주요 콘텐츠로 건너뛰기
iPhone 4S Battery Replacement
필요한 것
  1. iPhone 4S Battery Replacement, Pentalobe Screws: 1 단계, 이미지 1/1
    • Remove the Bottom Pentalobe Screws next to the charger connecter.
    • It is recommended that you use a small 5-Point screwdriver.
    • Remember to make sure your iPhone is fully turned off before tearing it down, to prevent serious injury.
  2. iPhone 4S Battery Replacement, Back Panel Removal: 2 단계, 이미지 1/2 iPhone 4S Battery Replacement, Back Panel Removal: 2 단계, 이미지 2/2
    • Push the back panel towards the top edges of the iPhone. Doing this should allow the back to slide off.
    • Do NOT apply so much pressure. Especially if your iPhone is cracked.
    • Do not rush it! Time is key.
  3. iPhone 4S Battery Replacement, Battery Screws: 3 단계, 이미지 1/1
    • Remove these two screws that are securing the battery connecter to the Logic Board.
    • Remember to focus and pay attention. So you don't accidentally slip and pierce the Battery!
    • For the bottom screw, it is recommended that you use a 1.5 mm Screwdriver, and a 1.7 mm for the top screw.
  4. iPhone 4S Battery Replacement, Battery Strip: 4 단계, 이미지 1/1
    • Locate and pull the Plastic tab to pull out battery. Make sure to pry up outsides of battery on other sides as well.
    • Do not pull the plastic tab to hard, as it can easily rip!
  5. iPhone 4S Battery Replacement, Battery Removal: 5 단계, 이미지 1/1
    • Carefully remove the battery.
    • Remember, if you are replacing your battery, remember to preform a hard reset on your iPhone once its all finished.
결론
다른 59명이 해당 안내서를 완성하였습니다.
Cole Anello
회원 가입일: 11/01/16
1,965 평판
안내서 1개 작성함
댓글 한 개
la olum bunu benim 1 yaşında kızım da biliyo
ahmetceylanbm - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 36
30일 전: 127
전체 시간: 20,602
