주요 콘텐츠로 건너뛰기
iPhone 4 Contact Clip Replacement
필요한 것
  1. iPhone 4 Contact Clip Replacement, Rear Panel: 1 단계, 이미지 2개 중 1개 iPhone 4 Contact Clip Replacement, Rear Panel: 1 단계, 이미지 2개 중 2개
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Your iPhone 4 rear cover may have either two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws (second image). Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
    • Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
    • Be sure the driver is well seated when removing Pentalobe screws, they are very easy to strip.
  2. iPhone 4 Contact Clip Replacement: 2 단계, 이미지 2개 중 1개 iPhone 4 Contact Clip Replacement: 2 단계, 이미지 2개 중 2개
    • Push the rear panel toward the top edge of the iPhone.
    • The panel will move about 2 mm.
  3. iPhone 4 Contact Clip Replacement: 3 단계, 이미지 1개 중 1개
    • Pinch the rear panel with your fingers and lift it away from the iPhone. Alternatively, use a Small Suction Cup .
    • Be careful not to damage the plastic clips attached to the rear panel.
    • If you are installing a new rear panel, be sure to remove the plastic protective sticker from the inside of the camera lens and the sticker from the large black area near the lens.
  4. iPhone 4 Contact Clip Replacement, Contact Clip: 4 단계, 이미지 1개 중 1개
    • Remove the single 2.5 mm Phillips screw securing the battery connector to the logic board.
  5. iPhone 4 Contact Clip Replacement: 5 단계, 이미지 3개 중 1개 iPhone 4 Contact Clip Replacement: 5 단계, 이미지 3개 중 2개 iPhone 4 Contact Clip Replacement: 5 단계, 이미지 3개 중 3개
    • Use an iPod opening tool to carefully pry the battery connector up from the ends closest to the top and bottom edges of the iPhone.
    • Do not pry against the contact clip.
    • Remove the contact clip from the iPhone.
    • Before reconnecting the battery connector, be sure the pressure contact (shown in red) is properly positioned next to the battery connector.
    • Before reassembly, be sure to clean all metal-to-metal contact points on the pressure contact as well as its contact point on the rear panel with a de-greaser such as windex. The oils on your fingers have the potential to cause wireless interference issues.
결론
다른 93명이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
6다른 기여자 명과 함께
Scott Head
53,415 평판
안내서 7개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,612개를 작성함
2가이드 댓글
need a job as assistant with the author ...i am a 16 year old kid who loved being with iphones ..i can do a all kind of software problems in iphones and ipads....please reply.sir
mac - 답글
Mwea ko battery ka connector chayan
Lalita Kumar - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 13
지난 30일: 80
전체 시간: 85,610
