이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use the Pentalobe screwdriver to remove the two 3.6 mm Pentalobe screws near the dock connector.
다른 432명이 해당 안내서를 완성하였습니다.
댓글 3개
What do you do when you strip a screw
I also think I stripped one of the pentalobe screws,one came off the other was a problem from the start. How do you deal with a stripped pentalobe screw?
Hey there! Our Answers forum has a lot of great solutions to this problem! Check out these posts 3.6 mm Pentalobe screw is stripped, What to do when my iPhone pentalobe screws are stripped?, How can I remove a striped pentalobe screw? Good luck!
