주요 콘텐츠로 건너뛰기
iPhone 4 Trouble Shooting Repair
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. iPhone 4 Trouble Shooting Repair, iPhone 4 Trouble Shooting Repair: 1 단계, 이미지 1/1
    • Before you begin make sure that the phone is on silent and it is shut off.
  2. iPhone 4 Trouble Shooting Repair: 2 단계, 이미지 1/2 iPhone 4 Trouble Shooting Repair: 2 단계, 이미지 2/2
    • Remove both five-point tamper resistant screws which are located on either side of the charging port. Remove them with your T5 Torx screwdriver.
  3. iPhone 4 Trouble Shooting Repair: 3 단계, 이미지 1/2 iPhone 4 Trouble Shooting Repair: 3 단계, 이미지 2/2
    • After the screws are removed the back should slide up and remove smoothly.
  4. iPhone 4 Trouble Shooting Repair: 4 단계, 이미지 1/1
    • You can then remove the screw on the battery connector. Which will free up your battery for removal.
  5. iPhone 4 Trouble Shooting Repair: 5 단계, 이미지 1/2 iPhone 4 Trouble Shooting Repair: 5 단계, 이미지 2/2
    • Then you will take your plastic opening tool and begin to pry up the battery connector, which is the plate you took the screw out of. After you have that up you can begin to pry up on each edge of the battery.
  6. iPhone 4 Trouble Shooting Repair: 6 단계, 이미지 1/2 iPhone 4 Trouble Shooting Repair: 6 단계, 이미지 2/2
    • After removing the battery you can put the replacement battery in and connect the battery connector.
  7. iPhone 4 Trouble Shooting Repair: 7 단계, 이미지 1/1
    • you can then pit the back cover back on and screw in the five-point tamper resistant screws and it should be ready to use.
결론
Your iPhone 4 should now be back to its former glory!
cody m nixon
회원 가입일: 03/06/18
154 평판
안내서 1개 작성함
Vegas Room H9 Vegas Room H9 회원
Community
13 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 346
