주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
iPhone 4 Verizon Rear Panel Replacement
필요한 것
동영상 개요
  1. iPhone 4 Verizon Rear Panel Replacement, Rear Panel: 1 단계, 이미지 1/1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Your phone's rear cover may have two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws. Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
    • Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
  2. iPhone 4 Verizon Rear Panel Replacement: 2 단계, 이미지 1/2 iPhone 4 Verizon Rear Panel Replacement: 2 단계, 이미지 2/2
    • Push the rear panel toward the top edge of the iPhone.
    • The panel will move about 2 mm.
  3. iPhone 4 Verizon Rear Panel Replacement: 3 단계, 이미지 1/1
    • Pinch the rear panel with your fingers, and lift it away from the iPhone. Alternatively, use a Small Suction Cup .
    • Be careful not to damage the plastic clips attached to the rear panel.
결론
다른 113명이 해당 안내서를 완성하였습니다.
Andrew Bookholt
586,109 평판
안내서 619개 작성하였습니다
댓글 4개
Step 1 says the screwdriver should only be used once. Is this correct? Or should it read the screws should only be used once?
Andrew Stevenson - 답글
Took less than 10 minutes! Works perfect. Thanks ifixit!
bsterlin - 답글
Super simple and easy! done i less than 5 minutes!
Gine - 답글
This was a remark made in the products section for the rear glass panel on the Verizon CDMA, "The instructions don't tell you to make sure that you remove the plastic lens from the front facing camera." It is referring to the protective plastic film on the new rear panel that protects the new lens. This should definitely be included in the instructions for replacement of the back panel.
uncletom - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 8
30일 전: 15
전체 시간: 46,811
