주요 콘텐츠로 건너뛰기
iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
동영상 개요
  1. iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery., iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: 1 단계, 이미지 1/3 iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery., iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: 1 단계, 이미지 2/3 iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery., iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: 1 단계, 이미지 3/3
    • Open iTunes. The iPhone must be connected to the PC and powered OFF.
    • ATTENTION, ATTENTION: You will lose all your data. Be sure that you have backup.
  2. iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: 2 단계, 이미지 1/3 iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: 2 단계, 이미지 2/3 iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: 2 단계, 이미지 3/3
    • Entering DFU mode.
    • Instruction you can read at the description.
    • iTunes has detected an iPhone in recovery mode.
  3. iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: 3 단계, 이미지 1/3 iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: 3 단계, 이미지 2/3 iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: 3 단계, 이미지 3/3
    • Select "Restore iPhone" and iTunes will download and install the latest firmware for your phone.
  4. iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: 4 단계, 이미지 1/1
    • Your iPhone is factory restored now.
    • Did you do it successfully?
결론
This guide does not need reassembly.
다른 455명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,182 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,521개 작성하였습니다
댓글 99개
This is not flashing anything just resetting the iPhone...
Newbye - 답글
You are wrong. This procedure reflash the firmware, but if your phone is already with the latest version, for you this will looks like full reset.
ZFix -
My iphone 4 is locked and i dont know the apple id so by doing this i can unlock it or not please help
mehtashivani44 - 답글
If your phone is carrier locked or iCloud locked - no.
ZFix -
contact me to unlock iphone 4 icloud lock
Himanshu Rattan -
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 63
30일 전: 295
전체 시간: 502,674
