of its connector, and remove the display assembly from the iPhone.
  8. iPhone 3GS Logic Board Replacement: 8 단계, 이미지 1개 중 1개
    • Insert your SIM eject tool or a paper clip into the hole next to the headphone jack.
    • Press down on the tool until the SIM card tray pops out.
    • Grasp the SIM card tray and slide it out of the iPhone.
  9. iPhone 3GS Logic Board Replacement: 9 단계, 이미지 1개 중 1개
    • Use a spudger to disconnect the ribbon cable labeled "4."
  10. iPhone 3GS Logic Board Replacement: 10 단계, 이미지 1개 중 1개
    • Use a spudger to disconnect the ribbon cable labeled "5."
  11. iPhone 3GS Logic Board Replacement: 11 단계, 이미지 2개 중 1개 iPhone 3GS Logic Board Replacement: 11 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the ribbon cable labeled "6."
    • If you have an iPhone 3GS, refer to picture 2 and use a spudger to disconnect the ribbon cable labeled "7."
  12. iPhone 3GS Logic Board Replacement: 12 단계, 이미지 1개 중 1개
    • Carefully peel up the small sticker labeled "Do not remove."
  13. iPhone 3GS Logic Board Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the following 8 screws:
    • Five 2.3 mm Phillips #00 screws with partial threads securing the logic board to the rear panel.
    • Two 2.3 mm Phillips #00 screws with full threads securing the logic board and camera.
    • One 2.9 mm Phillips #00 screw from beneath the "Do not remove" sticker.
  14. iPhone 3GS Logic Board Replacement: 14 단계, 이미지 1개 중 1개
    • Use a spudger to gently remove the camera retaining clip, (formerly secured by the removed screw) and gently pry the camera up and out of its housing in the rear panel. The camera cannot be removed entirely yet because it's connected to the bottom of the logic board.
  15. iPhone 3GS Logic Board Replacement: 15 단계, 이미지 1개 중 1개
    • Use a spudger to gently pry up the end of the logic board closest to the dock connector.
    • If the board won't lift up, double check to make sure all the screws securing the logic board have been removed.
  16. iPhone 3GS Logic Board Replacement: 16 단계, 이미지 1개 중 1개
    • Slide the logic board towards the dock connector and out of the iPhone.
  17. iPhone 3GS Logic Board Replacement: 17 단계, 이미지 1개 중 1개
    • Use a spudger to disconnect the camera from the logic board.
결론
다른 142명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ben Eisenman
87,747 평판
안내서 59개를 작성함
1가이드 댓글
Hi, thank you for the instructions! Maybe you can help. I'm tryin to recover data from a logic board of an iphone 3gs. I bought a working iphone 3gs and opened it, it now has a blue logic board. After replacing the blue to the green, the phone says 'connect to itunes' and does not start properly. Why are there two different colours of logic boards, what's the difference? Thanks for helping!
Julia Marmitt - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 47
전체 시간: 180,357
