주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide shows how to remove the two bottom Pentalobe screws on the iPhone 4.
도구
지정된 도구가 없습니다.
  1. Use the Pentalobe screwdriver to remove the two 3.6 mm Pentalobe screws near the dock connector. Use the Pentalobe screwdriver to remove the two 3.6 mm Pentalobe screws near the dock connector.
    • Use the Pentalobe screwdriver to remove the two 3.6 mm Pentalobe screws near the dock connector.
  2. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
결론
다른 428명이 해당 안내서를 완성하였습니다.
Walter Galan
641,975 평판
안내서 1,203개 작성하였습니다
What do you do when you strip a screw
Jesse Medrano - 답글
I also think I stripped one of the pentalobe screws,one came off the other was a problem from the start. How do you deal with a stripped pentalobe screw?
bftravers522 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 14
30일 전: 43
전체 시간: 404,228
