주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPhone 4S Battery Replacement
필요한 것
  1. iPhone 4S Battery Replacement, Pentalobe Screws: 1 단계, 이미지 1개 중 1개
    • Remove the two bottom Pentalobe screws next to the 30-Pin connector.
    • It is recommended that you use a small 5-Point screwdriver for this process.
    • Remember to make sure your iPhone is fully turned off before commencing this process, to prevent serious injury to the phone.
  2. iPhone 4S Battery Replacement, Back Panel Removal: 2 단계, 이미지 2개 중 1개 iPhone 4S Battery Replacement, Back Panel Removal: 2 단계, 이미지 2개 중 2개
    • Push the back panel towards the top of the iPhone. Doing this should allow the back panel to slide off safely.
    • Do not apply too much pressure to the back. Especially if your phone has a cracked back panel.
    • Do not rush it! Time is key.
  3. iPhone 4S Battery Replacement, Battery Screws: 3 단계, 이미지 1개 중 1개
    • Remove these two screws that are securing the battery connector to the Logic Board.
    • Beware of unscrewing the battery connector, as your screwdriver does have the possibility to slip and pierce the battery.
    • For the bottom screws, it is recommended that you use a 1.5 mm screw bit, and a 1.7 mm for the top screw.
  4. iPhone 4S Battery Replacement, Battery Strip: 4 단계, 이미지 1개 중 1개
    • Locate and pull the plastic tab to pull out the battery. Make sure to pry up on the outside of the battery on all sides.
    • Do not pull on the plastic tab too hard, as it can easily rip, making the battery removal process harder.
  5. iPhone 4S Battery Replacement, Battery Removal: 5 단계, 이미지 1개 중 1개
    • Carefully remove the battery.
    • Remember, if you are replacing your battery, remember to preform a hard reset on your iPhone by holding on both the home and power button for a few seconds once the repair is all finished.
결론
다른 62명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Cole Anello
회원 가입일: 11/01/16
2,028 평판
안내서 1개를 작성함
1가이드 댓글
la olum bunu benim 1 yaşında kızım da biliyo
ahmetceylanbm - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 63
지난 30일: 269
전체 시간: 24,643
