주요 콘텐츠로 건너뛰기
iPhone 4S Speaker Enclosure Assembly Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. iPhone 4S Speaker Enclosure Assembly Replacement, Speaker Enclosure Assembly: 1 단계, 이미지 1/2 iPhone 4S Speaker Enclosure Assembly Replacement, Speaker Enclosure Assembly: 1 단계, 이미지 2/2
    • Remove the following screws securing the dock connector cable cover to the logic board:
    • One 1.5 mm Phillips screw
    • One 1.2 mm Phillips screw
    • Remove the metal dock connector cable cover.
  2. iPhone 4S Speaker Enclosure Assembly Replacement: 2 단계, 이미지 1/1
    • Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
  3. iPhone 4S Speaker Enclosure Assembly Replacement: 3 단계, 이미지 1/1
    • Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
  4. iPhone 4S Speaker Enclosure Assembly Replacement: 4 단계, 이미지 1/2 iPhone 4S Speaker Enclosure Assembly Replacement: 4 단계, 이미지 2/2
    • Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board.
    • De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
  5. iPhone 4S Speaker Enclosure Assembly Replacement: 5 단계, 이미지 1/1
    • Remove the two 2.4 mm Phillips screws securing the speaker enclosure assembly to the outer case.
  6. iPhone 4S Speaker Enclosure Assembly Replacement: 6 단계, 이미지 1/1
    • Remove the small black spacer that was under the Phillips screw near the vibrator.
  7. iPhone 4S Speaker Enclosure Assembly Replacement: 7 단계, 이미지 1/3 iPhone 4S Speaker Enclosure Assembly Replacement: 7 단계, 이미지 2/3 iPhone 4S Speaker Enclosure Assembly Replacement: 7 단계, 이미지 3/3
    • Use a plastic opening tool to lift the speaker enclosure assembly out of the case, being sure not to damage the EMI fingers on the attached Wi-Fi antenna.
    • Remove the speaker enclosure assembly.
    • Before reinstalling the speaker enclosure assembly's screws, be sure the Wi-Fi grounding fingers are installed below the lip in the iPhone's metal case as seen in the third picture.
    • Before reassembly, be sure to clean all metal-to-metal contact points between the grounding fingers of the Wi-Fi antenna and the case of the iPhone with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause wireless interference issues.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Walter Galan
694,627 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 726
